Humidifiers
Problem for Humidifiers
Generic problem for all Humidifiers
NEED MOTOR, EATON 416 025 20 FOR SEARS FUR...
By lenny061936 on Mar 17, 2009
motor is dead, need replacement
Same Problem
Apr 12, 2009
-   I have the same problem. I have checked all aspects of the humidifier, including the power up to the motor. Everything checks good, but the motor no longer turns. Sears claims the part no longer exists.-   FD Chief
Solution #1
posted on Nov 03, 2009
Not Rated)
UJBups
Rank: Apprentice
Rating: 0%, 0 votes
It`s pretty expensive but Appliance Factory Parts has the same motor except at 24 volt and you have to use the gear from your old unit and a step down transformer..as yours is 115 volt..
Around $80 as they will combine the shipping if you call them..
Local electric motor shop repaired my 1994 motor for $35 after I explained to them I could not find a replacement..
I talked to Sears repair service man, he said our units are too expensive to produce today but are better than these new high flow models they use allot of water that just goes down your drain..
Was this helpful?
Yes
No
Popular Solutions for Humidifiers
Questions and Unsolved Problems for Humidifiers
Answer
I have a Lakso model 110 humidifier that needs a filter. Can you advise me where I can find... (More)
Answer
Hi, Could anyone please recommend filter free cool mist humidifiers (3-4 gallon). I am sick of... (More)
Answer
solenoid valve turns on whenyou put control on test but doesnot anyother time. control panel just... (More)
Answer
I need a float valve button DLHorjus says she has 4. how do I contact her
Answer
valve makes a loud clicking noise and activates over and over again
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Humidifiers:
Top Humidifier Experts
Rank: Guru Guru
Solutions: 1582
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Humidifier Experts
Top Air Conditioner Repair
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
