Question about Teac PD-H300 CD Player
CD PLayer no longer recognising CD RW discs
The CD player has been playing CD-RW disc's fine up until today when I put in a disc that had previously worked, but when it tried to load the tracks, it came back with No Disc on the display. Normal CD's seem to play fine, although occasionally it does sound like it's even struggling to read these. I've had the system for just over three years but rarely used it so I can't imagine that the laser has gone already. Can you offer any advice?
  • Anonymous Dec 17, 2007
    I have a Teac CR-L600 cd/receiver micro system.  When I put a CD on it opens and closes and goes to track 1 but does not play.  I have used the memory button and play but still nothing.  Any solutions please?
  • 35 Answers
Use fine cd on ur player. If some cd is not working ten do not try it again an again. Try different one. Thank You.
Posted on Aug 14, 2007
SOURCE:
I just bougth a marantz cdr 300 cd recorder,everything seems to be working fine, but I'm not able to listen what I just recordered on any other cd player.Marantz cd 72 mr 2020.Thanks
It sounds like you haven't followed the last step to the burning procedure. All you need to do once you've completed burning your disc is to Finalize the disc. Read below why you need to finalize as well as the steps to follow in order to finalize the disc.
Hope this helps ;)
How to Finalize Finalizing is writing the TOC (table of contents) on a disc so a CD player can recognize the number of tracks, the total time for each track, and their location on the disc. A recorded disc must be finalized to playback on a standard CD player. Once finalized a CD-R disc can be played on CD players that support CD-R playback. CD-RW discs can only be played on CD players that support CD-RW playback. Consult your CD player owner's manual to confirm supported formats. Finalizing is necessary to: • be able to play a recorded CD-R or CD-RW disc on a CD player • prevent further recording on a disc • avoid erasing tracks on a CD-RW disc • record text information onto a disc you record Notes: • A finalized CD-R disc can never be recorded onto again. • A finalized CD-RW disc can be unfinalized for more recording. • The CDR300 can play back unfinalized CD-R or CD-RW discs. • SYNC REC+FINAL mode automatically finalizes.
Here are the steps in order to Finalize your disk
1 Push Stop. The display shows the number of tracks and their total playing time. 2 Push FINALIZE. FINALIZE is displayed for about 3 seconds.
Jul 27, 2011 | Audio Players & Recorders
Shows unkown disc when i put in a burned dvd-r but it will play a store boughten disc what disc format is compadible with yhis unit
This model DVD player can play the following disc formats:
DVD-Video (Region 1 or relevant region coded store-bought movies)
DVD-R (must be finalised on appropriate recording equipment for compatible playback)
CD-R (for jpeg/mp3 media files)
CD-RW (for audio such as mp3)
music CD (such as store-bought albums)
This player will NOT accept DVD-RW/+RW discs, or Blu-Ray.
I hope this helps you a tiny bit.
Mar 21, 2011 | Durabrand DVD-1002 DVD Player
When trying to play a computer generated DVD +R DL, I get a message that says this type of disc cannont be played. please insert a different disc
The disc is probably an incompatible format for this model player. Even if the disc is finalised in your PC, or in a DVD recorder, this player may still be unable to read it. Some DVD recorder/players do not recognise DVD+R (or +R DL) media, while others won't recognise +/-RW discs (except CD-RW); this is a model limitation - not a fault with either your player, the PC burning software or the discs themselves.
Nothing can be done to fix this except purchasing a model which accepts multimedia (+R/DVD-RAM etc). The question is, does your player play ANY normal DVDs? I am guessing your player will accept DVD-R DL discs just fine since this is standard as well as proper shop-bought movies.
Feb 19, 2011 | Panasonic DVD-S35 DVD Player
Try cleaning the discs with straight swipes, with a dry cloth, like your shirt, starting from the center and swiping outward.
Mar 01, 2009 | Sharp CD-XP5500 CD Shelf System
Blue ray player wont play blue ray ''Kung Fu Panda'' disc.
i fixed this exactly as previous posted solutions, however a couple of points.
a) recordable CDs work if you don't have a DVD burner.
b) I didn't have a CD burner that would do an "image burn", I downloaded a free copy of "Express Burn" and that worked fine. The disk needs to be "finalised" or "fixated", it should do this automatically, or it may be a tick box selection.
c) I got a "No DWLD 09" when I put the disk into the player. I found this was an incompatibility with the CD-R (Maxwell) I was using. I changed to JVC and it worked fine.
Nov 22, 2008 | Sony BDP-S300 Blu-Ray Disc Player
JVC XV-THA5R multi-region DVD player - fault recognising a disc in and playing
I too have this same problem on my current DVD player, AND strangely enough I had the same problem on my previous player.
Previous player was made multi region and was a Sony S660 (I think that was the model number).
My current DVD player is a Denon and was £550! It is also made multi region and has the same problems! I don't get it!
Mar 08, 2008 | Televison & Video
Some dvds no longer play
well, seems like your laser diode is getting old. you need to change the diode. what you are experiencing is the start of a dying diod. it will start to rejects cd and soon enough it will not spind at all on all the cd's. so change the emitting diode. good luck
Feb 26, 2007 | JVC XV-S302 DVD Player
Teac PD-H300 CD Player Logo
941 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
