Question about Zenith C27A24T 27" TV
Zenith SL2773W problem
I'm hoping my ailing Zenith SL2773W is similar to the C27A24T. It no longer responds to commands from the remote. As the TV failed, the picture became obscured with a large, dark, rectangle. For a while the dark rectangle could be dispelled by pressing the PIP key on the remote, but the dark rectangle continued to return. The TV now starts normally with the front panel controls, but after a half-minute or so the dark rectangle appears.
  • 398 Answers
The dark rectangle appears because you have the closed captions on and set to TEXT. Closed captions set to CC1 puts the words on the screen and TEXT puts a black box on the screen. Go into the menu, navigate to the page with closed captions and set your captions to OFF.
Posted on Aug 13, 2007
Need cods for a universal remot to a zenith tv
  1. Manually turn on the tv.
  2. Hold code search button until the red light stays on.
  3. Press and release TV button-the light should blink
  4. Enter one of the following codes: Phillips Universal remote Codes-713 502 606 409 710 701 507 714 405 712 015 916 008 002 115 224 324 126 326 826 228 430 632 435 437 903 407 OneForAll Codes- 0017 0463 0178 009 With a valid code entry, the light should turn off.
  5. Press channel up button. If the tv responds, the code worked.
If some functions (like mute or menu) dont do what they should, try a different code.
Good luck.
Sep 28, 2011 | Zenith C27A24T 27" TV
Zenith C27A24T 27" TV does
Greetings - You need to have you DVD player hooked up to the video inputs - See below. Don't mind the mouse scratch out lines. The Device on the right represents your DVD player.
You then have to choose video as your source on the TV (not channel 3 or 4) using your remote - see below.
You should be good to go.
Enjoy your movies,
Mikeywaf
May 22, 2011 | Zenith C27A24T 27" TV
Need the code for the remote to controll a zenith tv
Try one of these, 001,004,089,099,105,177,197,200,017,092,016. ..hope this helps..
Mar 19, 2010 | Zenith C27A24T 27" TV
27 inch Zenith TV Vertical too big
If you are using a DTV coverter box, you may have changed the aspect ratio with your remote control. look for a button marked "aspect" or "picture size" use that to change size.
If you have a cable box, you may have a similar button.
Or you may find a picture size adjustment on your TV remote.
If you do not have "aspect" button on your remote try going to set up menu and look for picture size.
Older TVs used to have a vertical size adjustment at the back. look in the manual.
If none of the above, you have a biiger problem with the TV internal parts needing attention
Mar 03, 2010 | Zenith C27A24T 27" TV
Zenith sms1324s doesn't exist on universal remote codes pages
You can buy a suggested substitute (original no longer available) here:
Zenith substitute remote
I wish someone would bring a suit against any of these manufacturers using the term 'universal.'
At best, they are 'multibrand' and, with the proliferation of 'brands,' there never will be one that can rightfully claim to be 'universal.'
Dec 09, 2008 | Zenith C27A24T 27" TV
Old zenith sytem 3 tv not responding to dvd player
yes you need an RF modulator or vcr of cause
Jun 20, 2008 | Zenith C27A24T 27" TV
Power Button
there is a line fuse inside the set should be a 4 amp, could be blown and if it would blow again you have a short on the board. (if u r to try it don't forget to unplug tv!)
Oct 29, 2007 | Zenith C27A24T 27" TV
My tv will not turn on.
First of all, forget about the remote and see if the TV functions normally using the buttons on the front of the set itself. If the TV will not power on with the power button on the set itself, then something is wrong inside the TV. If the set works fine from the front buttons but no longer responds to that remote, then the remote has either gone bad or was accidently set to a different brand. In this case, look for the original book that came with the remote (or TV if it is the original remote) and follow the instructions for setting the remote back to Zenith. Try that and post your results here.
Aug 09, 2007 | Zenith C27A24T 27" TV
Zenith C27A24T 27" TV Logo
109 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
