Question about HP PSC 1210 All-In-One InkJet Printer
Printer not printing Wordart or Clipart in Word - newly installed on Vista laptop. Displays on the screen but does not print.
  • Anonymous Jul 18, 2008
    6month old laptop with Vista operating system - Been given a printer to use (HP PSC 1210 all-in-one inkjet) but not working with the laptop, not recognising it as such!
    Is there a driver I can download, or can you suggest anything else
  • Erica09M Apr 28, 2009
    Printer won't print images such as clip art. I'm using Vista, is there anything I can do to fix this problem besides buying a new printer?
No such thing as a vista driver for this printer
Posted on Sep 23, 2007
    Problem Solver:
  • 8 Answers
Just download new printer driver Vista version
Posted on Sep 20, 2007
Computer can's see Print Server in Add Printer Wizard The WGPS606 installation -- part 1 -- seemed to go fine. It sees our wireless network, we assigned it an IP address, it sees the printer connected to...
Make sure the printer has been connected locally first and that the print drivers have been installed. This should then allow you to add the printer via the set up.
Regards gaz
Sep 28, 2009 | NetGear WGPS606 (WGPS606NAR) Print Server
How to print mirror image with Cannon Pixma ip2000
  1. Click the Printer and Paper tab.
  2. Under Paper, in the Size box, select Letter.
  3. Click OK.
  4. Do one of the following:
    • If your design is a picture, clip art, or WordArt, flip it horizontally.
    default.aspx?assetid=za790050011033How?
    1. On the Arrange menu, point to Rotate or Flip.
    2. Click Flip Horizontal.
    • If your design includes text in a text box or table, turn it into a picture first, and then flip it horizontally.
    1. Select the text in the text box or table in your design.
    2. On the Edit menu, click Cut.
    3. On the Objects toolbar (toolbar: A bar with buttons and options that you use to carry out commands. To display a toolbar, click Customize on the Tools menu, and then click the Toolbars tab.), click Insert WordArt default.aspx?assetid=za060452451033.
    4. Under Select a WordArt style, click a style, and then click OK.
    5. Press CTRL+V to paste your text into the WordArt Text box.
    6. Format the text, and then click OK.
    7. If necessary, resize the WordArt, or use the WordArt toolbar to format it, and place it in the design.
    8. Select all the objects in the design, including the WordArt.
    9. Click Group Objects default.aspx?assetid=za060447801033.
    10. On the Arrange menu, point to Rotate or Flip, and then click Flip Horizontal.
  5. Print your design on plain paper first to make sure it looks the way you want it to.
  6. Make any adjustments to your design after seeing the test printout.
  7. Make sure thermal t-shirt transfer paper is in the printer.
  8. On the File menu, click Print.
  9. Select the options you want.
  10. Click OK.
Source
Cheers
Jun 20, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
My Epson RX 620 will not print anything from the computer with Vista
Have you tried running a print test page? Have you gone to epson.com website to see if they have printer driver available for your printer...
www.epson.com/cgi-bin/Store/support/supDetail.jsp?oid=44341&infoType=Downloads -
Jun 16, 2009 | Epson Stylus Photo RX620 All-In-One InkJet...
Incorrect & missing colors
I would try purchasing new ink - especially if the printer and inks has been sitting unused.
May 14, 2009 | Laser 3115cn All-In-One Printer
Hp deskjet 9650 not compatible with Vista 64-bit
Hp Deskjet 9650 printer owner, sorry to inform that there is no Microsoft Windows Vista operating system printer driver solution available for your printer. But there is an alternative way to workaround it so that you can do basic printing with your printer.
As a workaround, an alternate printer driver solution included in Microsoft Windows Vista operating system can be used to perform basic printing to the printer. However you might find that some of the product features are no longer available when using this alternate printer driver, but that is your best option right now.
The alternative HP printer driver that will work with your printer is HP Deskjet 9800.
The Next thing you do is: Install the driver for HP deskjet 9800
1. Verify that the Universal Serial Bus (USB) cable is NOT connected to the printer.
2. Click Start , click Settings , and then click Printers .
3. Click Add a printer .
4. Click Add a local printer .
5. Select the Use an existing port check box.
6. In the Use an existing port drop-down list, select LPT1: (Printer Port) and then click Next .
7. Under Manufacturer on the Install the printer driver dialog box, select HP .
8. Under Printers , select the appropriate alternate driver for the printer (deskjet 9800) and then click Next .
9. In the Printer name text box, type the printer name and then click Next . The printer driver starts to install.
NOTE: The name of the alternate driver displays as the default name. Change this name to the name of the printer, if desired.
10. After the screen stating that the printer was successfully added displays, connect the USB cable / Parallel cable to the printer and to the computer.
11. On the Found New Hardware screen, click Cancel .
12. For USB connected printer, please proceed to step three . For Parallel port connected printer, please proceed to step four .
NOTE: If multiple pop-up windows display, click Cancel on each window.
Next is: Configure the printer
1. In the printer folder, right-click on the name of the printer and then click Properties .
2. Click the Ports tab.
3. Change the port from LPT1 to the newly created USB port, click Apply .
Last step: Print a test page
1. Click the General tab.
2. Click Print Test Page .
Good luck Cheers!!!
Apr 26, 2009 | HP DESKJET PRINTER, HP OR COMPATIBLE
"Rainbow" word art (Microsoft)
Have you tried prinitng this in MONO on your 2840 printer.
Does Wordart from Word or other office programs cause this?
If it is the office suite, then look at downloading some service packs from Microsoft.
If it's just your 2840 doing it, then look at downloading a different driver.
For some printers there are different types of PCL drivers, like PCL5 or PCL6, these do behave differently per printer, so swapping the driver might not be a bad idea.
Also check if you are using a PS or Postscript driver, but again, try the PCL alternative for your printer.
I would install the different driver under another name, for testing, then if it works just delete the bad one.
May 08, 2008 | HP Color LaserJet 2600n Printer
Dell 926 printing freezing when using remote desktop
I've had a problem with a 926 freezing at the end of printing when deleting the job from the print queue.This was as a local or network computer/printer task.I changed the print processor to winprint/NT EMF 1.008 and this cured the problem.Right click on the printer/properties/Advanced/Print processor and give it a try.HTH.
(Using Vista Ultimate)
Apr 04, 2008 | Dell 962 Photo All-In-One InkJet Printer
No printer information
Follow these steps to set up your Epson product and install the built-in Windows Vista drivers:
  1. Set up your computer.
  2. Connect your Epson product to your computer.
  3. Follow the on-screen instructions that Windows Vista displays to guide you through product driver installation.
You need to use a program that can do printing multiple pictures in just one click.
Feb 05, 2008 | Epson Stylus Photo R200 InkJet Printer
Cannot select 'properties' when I choose to print - printer newly installed on Vista
yes you can update your printer drive for vista go to hp site and see is there update are available or not..bye
Aug 12, 2007 | HP PSC 1210 All-In-One InkJet Printer
HP PSC 1210 All-In-One InkJet Printer Logo
1,048 people viewed this question
Clive
Clive
