Question about Passport 8500 Radar Detector
Service Required on 8500
I get radar detector calibrating message when I power up the detector and when it finishes I get "service required"...Then I push the 2 buttons and it tells me "calerror 3". What is my next step? Thanks!
  • 1 more comment
  • mugunini Aug 23, 2008
    Started getting Service Required message. Won't work anymore. Where can this be fixed?
  • a_damm Sep 05, 2008
    Radar reads service required after a few minutes of usage. what do I do?
  • yo mama
    yo mama Mar 06, 2019
    This is how escort gets a couple hundred of bucks off their customers, its programmed to do this after a certain amount of time. escort makes hundreds of thousands off this error every one of their detectors will do eventually.
  • 3 Answers
Hold all THREE buttons, one is located on the front right of the detector, while turning the detector on.
Posted on Sep 29, 2007
I had the same problem and ventured to disassemble it. Good decision on my part instead of sending it back for repair. I found that the grooves that the top buttons set in were dirty so it made my buttons stick. So in essence the buttons were always pressed downward to the point it had my detector cycling. So it would program and then get the service alert. Once I cleaned the buttons and the grooves in between, everything is just like new. Hope that helps.
Posted on Mar 10, 2008
If you leave it in your car in the sun it can overheat and say service required it justs happen to mine a couple days ago and i let it cool down and it worked try that
Posted on Apr 22, 2008
SOURCE:
My 8500 keeps telling me service required
Needs to be re calibrated, escort can do that for you, so give them a call.
Aug 23, 2011 | Passport 8500 Radar Detector
My 8500 Radar more and more often displays service required message. How do I fix it? Thanks
This is due to failing the calibration test.Perhaps you can reprogram it or will have to return for sevicing.
here is the brochere link.
http://www.escortradar.com/pdf/8500x50manual.pdf
Oct 09, 2009 | Passport 8500 Radar Detector
Passport Radar service required
The internal diagnostics have detected a problem with the detector. You should contact Escort Customer Service directly for assistance, below:
http://www.escortradar.com/customer-service.php
Sep 27, 2009 | Passport 8500 Radar Detector
I got the Service Required message. What do I need to do?
The Service Required message indicates that your RD has repeatedly failed its attempts to perform self calibration of its radar detection circuitry. Only Escort can repair this issue.
Jul 13, 2009 | Passport 8500 Radar Detector
Service required
If this sounds like a dashboard alert for a fault then you need to have your car diagnosed by a computer to find the exact fault.It works out to be cheaper..Check digimotolite on google ...
Jun 15, 2009 | Passport 8500 Radar Detector
Service required
This message is generated only after a Bel or Escort radar detector has repeatedly encountered problems while trying to self-calibrate its radar detection circuitry. The Service Required message literally means that you must send in your RD for service since there is nothing that can be done to fix whatever the problem is short of sending it in for factory service. At least it will come back working like brand new!
Mar 06, 2009 | Vector 955 Radar Detector
I have a passport excort 8500 X50 that signals maximum Ka and X over and over.
Are you getting any Self Calibration or Service Required error messages? If not, then this means that the basic electronics are good and that the problem is within the antenna. If your X50 is in warranty then Escort will repair the antenna for free. If not, then there will be a service fee ($80). Yet I can all but guarantee you that after Escort fixes the antenna problem then you will never have this problem again.The service fee also includes fully testing and calibrating your X50, and updating its internal computer firmware code to their latest code. So the end result is that your X50 will perform just like a brand new one.
Jan 25, 2009 | Passport 8500 X50 Radar Detector
Escort 8500 radar detector
Service Required means that your 8500 has repeatedly failed while attempting to calibrate its radar antenna. This can be fixed by Escort for free if your RD still is in warranty. There is a service fee if your RD is out of warranty, but at least Escort will fully test everything in addition to repairing your 8500, and they will upgrade your 8500's firmware to whatever their latest and greatest firmware is which may help to improve sensitivity, reduce false alerts, or to detect newer laser gun models.
Aug 05, 2008 | Passport 8500 Radar Detector
Service required
Hold down all three buttons and the device will reset itself.
Dec 15, 2007 | Passport 8500 Radar Detector
Passport 8500 Radar Detector Logo
2,473 people viewed this question
Top Escort Vehicle Parts & Accessories Experts
Jason
Steve Allison
Steve Allison
Marvin
Marvin
Are you an Escort Vehicle Part and Accessory Expert? Answer questions, earn points and help others
