Hello Samiran mandal, here is a solution.I purchased one cordless telephone (Siemens Gigaset) in Germany. I also had the same problem, caller-id did not work. I purchased this telephone because we can set different ringtones for different caller groups. But, if caller-id doesn't work, this feature also doesn't work. I had gone through internet and finally found that CA electronics, Bangalore has it and got it through courier (I live in Pondicherry). It worked flawlessly for two years. Then it stopped working. For 'no reason' I ordered for a 'caller-id' unit on ebay for Rs.75/- (+ Rs.75 shipping). I just got the unit and fixed it to my line. Very very surprisingly, my cordless telephone is now showing caller info. This is a real surprise to me. By the way, caller-id unit is "Eurotel" make, DTMF/FSK caller-id. I feel this is very nice solution. The 'caller-id' unit is nice (backlit display) and also there is no need of converter for using the caller-id feature of your foreign telephone. I connected caller-id between the line and telephone. That's all. Enjoy.
The one who can show the caller ID when someone call is the caller only. He/she can set to hide his/her number ID in their phone so we can't see it. We can't force to see this caller ID, but if this calls disturbed you, you can install call blocker and only allow certain incoming call to be recieved.
Thanks for using FixYa. I think you have stored more than 100 Caller ID messages and hence the caller ID is not showing on Uniden Tru8888.In the following cases the caller ID will not be shown-
If you answer a call before the Caller ID message is received (for example, before the second ring), the Caller ID message will not appear.
When the call is received via a telephone company that does not offer Caller ID service, the caller’s phone number and name does not appear. (This includes some international calls.)
When the call is via a private branch exchange (PBX), the caller's phone number and name may not appear.
You may receive any one of the following messages:
When a private name is received; Private Name
When a private number is received; Private Number
When a unknown name is received; Unknown Name
When a unknown number is received; Unknown Number
When invalid data is received; Incomplete Data
The Caller ID list stores information for incoming calls - even unanswered calls. You can store up to 100 Caller ID messages and phonebook entries (including Speed Dials) for each handset and the base. You can view the Caller ID list through the handset or base during a call or when the phone is in standby mode.
Memory locations for Caller ID messages and Phonebook entries (including Speed Dials) are common, you can store up to all 100 entries for each handset and the base. Caller ID messages are not stored when you have 100 phonebook entries. When you have stored a total of 100 phonebook entries and Caller ID messages, the oldest Caller ID message is overwritten.
Please do rate the solution and revert for further assistance.
I don't think the problem is the FSK vs. DTMF. The manual even states that the caller ID is generally received after the second ring. This is true in America. I lived in India for four months and I never ran into the problem there so... I just can't say how your provider sends the caller ID. It may be that the line is being interfered with. Do you have a DSL line attached to the same device. If so make sure that there is a filter between you phone and its connection.
I am assuming that you tested your line with the other equipment connected to the same location. You may want to reduce the problem to the simplest configuration by connecting directly to the line only no other equipment. If it works add the other equipment until the caller ID stops again. Then you know what is interfering. If you have a monitor set you could listen to the DTMF being sent make sure it is coming between the first and second ring. It is audible if it is there. If you are answering on the first ring you will not see caller ID you have to wait till after the second ring then you should see it, If BSNL is sending the same as American systems. Good luck Z
Turn off your computer off and temporarily remove the DSL filter to see if the Caller ID then works. If that makes no difference you will need to contact the dish company.
How to get the caller ID to work on the additional GE DECT phone handsets. You must follow these steps in the exact order :
#1 - unplug the base phone
#2 - unplug the telephone line from the base phone
#3 - remove the battery packs from the phones
#4 - wait 10 minutes. reverse the order when assembling. Put battery packs in phones, put the telephone line back in the base phone and lastly plug all phones back in.
It takes about another 10 minutes after that before all phone handsets start recognizing caller ID.
Here is the tip directly from the manufacture vtech.
Tip 1 of 1
Caller ID and Call Waiting ID are subscription services, available from most local telephone service providers. You must subscribe to these services in order for the features to work on your phone. Contact your local telephone service provider for more information.
In addition, your caller must be calling from an area that supports caller ID.
Both you and your caller?s telephone service provider must use compatible caller ID systems.
Caller ID and Call Waiting ID may not be available for every call. Common reasons are incompatibilities between your and your caller?s service, transmission errors and answering calls before the ID data is received.
They state that if you have further problems, to contact customer support at 1-800-595-9511.
Also, who is your phone service provider? And who is the manufacture of the old phone?
If this does not help, please post further.
Also, please rate this solution through fix-it.
Thank you.
