Question about Panasonic PV-GS35 Mini DV Digital Camcorder
Counter reset for a press of each record
While recording the video the time counter is going to 0:00:00:00 for each press of record button. The recorded video is also improper. can aybody tell me what problem it has?
  • Ganesh Hegde Aug 12, 2007
    Im using Panasonic Tapes
    I tried Head Cleaning three times.
    I can't play the videos recorded by other DV camcorders also.
  • 38 Answers
It brings to mind that the drum is not picking up the time code track from the previous pass nor is it able to lay down a new suitable track. Have you tried a dry type cleaning tape? It sounds like you have a clogged head. Other possiblities will involve repair. Drum connection problems can occur for instance. If you are using maxell tape you have a higher percentage of possible cleaning issues. Good luck, magic seadog
Posted on Aug 12, 2007
How do you reset the counter when shooting video?
The resetting of the counter is not a problem. As a matter of fact you can not reset it because it is meant to be continuous as long as the video is the same. However there is way around it. After recording your first part when you want to reset you go to 'play'. You play forward for less than a second and stop. When you go back to record the camera resets itself and thinks its starting a new video. It goes back to 000. You keep on doing this when you want to reset again. Normally in professional circles the time code should be continuous for editing with professional Non linear editing software that's why the cameras do not reset the time code. But you can get along the way I have told you here for your purpose.
Oct 27, 2011 | Panasonic PV-GS39 Mini DV Digital...
An error appear in lcd screen of canon Mp550 is 5b00 please send to me an urgent soluation
If you encounter "Error Code 5B00" it means that the Printer Counter Protection is Full and it required a reset and Ink absorber replacement, if you want your printer to work again. There are two ways to reset the Canon MP printer, One is by using a Software tool and the other is manually resetting the EEPROM of the printer. Below is the step by step procedure on how to reset your Canon printer.
1. Using MPtool Software to reset Canon MP Printer
Turn of printer then run mptool software this software automatically detect the printer.
Click reset main and reset platen button in the waste ink counter section.
If you want to reset the cartridge ink level, click reset black and reset color in the ink counter section.
2. Manual Reset of the printer
Turn off the Printers.
Press and Hold the button Resume/Cancel then press POWER button.
Release the Resume/Cancel button while keeping POWER button on press.
Press Resume/Cancel 2 times and then release all the buttons.
When the indicator recorded GREEN - click Resume/Cancel 4 times!
Turn off and On the Canon Pixma MP Printers. And your done.
Feb 21, 2011 | Canon PIXMA MP520 InkJet Printer
Dvr restart
WARNING: this will wipe out all of your recordings, all scheduled recordings, all series recordings (your series priority list), and all manual recordings!! Write down everything you can before you do this!
  1. The DVR should be turned on. Press CABLE, POWER to turn off the box.
  2. Immediately press OK/SELECT to bring up the diagnostics page.
  3. While on this screen, press the following key sequences press the counter-clockwise arrow (REPLAY on some remotes) 2 times, then press the MyDVR (LIST on some remotes), button 3 times then the live button 2 times."Clr" will appear on the LED display.
  4. Press OK/SELECT to proceed with the reset. The STB should now reformat the HD & then perform a STB reset and begin to reload your Cable settings and Time Settings from the Head End. It will then begin to populate the Guide data over the next 2 - 24 hours.
On some systems, the button press pattern may be 1-3-1, not 2-3-2 as above. This is true for at least the DCT 3416 I on Shaw.
Feb 17, 2011 | Computers & Internet
En la pantalla de mi impresora aparece error 5B00 digame q puedo hacer?
Feb 02, 2011 | Canon MP490 InkJet Printer
I have an error code 5B00 on my Canon MP830 printer. Can you help?
If you encounter "Error Code 5B00" it means that the Printer Counter Protection is Full and it required a reset and Ink wastepad replacement, if you want your printer to work again. There are two ways to reset the Canon MP830 printer, One is by using a Software tool and the other is manually resetting the EEPROM of the printer. Below is the step by step procedure on how to reset your Canon printer.
1. Using Mptool Software to reset Canon MP830 Printer
Jan 24, 2011 | Canon PIXMA MP830 All-In-One InkJet...
ERREUR 5B00
Jan 17, 2011 | Canon PIXMA MX310 All-In-One Printer
Hi, need help with the camera not powering down unless i take the battery out & when i try to record the camera says record but the counter clock is not showing any recording time, any help would be...
Once you turn off the camera and remove the batter, does it power on and if you press the off button does it go off ?
Try this
You need to know in which position was camera turned of.
So try turning it on in RECORD OR PLAY position.
It will work then...
Nov 27, 2010 | Panasonic Palmcorder PV-GS15 Mini DV...
Tape Counter
Thank you.  The machine has a reset button that brings the counter back to zero. Still not sure it is working right but I'll see as I transcribe my tapes.
May 19, 2009 | Sony BM-840T Desktop Cassette Transcriber...
Recording
The EDSR1600 will not go into manual recording mode (by pressing the REC button on the front panel) unless all of the automatic modes are disabled and the hard drive bays are firmly pressed in and locked. Press the MENU button, select ALARM and turn everything in the OPeration column to OFF. Return to the MENU, select MOTION and also turn set all the OPerations to OFF. Return again to the main MENU and under RECORD, set ALARM RECORD OPERATION to OFF, PRE-ALARM RECORD OPERATION to OFF, and PERMANENT RECORD OPERATION to OFF. Note: Turn the JOG wheel clockwise or counter-clockwise to select an option. Press the ENTER button to confirm the option and move to the next field. Press the MENU button to enter, or return to the main MENU. Press the MENU button twice to exit the main MENU. To check if the round key locks on the front of the Hard Drive bay trays are locked, turn OFF the EDSR1600. Open (pull down) the left side front cover and gently pull up on the drive bay handles. If locked, the handles should not lift and the bays should not slide out. After your check, press the bays in firmly to ensure good seating of the Hard Drives. The ESDR1600 should now go into manual RECord if the DVR is working properly. The red REC LED should also light each time a recording is being made. If the REC LED flashes, this means the DVR is recording a field or frame of video.
Jan 26, 2007 | EverFocus EDSR1600 16 CHANNEL 160GB...
Open Questions:
Panasonic PV-GS35 Mini DV Digital Camcorder Logo
49 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
