Question about Toshiba 42HP83 42 in. HD-Ready Plasma Television
Television shuts off after being on for 30-60 seconds.
RE: I have the same problem. The television shuts off after being on for 30-60 seconds. Thank God it is happening while still under warranty. Is this something simple that I'm missing? When it goes off, the red (on) light actually blinks twice every few seconds. I'd appreciate any help anyone can provide. I don't see that anyone posted a response. I hope someone can help.
Same thing with mine! I just had a repair guy out and he said it was the power supply grid and that it would cost 1300 to fix!
Posted on Oct 02, 2007
I just had the same problem with mine (Toshiba 42HP85) The TV was fine and shutoff red light blinked twice, and you can turn it on agin right away then it shuts off again. The problem was there are 2 cooling fans you can here at the top rear of the unit, when they get dusty the bearings wear out and shut off. See if you can here 1 or both fans working. If only one is on, you can get a replacement from coolguys.com for 7.95 ea. model # is on the back of the fan. Replace both while you have the cover off, if that's the problem. The unit shutting off is the computer sensing there is a problem the red light is an error warning. Good Luck!
Posted on Aug 25, 2007
Sound but no Picture.
You have an akb shut down due to bad crt's (it could be any one of the crt's bad).
Mar 19, 2010 | Sony KP-46WT520 46" Rear Projection...
2003 Sony Trinitron 36" television. Just shut off, light blinkin
The STANDBY light will flash if the television detects an issue within the television. Some of these issues can be resolved simply by following the steps below to reset the television.
If the issue is still unresolved after following all of the troubleshooting steps, Service will be required. Please note the number of times the STANDBY light flashes and relay that information to the service center.
  1. Turn off the television. IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
  2. Unplug the television power cord from the electrical outlet.
  3. Let the television remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
  5. Turn on the television.
Sep 14, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Turn on the tv a few seconds later it shuts the power light blink
Replace both of your convergence ICs they are STKs big black ICs will have part number on them.
Jun 19, 2009 | Mitsubishi WS-55511 55" Rear Projection...
While trying to change channels, my t.v. displayed ''no signal'' and then shut itself off. Now, when I turn it on, it says no signal and turns itself off after a few seconds.
Turn the television on and as soon as the screen turns on repeatily press the input button or change the input to whatever input you are using from a source device. As long as you change it to anything other than RGB.
Your television is essentially a big computer monitor with multiple inputs and a tuner. When using your computer and shutting it down the monitor will go in a power save mode. You don't need to shut off your monitor due to this power saving mode. When you power up your computer your monitor automatically turn on.
With the VIZIO and the RGB (computer) input the television will act just like a computer monitor. When you have a computer connected it will power down automatically when you shut off your computer. When you turn your computer on the VIZIO will automatically come out of standby mode. This is through RGB only.
This is normal operation for the VIZIO but can see confusing when nothing is connected to the RGB input. If you change your television input to RGB it will sense no signal on the input and will go into standby mode after about 5 - 10 seconds. If you were to send a signal to the television through RGB it would automatically kick on.
Apr 05, 2009 | Vizio L37 Television
Television shuts off after about thirty seconds
You definitely need the lamp. If you can provide the make and model # i can probably tell you which lamp you need.
Mar 29, 2009 | Televison & Video
Television Shuts Off
TRY REPLACING THE REGULATOR OR CHECK DIODES IN SAID CIRCUIT ,ALSO CHECK FOR BAD CONNECTIONS.
Jan 26, 2008 | Toshiba MD14FN1 14 in. TV/DVD Combo
Television difficulties
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence
Dec 07, 2007 | Mitsubishi WS-55819 55" Rear Projection...
Problem with philips 50p8341 big screen tv
if in 20 seconds maybe you have lost contact at the main board hot side section!
Oct 03, 2007 | Philips 50P8341 50" Rear Projection...
Turning on for 2 seconds then shutting off
thats the protection circuit. it detects that the low and or high voltage is not correct and shuts down.
you need a tech .
Sep 04, 2007 | Mitsubishi WS-55315 55" Rear Projection...
Toshiba 42HP83 42 in. HD-Ready Plasma Television Logo
328 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
