Question about Fujitsu Desktop MPG3204AH 20.4 GB Hard Drive
Invalid boot disk
There are a couple of posts here with a problem like mine System will not recognize my drive. I got another drive same model and changed the controller board. Still same problem is there different versions of controller boards on the same model of drive. Is there anything else I can try. Has anyone taken the platters out of a drive and put them in another drive same model. I will try the freezer thing and see what comes of that. Is there anyone that has had luck with that. Anyone care to exchange there experience with changing the controller on the hard drive Id like to hear how you made out Thanks Rick
  • trickyrick Aug 14, 2007
    I tried that (put it on another computer) Windows will not recognize it and neither will any of the tools that I have downloaded to recover files. The software scans the system for HD's and they don't see my second drive. I have even purchased another drive same model and replaced the controller (thinking it was that) is there anything else that could go wrong in the drive that I could replace out of the working drive I purchased
    Thanks
    Novelist:
    Scholar:
  • 158 Answers
The reson for this invalid boot disk is it need to be formated to the motherboard and made active primary hard drive this is it you are going to use it but it you have files that need to be recovered please use another pc and use ntfs recovery tools to recover files this see deep inside the hard drive even when there is no boot sector there place this drive on secondary Ide if pc has 2 ide ports but if only 1 ide then jumper this as slave. and if a virus attacks the mbr which is know as the Main Boot Record. hope this helps.
Posted on Aug 14, 2007
  • nicky rye Aug 14, 2007
    which operating system you running if its windows on pc then use rstudio ntfs recovery tools if you are running mac then see if they do the program for that system or you could email me on [email protected]
    and I could give more advice on problem
SOURCE:
Toshiba portege 2000 windows xp invalid system disk.
When booting, try going to the Boot Menu by pressing F12 when you see the Toshiba logo so you can select your hard drive as your boot device. After doing so, if you still get an "Invalid System Disc" error, then your hard drive may be shot.
Jan 04, 2014 | Toshiba Tecra 510CDT (P000224080)...
Invalid system disk
The computer TRIED and FAILED to boot from the hard-disk, and now is expecting you to insert a "bootable" CD-ROM into the optical drive. Replace the "dead" hard-disk.
Dec 01, 2013 | Compaq Computers & Internet
At boot-up I get "invalid
1) Go into your bios by pressing the Delete key.
2) Navigate to boot disk priority.
3) Set this to Primary master disk drive (The drive that your operating system is installed on.
4) The save and exit.
This should stop the message from coming up and solve your problem.
Please rate this solution by clicking on the thumbs up at the top right of this solution, it is much appreciated.
Thanks.
Nov 01, 2010 | ASUS A7V333 Motherboard
Ibm deskstar model dtla-307015 invalid system
For some reason, the computer isn't able to read the hard drive and Windows isn't being found. If this computer has a floppy disk drive, make sure there's no disk in it. (Some people still use floppies, and the normal setting for systems with floppy drives is to try booting from that drive first. You may have a disk in it that isn't bootable.) Other possible causes are hard drive failure, a virus or other malware program has damaged the drives boot sector, or a motherboard problem. The most likely cause would be the hard drive; as a mechanical device they are more prone to fail than other parts.
Mar 08, 2010 | IBM NetVista M42 PC Desktop
Computer doen't recognize Maxtor n256 have to boot by CD
  1. Log on as administrator or as a member of the Administrators group.
  2. Click Start, click Run, type compmgmt.msc, and then click OK.
  3. In the console tree, click Disk Management. The Disk Management window appears.
  4. you should see the maxor disk (unallowcated)
  5. right click & format it
Apr 04, 2009 | Maxtor Hard Drive
Non system disk or disk error
This error can be a couple of things. If the "boot block" on the disk has become faulty, the system won't recognize that the disk has an operating system on it and will generate this error message. If the disk is defective completely, the same error will occur. If you have a boot floppy or CD, try re-writing the boot block on the disk. If that fails to resolve the problem, the disk is defective and will need to be replaced.
Dan
Feb 25, 2009 | Compaq Computers & Internet
IBM THINK PAD 390X LAP TOP INVALID SYSTEM DISK
check that you have no floppy disks in the drive and also no usb memory sticks/Hard drives plugged in as if they are and are not bootable you will get the error you describe
Dec 11, 2008 | IBM ThinkPad T40 2373 Notebook
Cd/dvd problem on toshiba m45-S165 laptop
Is you new hard drive lager than you old on and was the disk drive a factory replacement cause with those disks if you even change just that they will not work
Dec 09, 2008 | Toshiba Satellite A45-S250 Notebook
Asus M2N motherboard ATA problem
Hi, Go into the POST and set it back to the default setting. Reboot and see if the cd/dvd rom drive. If it still does not recognize the drive, then try using a different IDE cable. Question, did the MB work fine and all of a sudden it does not regonize the drive? By the way, I have the same MB. So far I have not encounter any problems with it. Thanks, Mike
Nov 01, 2008 | Computers & Internet
Invalid Boot Diskette
Check the floppy drive to see if there is a disk in it....if so, remove it and try booting up the computer again.
Jan 20, 2008 | Dell Dimension 2300 PC Desktop
Fujitsu Desktop MPG3204AH 20.4 GB Hard Drive Logo
157 people viewed this question
Top Fujitsu Computers & Internet Experts
Ekse
Alun Cox
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
