Question about Acer AL1916B 19" LCD Monitor
Unknown problem when I connect the power to my monitor it shows a thin white line across the top of the screen and some colored vertical lines at various spacings. The power light on the button never turns green and after about 5 - 10 second the screen goes blank. I have owned it for maybe 8 months. Got it as a Xmas present from my parents. It has had normal use...I have moved twice and put it back in the box both times. I have even had a real "bug" inside the screen that died and i had to turn the monitor on the side to get it out of the middle of the screen. Other than that, no drops and I live in a basement so its not very humid down here and it doesn't get super cold or hot. My pc's specs are as follows: Asus A8N32-SLI Deluxe AMD dual core 3800+ (2.01 GHz) 2 GB of Kingston Ram (1 pair regular the other pair HyperX) XFX Nvidia GeForce 7600 GS 512 MB OCZ Powerstream 600W various harddrive sizes all Western Digi... if you need other specs lemme know. Also I have tried rolling back and reupdating the driver...but as the thing doesn't even power on I don't think a driver re-install will help.
Re: unknown problem
Just open the casing and look for a bulging capacitor? Replace and it should work again? If this will work then I need to find a soldering iron and a new capacitor.
Posted on Apr 23, 2008
  • 180 Answers
Re: unknown problem
It is having the problem with the main board. Open to see any buldging capacitor. replace it the it will be ok.
Posted on Apr 20, 2008
0 characters
3 Points
My ViewSonic monitor on my desktop has very, very thin lines of color running vertically all the way across the screen. Has been like this - according to former owner _ since he got it and sprayed th
I am under the impression of the following:
Some cleaning spray must have leaked in through the bezel and went on to a circuit board. In this type of case this would be a type of matrix screen drive problem. If any of the boards are damaged they have to be replaced. I have my doubts you can buy circuit boards and service the monitor yourself. It would be much more reasonable to replace the monitor.
When cleaning a monitor with liquids, dampen the soft tissue with the cleaner, and then do the cleaning on the screen. Make sure no liquid will run down to below and beneath the bezel.
Jerry G.
Jun 30, 2012 | ViewSonic Computer Monitors
Band of virtually solid white lines (ca 7cm wide)
check on bios if still there then monitor needs repair.
Sep 15, 2009 | Dell E176FP 17" LCD Monitor
Vertical white line near the left end of the screen.
Usually when there are colored lines on the LCD its because the screen is going bad. Quick way to verify this, try a different monitor on your computer and if the line goes away then you know for sure the monitor is bad.
If you try a different monitor and the line remains then you know that the video card is bad.
Jun 03, 2009 | Mitsubishi Power Adapter for DiamondPoint...
Permanent vertical line down monitor
The thin ribbon that connects the board on the back of the lcd screen to the front glass of the lcd screen got damaged.
It wraps around the top of the screen and is very thin and can be easily damaged.
May be from old age and heat at the top of the screen or it could have gotten hit at the top.
The cheapest way to repair this is to replace the lcd screen with a good used one because trying to find a shop to try to repair it would cost more than a new monitor.
It will change color with different colors and also if you push the screen at the top point. Don't play with pushing the screen too often as this may cause more to show up.
Sorry there isn't an easy fix to this.
Mar 29, 2009 | Acer AL2216WBD LCD Monitor
Screen displaying a thin white very bright horizontal line.... plz help
problem in vertical section.
1. Solder the vertical ic
2. vertical ic supply capacitor problen.
3. dry points in neck board.
Aug 08, 2008 | LG Studioworks 45 14" CRT Monitor
Remove dry solder at Vertical IC if problem not solves replace VERTICAL IC and pf104
Jul 05, 2008 | LG Studioworks 552V 15" CRT Monitor
HP L1706 monitor with thin white/blue horizontral line
It is the problem of monitor pcb in vertical section.check vertical ic for dry soldring. Resolder the ic if problem still on then change ic or check components related ith it. check continuity of vertical deflection coil.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FIXYA.
Mar 13, 2008 | HP L1706 17" LCD Monitor
Bright,thin line, in the middle of the screen, then...
1. I turn on the monitor, I hear a 'cracklin' sound
Reply: In a CRT Monitor there is a component called EHT which generates High voltage which is connected to the anode of the CRT, If there is any leakage due to moisture can cause this crackiling sound, You need to clean this high tension wire or replace the EHT ( CAUTION : BE AWARE OF HIGH VOLTAGES )
2. The screen only shows a bright, thin line.
Reply: The vertical Drive section of the monitor is faulty.
Dec 21, 2007 | Hitachi SuperScan Elite 802 21" CRT...
A thin horizontal line across the screen
I know I have seen thin lines in the past on older CRT monitors, these are usually wires which support the aperture grill. LCD is just a panel so this must be something different. What color is the line? It is probably an error in the scanning process.
Aug 01, 2006 | Gateway FPD1975 19" LCD Monitor
Acer AL1916B 19" LCD Monitor Logo
188 people viewed this question
Top Acer Computer Monitors Experts
Steven Wander
Steven Wander
 Mike M
Mike M
Are you an Acer Computer Monitor Expert? Answer questions, earn points and help others
