Question about Haier HWC08XC1 Wall/Window Air Conditioner
Air conditioner the compressor kicks on but the fan will not run
  • Anonymous May 06, 2008
    The compresser kicks on, but the fan is frozen. The unit is only a year old. What can I do to fix this problem?
  • 50 Answers
This could be an obstruction in the blower cage or the blower could be bad.
Posted on Aug 18, 2007
SOURCE:
Outside fan not running, inside unit running fine. Compressor was running this morning, but no longer. Replaced fan motor, turned power back on, now fan or compressor not running. What else can be checked?
There may be a manual reset high limit... look for a red button on a round part hooked to the small copper line and push it in hard...
Also the compressor may have kicked the overload and needs a few hours to cool and it reset, that is interanl insdie the compressor.
Contactor may also have went bad...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
Air Conditioner Trouble - Review the Possibilities
heatman101
Sep 25, 2010 | Goodman Heating & Cooling
Neither A/C compressor or fan coming on in ouside unit.
The bulge is a telltale sign of a defective capacitor along with the tripped breaker. Replace it and cross your fingers.
Jun 21, 2010 | Carrier 38CKC036 Air Conditioner
Compressor appears to kick in, runs for short time
It sounds like your unit may have a bad run capacitor or start capacitor and relay. Low voltage will also cause this problem. First you need to make sure that you have the full rated voltages at the unit, if you do, then, have the run and start capacitors checked out and the start relay.
May 31, 2010 | Dometic Rooftop RV Air Conditioner
A.c compressor kicks on and off
How long has it been there, without experiencing any problems? This just start recently? Have you cleaned intake air filters at ceiling? Fan keeps running?
Jul 18, 2009 | Coleman Mach 15 Air Conditioner
Compressor not kicking in when i turn the air conditioning on.
what is the make and model? how long has it been switched on? is the compressor top hot?
Jun 23, 2009 | Dometic Rooftop RV Air Conditioner
DuoTherm compressor starts but will not continue to run
check condenser fan if running. it will make compressor comes on and off if broken
May 31, 2009 | Dometic Rooftop RV Air Conditioner
Air conditioner fan will not come on and unit will run for 1 minute and stop
You hear the compressor kick in (Hum) but no fan comes on? Will the fan come on when just in fan mode, not cool, or do you have that set-up?
Aug 13, 2008 | Dometic Rooftop RV Air Conditioner
Compressor not kicking on
What type of thermostat are you using? When was the last time it worked ? Do you just get fan on cool mode, or does fan only run on fan mode?
Aug 08, 2008 | Dometic Rooftop RV Air Conditioner
Haier HWC08XC1 Wall/Window Air Conditioner Logo
139 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Jeff Waters
Jeff Waters
Level 1 Expert
theaircoguy
Level 1 Expert
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
