Question about Panasonic PV-V4022 VHS VCR
PANASONIC PV4022 When using the remote on the VCR, there is a button called "add/delete". When the button is pushed, the channel showing on the face of the VCR no longer is deplayed and therefore can not be recorded. How do I get the channels back that have been deleted? Ex: The channels on the TV run from 1 to 95, but the VCR shows 1-15 and 22-95. How do I get back channels 16-21?
    Novelist:
    Champion:
  • 254 Answers
One way is to manually select the missing channel with the numeric keypad, then push "add." There is also an auto program function puts the VCR into a search mode, adding all channels where a good signal is found. Early VCRs (like late '80s or so) did not have this auto mode, but many later ones did. Also, make sure your VCR is set to the "cable" or "CATV" mode not "off-air" Do you have the VCR manual? If not, recheck your model and see if Panasonic has it online at http://service.us.panasonic.com/OperMan/Default. aspx I looked at at a manual for a PV-4651, and it showed functions which sounded similiar to what you need. Check pg. 10-12
Posted on Aug 13, 2007
  • Merwyn Bolles
    Merwyn Bolles Aug 13, 2007
    Oops! After looking again at your problem, the model number is PV-V4022. Panasonic shows ithttp://service.us.panasonic.com/OperMan/...
    Yes, your VCR does have the auto channel programming function.
How to add channels
Try doing the auto scan first to get all the possible channels.. Usually the Add/Delete function applies once the TV knows what channels are out there to add or delete.
Jan 23, 2018 | Emerson EWC1303 13 in. TV/VCR Combo
What buttons do i press to add/delete channels on emerson tv model# EWC1304? I cannot seem to get pass channel 2. I have no remote.
I have the same problem, my tv will not allow me to change channels but will only let me add/delete the channel the tv is currently on
Oct 11, 2011 | Emerson EWC1304 13 in. TV/VCR Combo
I HAVE A QUASAR VV2008 TV/VCR COMBO AND I DONT HAVE REMOTE AND CANT GET TO NO CHANNELS EXCEPT 60 AND LINE
The remote model number for the Quasar VV2008 is VSQS1570 and can be ordered from Panasonic at 1-800-221-7262 or Go to a Family Dollar store and purchase the grey RCA universal remote for $6.00 about 6 inches in length. When you are ready to program it for the Quasar VV2008 push the code search button then the VCR button and enter 0162 then push enter. The red light should go off and the remote should turn the TV/VCR off and on. It worked for me 4/19/2013
Apr 12, 2011 | Quasar VV-2002 20 in. TV/VCR Combo
I have a 1990 panosonic tv vcr combo,I have the remote but can't seem to add any channels above channel 13.model is pv-m2028-k.the remote has add /delete button and I can delete a channel and add it back...
No,all CRT tvs can't get digital signal,all CRT require a digital converter box,if u don't have pay tv.Yes the converter box hook up it getting the digital signal from the box,not the Analog tv.
Mar 13, 2010 | Panasonic PV-C1323 13 in. TV/VCR Combo
Ilo tv shows no tv signal, I believe that the channels are deleted but don't know how to add the channels back
Here is how to try and get them back if they are available.
On the original TV remote do the following-
1. Press the MENU button
2. Use the channel down button to select channel set
3. Select channel add/delete
4. Press volume up
5. Select channel you want to add by using the channel up/down buttons on remote.
6. When you get to the channel you want use the Volume up button and the color of the channel number should become either blue or green if it is added and it will be red if it is deleted.
7. Repeat until you have added all the channels you feel you are missing.
8. Press MENU button to exit.
If the channels are still available this should get them to return. If not contact you cable provider to see if they have moved some of their channels recently or check their web site for the current channel line up.
Good Luck and please rate this solution....
Jan 08, 2010 | iLO IWT3206 TV
Emerson TV/VCR Combo mODEL ewc1303/a
You have built-in features that correspond between the TV and The Hand held controller designed by Emerson. Universal remotes are lacking some features that are necessary for full function of the TB. In your case, you may be required to replace the hand held unit with another exactly alike and with all of the functions you are accustomed to.
Feb 04, 2018 | Emerson EWC1303 13 in. TV/VCR Combo
Remote control for panasonic
I unplugged the unit. Replugging it fixed the problem, And it's an e46.
Jan 13, 2009 | Panasonic DMR-ES46VS DVD Recorder/VCR
Panasonic NV SJ205 changing RF settings
Your VCR has input to record video-audio signal. Here is 2 options to record program in vcr.
1= You need to hook up video-audio cable at Monitor Out in TV and video-audio in at VCR. select Line-1 or Line-2 (where you hook up cable) in vcr and insert cassette with Record Tab intact, VCR is ready to record TV program. select desired channel on tv and hit record button of vcr, recording will start.
2= Plug RF antenna / cable wire in RF In of vcr and tune desired channel in vcr (get help of vcr's user manual for that) and push record button to start record directly in vcr.
Have further query, let me know please.
bye.
Sep 09, 2008 | Panasonic NV-SJ205 VHS VCR
Panasonic NV-SJ205 Changing Rf ?
ok. This is a really easy one.
All you have to do is hold down the menu button on the remote control for more than 5 seconds, If that doesnt work hold down the power button on the remote control for more than 5 seconds. If that doesnt work hold down the power button on the actual vcr unit for 15 seconds. The first method should work for Panasonic's fine.
This will then display your current rf output.
You can then change the output by using the up and down arrows or the channel up and down button on your remote or the vcr unit.
Press menu button to save or the same button you used to bring up the rf opposition eg power button on remote or the unit.
all the best. Top tech
Sep 02, 2008 | Panasonic NV-SJ205 VHS VCR
Lost the remote, manually need to access Menu button
VCRs since the early '90s have limited function with the machine located controls, and a remote is necessary to get into most setup options, probably including the channel add/delete. Many VCRs do have an auto program mode which searches for active channels, but I'd guess this also is activated via remote. A universal remote which specifically has the capability of performing the advanced functions is probably available. Look here for an exact http://www.electronicadventure.us/panasonic.htm Part number is VSQS1418 according to this site for PV4501.
Aug 27, 2007 | Panasonic PV-7661 VCR
Panasonic PV-V4022 VHS VCR Logo
191 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
