Question about Sony PlayStation Portable (PSP) Console
Psp battery problems
Hi There My PSP battery is charging and shows 100% after charge but the console doesn't switch on. It switches on and works fine with the ac adapter even with the battery inserted, but as soon as I take the ac adapter out the console dies down. I have checked the battery. tested it in a different console and tested a different battery in mine but still the same problem. Can this be a blown fuse or is my problem more severe.
  • Sony Expert
  • 311 Answers
If you tryed it with the other batterys and it died also try this website if you are technical enough to do it because it ruin ur psp if you do it wrong http://www.llamma.com/PSP/repair/PSP_fuse_repair.htm
Posted on Aug 13, 2007
  • 85 Answers
Clean the battery contact. buy a new battery, sometimes the battery will die if you have charged it without letting it drain completely. If this does not work then it may be your motherboard or a connection that leads to the motherboard.
    Problem Solver:
  • 19 Answers
Have you try to use come electronic contact cleaner to clean the battery contact of your psp ? Clean both the battery and your PSP !!
SOURCE:
Psp 1001 charging really slow using usb to ac adapter
You have to buy ac adapter I was same I don't have ac adapter but I have powerbank so I can charge it
Feb 22, 2013 | Sony PlayStation Portable (PSP) Console
I need to know if the power source could be the problem. I already replaced the battery and it worked fine for a week, and then died. I already took it apart once and fixed the dpad, so that's not a p
This could be due to a faulty charging cable, a burnt-out battery or the interference of software you have downloaded. Solve these problems by testing your PSP to locate the charging problem and proceed to implement the correct solution.
Instructions
Revert to Factory Settings
1 Switch the WLAN button on your PSP so that it is in the "Off" position. Remove any memory stick or UMD that is in the system and put them aside.
2 Choose "Settings " from the left side of the cross media bar. Scroll to "Restore Default Settings." Press "X" to enter this menu. Press "X" to accept the restoration. The PSP will then revert back to its original settings.
3 Power off the PSP and plug it into an outlet with the AC adapter to charge for three hours. Power on the system to see if if the charging issue has been resolved.
USB Charging
4 Power on your PSP and scroll to the far left of the cross media bar. Choose "System Settings" and press "X." Scroll down the System Settings menu until you reach the option for "USB Charge." Press "X" and switch the setting to "On."
5 Return to the "System Settings" menu and choose "USB Auto Connect." Make sure the Auto Connect setting has been turned on. This allows your PSP to enter USB mode and begin charging whenever it is connected to another device.
6 Connect the PSP to a powered on PS3 or PC using the USB connector cable. The small end fits into the top of your PSP while the large end is inserted into a USB slot in your chosen system. The PSP will automatically enter USB mode as soon as it is connected.
7 Leave the PSP attached to the system for 30 minutes to an hour. When you detach your PSP, check your battery power. If it has gone up, then the charging problem is with your AC adapter. You can replace it or continue to use the USB charge function.
Battery
8 Plug your PSP into an outlet using the AC adapter cable and power on the system.
9 Enter the "System Settings Menu." Scroll down until you reach "Battery Information." Press "X" to open the menu.
10 Check the last option on the page which is labeled "Battery Status." If the status does not say "Charging," then the battery is not receiving a charge from the cable. While your PSP is getting power from the cable, you will need to purchase a new battery.
Oct 04, 2012 | Video Game Consoles & Games
My sp will not charge, I am not sure if it is the battery or something else
Game Boy Advance SP - Charging Light Won't Display If the orange-colored charge light on your Game Boy Advance SP is no longer coming on when the A/C Adapter is connected to your system, please use the following troubleshooting steps.
    Troubleshooting Steps:
    1. Make Sure the Game Boy Advance SP Isn't Already Fully Charged
      If the battery is already fully charged, the light will not display when the system is plugged into the AC Adapter. Play a game without using the AC Adapter for at least 10-15 minutes, then plug the AC Adapter in, to see if the light comes on. If it does come on, the battery was fully charged. If the light still does not come on, see Step 2.
    2. Make Sure the Outlet You Are Using Works
      Plugging another electrical device into the outlet is a good way to check if the outlet works, or that the outlet you are using is not controlled by a nearby light switch. You may also want to try a different outlet.
    3. Try a Different Licensed AC Adapter
      If the charging light doesn't display, try a different AC Adapter, if possible, to determine if perhaps the problem is with the adapter.
      • If a different AC Adapter works, you will need to get a replacement AC Adapter from our Online Store, or by calling our Consumer Service Department at 1-800-255-3700.
      • If a different AC Adapter doesn't work, or if a replacement AC Adapter is not available and the lights will not display, we recommend having your Game Boy Advance SP repaired. Check out our convenient repair options.
    Note: Please be sure to include both the Game Boy Advance SP and the AC Adapter with any repair
Sep 02, 2011 | Nintendo Game Boy Advance SP Console
My psp 1006 is not working, the power green flash light comes for 3 second on and off the screen stays black.
Let's start with the obvious first. It the psp properly charged? if yes, then contiue reading. Try taking out the battery and putting it back in. You may also take out the battery all together and just run it off the AC power adapter. if the unit runs fine just using the AC adapter, it means that your battery is busted. If the unit still does not work, your Memory Card may be the culprit. Try removing the memory to confirm if it is indeed causing the problem. Replace if needed.
I hope everything works out. All the best to you.
Jul 12, 2011 | Sony PlayStation Portable (PSP) Slim...
Not charging ac power orang light not coming on.
Check the powerpoint, switch, Battery, charger!
One or more of those could be the problem!
Oct 21, 2009 | Sony PlayStation Portable (PSP) Console
Chargind psp
If it’s the 2000 series (PSP Slim), then yes. Connect your PSP system to an available USB port on your computer. Turn on your PSP, then under “Settings“, select “USB Connection”. Your PSP should connect to your computer and start charging. It may take awhile, but it will charge it all the way. Hold the display button (The button with the rectangular shape at the bottom of your PSP) until the screen goes black. This will speed up the charging process and is a good method of prolonging battery life when listening to music or other things.
If that doesn’t work, try looking for an adapter lying around your house that matches the volt numbers. The PSP takes 5V. Most portable CD players use 5V adapters and are usually the same size as needed for the PSP. I suggest using an adapter that matches the volt number and fits without trouble. If the orange light doesn’t come on or the PSP acts weird after charging, I’d stop using the adapter. Ask me any questions if you have any. ;)
Sep 02, 2008 | Sony PlayStation Portable (PSP) Console
Psp
So you are trying to update your firmware and the screen goes black? Can you still hear the startup sound when you switch it on? If you cannot, your psp seems to be bricked, for some diy repair, read my little tip near the bottom of this section, or send it back to sony for repair.
Next time, before you proceed to update firmware, have your battery charged 100%.
Dec 26, 2007 | Sony PlayStation Portable (PSP) Console
Sony playstation portable
It might be a problem with your battery pack, you can even switch on your psp without battery pack, with the charger plugged in acutally. So a replacement battery will be a good choice for you.
Dec 24, 2007 | Sony PlayStation Portable (PSP) Console
Sony PSP not charging
ok heres what you do 1. try blowing in the adapter slot 2. take out the mem. card & the battery for 24 hours 3. buy a new psp
Apr 30, 2007 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
126 people viewed this question
Top Sony Video Game Consoles & Games Experts
Ekse
shevantha perera
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
