Question about Samsung ML 2010 Laser Printer
Samsung ML-2510 will not print from MAC OS on Macbook
I have gotten this to print from the PC side, but it will not print from the MAC side. The software is installed. When I ask it to print, the light on the printer starts flashing and then the job stops. I am printing from Firefox. I just tried it from Word after deleting the other documents. It told me there are stopped jobs and I told it to go ahead anyway because I had deleted the stopped jobs. It seriously tried to print, whirring and flashing, but then the job stopped again. More than that, as others have said, it looks like it has not really let go of the stopped jobs, although they are no longer listed. This is pretty maddening!! Hope someone has an idea. I did use the CD to install the printer, although, and this may be relevant, I tried it first without it. Thanks steinph
  • Anonymous Sep 04, 2008
    I have the same problem the driver version is 2.0.4
I had the same problem and found the solution on the Apple discussion boards. Apparently, OSX 10.4 installs the printer as a Lexmark 510 series, not a Samsung ML-2510.
Just add a new printer and change the type from Lexmark 510 series to ML-2510 series.
Worked a charm for me!
See: http://discussions.apple.com/thread.jspa?messageID=5955598
Posted on Jan 16, 2009
Hello, I have tried the updated printer driver for the Samsung ML-2510. It still would not print from my mac mini. However, with the appletalk advice that you have suggested, it works fine. Many thanks! ASharma
Posted on Aug 26, 2007
Hi I finally called Samsung. It turns out that there is an updated printer driver for OS 10.4 and that is the reason it would not work. They talked me thru the download and after we went in circles a few times it worked. Thanks!!!!
Posted on Aug 14, 2007
    Novelist:
    Scholar:
  • 114 Answers
I am assuming you are connecting over your network (you haven't said) and if you are you may well find that the only way for you to use this printer with a Mac is to connect it via Apple Talk. we'll get to that in a moment but always start with the simplest answer first so go back in to the print queue and make sure the middle button says "Stop Jobs" if it says "Start Jobs" you need to click it. Next, From finder click Go, then click Utilities, then double-click Printer Setup Utility and see what printers are listed and what printer is set up as the default (the one in bold), next click on the Samsung printer and click Get Info. From the Info panel's pull-down list select Printer Model and check that it is using the correct driver, you should have a pull-down list of available drivers. If non of this helps you may well find that setting up the printer using AppleTalk resolves it. As old and dated as AppleTalk may seem it is the only way to connect to several laser printers, especially if you are sending PostScript jobs. Start by opening System Preferences and click Network, next double-click the network device you are using and click on the AppleTalk tab, now select Make AppleTalk Active and make sure that Configure: is set to Automatically. Now delete the printer from Printer Setup Utility and click Add Printer, you should now see both the original printer and a Samsung AppleTalk printer listed so select the AppleTalk printer. That should be all the work that is required to set this up, now all that you need to do is test it. Post back if you need anymore advice on this.
SOURCE:
Samsung ML-2510 Printer will not work with Macbook Pro - OS X
try to use the Generic drivers and not the Samsung ML driver for your model. In the drivers list type in GEN and it'll show up.
Dec 12, 2009 | Samsung ML-2510 Laser Printer
Cannot print on new Macbook with Leopard Mac OS - need driver
I just upgraded to snow leopard and my previous driver was erased, so I did some digging around and found the right driver (it is not included even in the most recent GutenPrint software).
Look at the Global Samsung website - the US Samsung site does not support MacOS drivers.
http://www.samsung.com/download/FileView.aspx?cttfileid=213919&type=Printer&typecode=15&subtype=Laser+Printer&subtypecode=1501&model=ML-1430&filetype=DR&language=
Your OS should ask to install Rosetta to read the file (Zip), but then the install is quick and easy. The printer driver immediately showed up in the printer>setup>driver menu. Prints without a hitch.
Haven't booted my laptop into 64bit kernel, so I don't know if the driver is 64bit compatible - I expect not. Hope this helps.
May 31, 2009 | Samsung ML 1430 Laser Printer
This printer has problems with Leopard last updates.
Contact Apple to see if a patch is available to run the printer on updated Leopard:
Apple - How to Contact Us.
Regards.
May 23, 2009 | Samsung ML-2510 Laser Printer
Driver for Samsung ML-1640 for WIN98SE
I got the same problem. It seems they did not develop specific drivers for win98se. However, I found that you can print using the drivers for the old Samsung ML-2510. Win98se drivers for that printer can still be downloaded from Samsung website. I've been using the 2510 drivers with the 1640 printer for a couple of months, and worked fine so far. It seems very little change in electronics from the 2510 to the 1640 model.
You need also Virtual Printer Port for USB from microsoft.
Jan 07, 2009 | Samsung ML-1640 Monochrome Laser Printer
Hi, sorry to hear you are having problems,
OK, first of all, you can stop worrying about solution #3, this printer is a USB or Parallel, there is no networking on this printer so no possibility of an AppleTalk connection.
You say you have downloaded the latest version of the driver from the Samsung website.
And, the Mac is connected DIRECTLY to the printer via USB.... ( It won't work if it's connected to a PC and then shared.. well it might work but I have not been able to make this kind of connection work...)
Well, if this is the case and you are unable to print while the PC prints fine, I expect that it is over the Parallel port or do you plug and un-plug between the Mac and PC...
It might be that the printer needs to reset after switching between the Mac and the PC, Shut off the Printer, I mean really, shut it down, unplug it for 30 seconds then connect it to the Mac and restart the Mac and start up the printer....
If it still does not work, do you have another Mac you can connect to for testing?
Also, the first test should not be FireFox, open the Text Edit app and type ( TEST ) and just print that...
Give that a whirl..
Dec 22, 2008 | Samsung ML-2510 Laser Printer
I had the same problem and spent some time trolling the Net. But....I found it.
Run installer from CD.
Tthen go to system preferences > print and fax
Delete the ml-2510 by clicking the minus square
Click the add square..
Select the ml-2510 again, and make sure that at the bottom of this window, under the "Print Using:" field, you again select the ml-2510.
Click add.
That's it! You're good to go!
Aug 05, 2008 | Samsung ML-2510 Laser Printer
Samsung ML 2510
It could be a transfer roller thats worn out.
If can be fixed by a technician.
Jun 14, 2008 | Samsung ML-2510 Laser Printer
How to print from DOS?
type
prn and then the file location
you will be able to get printouts from DOS
Jun 09, 2008 | Samsung ML-2510 Laser Printer
Samsung ML 2010 Laser Printer Logo
4,068 people viewed this question
Top Samsung Office Equipment & Supplies Experts
HEMANT GROVER
Victorman
Victorman
Steve Allison
Steve Allison
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
