Lutron #D-600PH-DK 600W SP Push Rotating Dimmer
Problem for Lutron #D-600PH-DK 600W SP Push Rotating Dimmer
Newly installed Leviton dimmer switch humming at the switch
By conjeannieal on Mar 17, 2009
I just installed a Leviton touch dimmer for my dining room chandelier. Now whenever I turn the light on there is an annoying humming sound coming from the switch area. How can I get rid of the hum?
Comments:
Jun 02, 2009
- Thank you to those who posted solutions. Fortunately, through a little internet research I found that simply changing out the builder's grade light bulbs for a better quality bulb solved the problem.
Solution #1
posted on May 30, 2009
Not Rated)
badenhop
Rank: Wiz
Rating: 88%, 17 votes
You'll need to install an electronic dimmer, like a Maestro. Otherwise, you'll have to live with the hum.
Was this helpful?
Yes
No
Solution #2
posted on May 29, 2009
Not Rated)
jmorganti
Rank: Guru
Rating: 89%, 372 votes
Unfortunately, the hum is normal for operation of that type of dimmer at low levels.  Sometimes the lamp filaments will also "sing" a high pitched sound.
Was this helpful?
Yes
No
Popular Solutions for Lutron #D-600PH-DK 600W SP
Questions and Unsolved Problems for Lutron #D-600PH-DK 600W SP
Do you recommend Lutron #D-600PH-DK 600W SP Push Rotating Dimmer?
Answer
Answer
can i order on and off trippers for Intermatic TN111
Answer
Have white and black wires in to box and white and black wires out to lights. What goes to the... (More)
Answer
when my dimmer switch is turned on, the light comes on at full strenght then about 5 seconds later... (More)
Answer
I have a headboard with 2 westek 6043 touch dimmer lights. When I use the touch pad for one light,... (More)
Answer
the lightolier 600 "red light" is on, but the lights won't turn on. could the lightolier...
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Dimmers Experts
Top Garden & Power Tool Repairmen
(509) 678-4379
Precise Engine Repair proudly represents Briggs...
(800) 937-7279
Replacement lawn mower and snow blower parts from...
Commercial Parts Warehouse
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
