Question about Philips 32PW6006 32" TV
Phillips 32PW9525/05R TV blinking red light.
I have a 32PW9525/05R Tv it has worked great but about a month ago it stated turning it's self off and a red blinking light kept flashing at the front of the tv if i turn the tv off by the switch and back on it does the same some times it will not happen for hours other times it will be off the whole day??? Please can any one help.
BUY A NEW TV BROTHER !!!!
Posted on Oct 10, 2007
TV turns red,shuts off, stand-by light blinking 8Times
Eight blinks - Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401, and 402. On some projection models of Sony TV sets, this code means that T8005 (flyback transformer), or the associative components in the high voltage circuits are defective on the D board.
Feb 27, 2014 | Sony KP-51HW40 51" Rear Projection...
Tv will not turn on. timer light constantly blinks
If you can get into the main menu go to load factory default and reboot, This will reload factory settings and this operation will erase all unwanted settings and load back to factory default. so you can load your own settings and take back control of your tv.
Feb 23, 2010 | Toshiba 42HL196 42 in. LCD HDTV
Tv turns on and off 3 times before picture appears
Ballast Board its what turns Lamp on Call Encompass or visit their website. 1-800-638-3328
Dec 14, 2009 | Toshiba 56HMX195 52" HDTV DLP Projection...
Blinking red led light when I plug in the tv then it turns right
Phillips purchases the main circuit board from Samsung, and it has a problem with capacitors failing. The failed capacitors can be easily identified as the top will no longer be flat, but will have bulged up.
If you have a local TV repair shop they can help you.
Jul 26, 2009 | Philips 42PF7220A 42 in. Plasma Television
TV shut off while watching and won't come back on
It seems this is a self diagnostic function. the official sony codes are as follows
  • Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
  • Six blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206.
It sounds like you have a video input problem. Have you unhooked all inputs from the TV and tried to power it back on by itself? Hope this helps
Mar 18, 2009 | Sony Televison & Video
42'plasma phillips tv
I had the same problem and fixed with a great online tutorial. Just replace 3 capacitors available at Radioshack onthe the board. 2662, 2663, 2664 1 is a 1000uf the others are 100uf. Max Volts need to be over 25. It worked great, check http://dynamicorange.com/2008/06/25/fixing-a-plasma-tv/
for more detail.
Jan 06, 2009 | Philips 42FD9932 42 in. Plasma Television
Red light blinking
My one take too long to turn on, relay/green light on and off for hours before it can start, I use a hair dryer to heat it up everytime, aim at the center from top, then it turn on very faster, no need to service
Feb 28, 2008 | Philips 32FD9954 32 in. HD-Ready Plasma...
Phillips tv 32pw9544
it is 100% sure that your tube is ok.
there are few problems in different section like
  • sound section for no sound
  • video & crt base  due to low light in picture.
  • red video output circuit.
  • though problems are very easy & can be fixed at your house.but you need skilled technician.
Oct 16, 2007 | Televison & Video
2 year old Phillips 42" Plasma TV won't turn on
Hi I had exactly the same problem, bought the above parts off ebay. The above solution worked and tv back to normal. the soldering is a bit tricky and there is a lot of screws holding the back on!
Sep 13, 2007 | Televison & Video
Philips 32PW6006 32" TV Logo
338 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
