Question about Frymaster Dean 2424G Deep Fryer
Frymaster blowing back fire
Hi first let me ask you to locate amanual for sg14d1-s.Now my next problem is just before ignition i am getting a big boof just before full ignition.I have a beautifull blue frame but too buch bang.
    Problem Solver:
  • 8 Answers
Poor ignition at burner @ pilot... check pilot strength and position...
If this fryer is fan assisted...then fan might not be working...
Posted on Feb 28, 2009
  • 640 Answers
Google sams manuals.is your fryer propane or natrual gas if so the baffles and orfices in the fryer are clogged.propane burnes very dirty.
Posted on Aug 13, 2007
2001 road king is only firing on back cylinder. replaced plugs and coil still the same, what is next?
Hi Advantagecol, and the usual suspects are:
1. Spark plugs in bad condition or partially fouled.
2. Spark plug cables in bad condition or leaking.
3. Spark plug gap to close or to wide.
4. Faulty ignition coil, module and or sensor.
5. Battery nearly discharged.
6. Damaged wire or loose connections at battery terminals,
ignition coil, or plug between ignition sensor and module.
7. Intermittent short circuit due to damaged wire insulation.
8. Water or dirt in fuel system, carburetor or filter.
9. Fuel tank vent system plugged or carburetor vent line closed off.
10. Carburetor controls misadjusted.
11. Damaged carburetor.
12. Loose or dirty ignition module connector at crankcase.
13. Faulty MAP, CKP, and or CMP sensors.
14. Incorrect valve timing.
15. Weak or broken valve springs.
16. Damage intake or exhaust vale.
For a prime suspect please visit website below and good luck:
Big Twin Carb EFI DTC Intructions codes Harley Davidson Forums Harley...
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Aug 23, 2012 | 2001 Harley Davidson FLHR - FLHRCI Road...
Deep fryer, once reaching desired temp., will be reluctant to fire back up. Changed the thermostat and calibrated. Found loose and corroded connections. Intermittent firing. Not consistent. Any ideas?
Have you replaced the high limit? That's what I would try next... When the thermosat doesn't fix it, it's usually the high limit, but you can't tell until you replace the thermostat first... Another way to get just alittle bit more of your dollar too.... If you need pricing, please call us at 888-542-5959 or email us at reocincinnati@Yahoo.com Our website is www.restaurantequipmentinc.com
Thanks, Susan REO
Aug 08, 2011 | Frymaster Dean MJ45 Deep Fryer
Hard starting at times when hot excessive cranking engine will kick back the next time it will start perfect
This happens when the engine trys to fire on the first "upstroke' of the pistons before those big flywheels get to spinning. This is common on stock ignition systems as far as I know. Harley may have changed the systems and I might not know about it but I doubt it. Some aftermarket systems, such as the Crane HI-4 have a spark delay system. The plugs will not fire until the engine has turned over three times. This gets those flywheels spinning and eliminates the start up kick back.
good luck
Steve
Oct 11, 2010 | 2005 Harley Davidson FLHTC - FLHTCI...
Getting loud feed back when i touch the input the feedback stops
I would contact Frymaster at 1-800-551-8633. Ask for tech support.
Feb 16, 2010 | Frymaster Dean H22 Deep Fryer
My suzuki gsf 600 bandit 1999 wont start. when i turn the ignition the lights come on but the starter motor makes no noise when i press the ignition, kill switch is set to "engine...
Hi and welcome to FixYa,
Initially, try with the sidestand folded up and / or the clutch lever pulled in.  Likewise determine if there is a clicking sound when the start button is pressed:
  • if there is a clicking sound, locate the starter relay. Follow the big cable from the battery's + terminal; it would end in nother terminal of the starter relay:
  1. turn ignition ON and kill switch to RUN;
  2. short the 2 big terminals of the starter relay. Expect a big start. If the starter spins, startr relay is faulty.
  • if there is no click, then the safety interlocks are preventing the relay from engaging. Check the neutral switch/wire and sidestand switch/wire.
It is of course assumed that the battery is fully charged and that the battery cablles/connectors are clen and tight.  Postback result(s) of tests.
Good luck and thank you for asking FixYa.
Jul 16, 2009 | 1997 Suzuki GSF 600 S Bandit
I need wireing diag for filter systen for frymaster mdl 350oced sn 9608ieo147. gas fryer. thanks i just need wireing diag
Hello. I think this is what your looking for:
http://www.frymaster.com/?xhtml=xhtml/fry/us/en/general/manuals.html
Go here, scroll down the page until you get to H50 units, and click on the link that has the SP manual, 819-0001 next to it, page 32 describes the different filters, and 61 has the wiring diagrams.
Hope that helped, and thank you.
If you need more help, "ask me"
Apr 10, 2009 | Frymaster Dean Kitchen Appliances - Others
Ignitor fires early or gas valve turns on too late - no ignition
Put your hand on the gas valve and see if the click of the valve is opening just before the ignitor goes off if it does your valve is going bad
Nov 12, 2008 | Heating & Cooling
Gf 40 frymaster fryer
Hi, I am suposing that this fryer has worked good in this location before. If not, check to make sure it is set up right for your gas supply. (LP-Nat) There is something wrong with the gas - air flow in your unit. Look for obvious things first like exhaust being blocked, Flame dancing out side of fire area, Pilot too small, Build up of debris in fire box. The pilot should be able to be adjusted at the gas valve if it is too small. I believe you problem could be taken care of best with a good cleaning of the burner, fire box and pilot assemble. Make sure that all burner holes are clean especially around the pilot light. Check for oily debris inside the fire box to make sure its not leaking into the fire area. If you are unable to do this yourself, contact some one either in the restaurant equipment service business or heating and air conditioning business. Hope I have helped you. kstfas NOTE: If this answer does not rate at least 4 marks, (almost there) please do not rate. Thank You.
Sep 26, 2007 | Frymaster Dean GF40 Deep Fryer
Frymaster Dean 2424G Deep Fryer Logo
418 people viewed this question
Top Frymaster Dean Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Thomas Perkins
Thomas Perkins
Paul Carew
Are you a Frymaster Dean Kitchen Appliances - Other Expert? Answer questions, earn points and help others
