Question about Toshiba TheaterWide 62HM94 62" Rear Projection HDTV
Toshiba Theatrewide I turn the set on and get sound and no picture. The red power light is on steady. I don't know where it start. I'm a certified computer tech, certs from all the OEMs, but no television experience.
  • Sjobie Aug 25, 2007
    The actual Model# for my set is 51H83. I got a service manual for it but it doesn't cover lamp removal or replacement. I appreciated the answer that was given, but wanted to be sure if the answer was correct for my model. I do think it is the lamp and will pursue that course. Any additional info would be greatly benefitial.
    President:
  • 3,130 Answers
If the light is on a steady red, thats an indication that the lamp is bad, or the lamp circuit is bad. If you replace the lamp, and the set still does not come on, this is going to be a tough one if you are trying to trouble shoot it without a manual. You can get a manual here http://www.servicemanuals.net/results.aspx?type=SM&brand=0&model=62HM94e Start with the power supply, and see if the regulator is working. If so move on to the lamp ballast circuit. If you need an owners manual, you can get one from here http://www.tacp.toshiba.com/tacpassets-images/models/62HM94/docs/62HM94_om_e_rev1.pdf Good Luck
Posted on Aug 13, 2007
  • 1 more comment
  • Larry  Dillon
    Larry Dillon Sep 04, 2007
    If you replaced the lamp and the set still does not work, return the lamp and get a replacement. If that lamp does not work, then you know you will have to search in another direction. Good Luck.
  • Larry  Dillon
    The service manual does not cover the lamp replacement but the owners manual does. You can download that for free from Toshiba athttp://www.tacp.toshiba.com/tacpassets-i...
    It is in chapter 11 on pages 98 through 100.
  • Larry  Dillon
    OH man, I know now why you cannot find the lamp for this TV set. I just realized your model still uses picture tubes. You have to be careful when you post the model number. I just saw your real model number, the 51H83. There IS no lamp inside this TV set. Three picture tubes yes. Now on this TV set, the reason you have no picture is the set lost the vertical sweep and the set automatically shuts off the voltages to the picture tubes to protect the lamps. I have seen the vertical output IC cause this problem, I have seen the Capacitor in the sweep power supply that feeds the voltage to the vertical out put IC, and I have also seen the convergence IC cause this problem. The set you first mentioned is a DLP set, you do not have a DLP set. You have convergence adjustments and a magic focus to adjust the convergence on the TV set. A set that uses a lamp does not have convergence alignments my friend. I am glad I cleared this up.
Set is getting power, but no sound or picture. we purchased it black friday
Power supply issue such as bad caps etc. But need the model number of the set in order to assist further.
Feb 08, 2012 | Hisense Televison & Video
Toshiba 57H81 Blinking power light
Greetings,
Power supply cannot sustain / provide juice to the whole system.
If you are qualified to do electronics, check the power supply section, otherwise contact a repairman.
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Jun 29, 2008 | Toshiba 57H81 57" Rear Projection...
Flashing Power light
Ur power board ic inverter is dead.
U need a new board.
Aug 19, 2009 | Toshiba 57H84 57" Rear Projection...
The tv seems really dark.57in theatrewide hd toshiba
Go into the tv menu and select the Preferences menu and set your picutre preference from Theater to Normal. The TV is currently in Theater mode, wich is for viewing with no lights on in the room. Switching it to normal lightens the pictue a lot.
May 27, 2009 | Toshiba 57H81 57" Rear Projection...
Toshiba TV stuck in TheatreWide mode
One fo the simple answers is if you have any of the new energy saving lamps (PL Lamps) is if you have one within 10 feet of the tv, the light inhibits the ir siganl.
Turn off your lights and see.
Hope it helps
Apr 03, 2009 | Toshiba 34HF81 34" TV
Toshiba 57H81 Flashing Red Power Light, Blown Fused F850+F852
Solved by resoldering some solder joints!!!!!!!
Toshiba Model 57H81 Rear Projection TV - Purchased 11-09-2001
Problem: Toshiba 57H81 Flashing Red Power Light, No Picture/Sound, Blown Fuses F850 + F852
Symptoms January, 2009:
  • Upon turning on set I got flashing red power light and nothing else.
  • Removing plug for one minute and plugging in results in:
    • Audible click, steady red power light for 2 seconds then slow flashing red light
    • Pushing power button results in steady red for about 2 seconds then slow flashing red light, no other set activity
  • Removing power cord for several hours and plugging back in made no change
    • Audible click, steady red for about 2 seconds then slow flashing red light
  • Possible related note: Over past several months occasionally the entire screen would flicker momentarily and at other times be problem free for weeks.
  • Fuses F850 and F852 found blown
Repairs Made:
  • PD0074 DEF/CON Power Board
    • There are two main power supply capacitors in this set. They are C-809 and C-810. One their negative lead on the printed circuit board re-soldered leads and nearby contacts. I’m told that because the factory left out a printed circuit board eyelet, the connection will come loose over time. When I called Toshiba customer service they said there was a known solder joint problem causing blinking red light.
    • Replaced blown fuses F850 and F852.
      • I actually installed a fuse panel on the inside of the cabinet and routed the fuse connections here instead of ordering the special fuses and replacing them on the circuit board.
      • Had to use a 5 Amp SLO-BLOW for F850. Fast blow does not survive power up. Get the red blinking light.
      • Used a fast blow 2 Amp for F852.
  • PD0073 SIGNAL Board
    • Re-soldered Q751 + Q752 STK392-110 Convergence Amps
    • Re-soldered adjacent pads that looks suspicious
Total Cost to Repair about $10
  • Twelve hours of my time over three days to research issue, disassemble set, make repairs, add fuse panel.
  • Already owned Service Manual and Circuit diagrams from a different 2004 repair.
  • Less than ten dollars at Radio Shack for fuses and fuse panel. Already had wires, etc.
  • Some solder. Already owned de-soldering tools, etc.
  • Visited both local authorized Toshiba factory service repair facilities. One said repair would have to include replacing Q751 + Q752 STK392-110 Convergence Amps with ST392-180, and realigning set for a total of $500+ and it would be more if they had to order a power board. NO THANK YOU! Other shop said $65 for site visit and $30 to make an estimate that could be applied to repair.
Jan 04, 2009 | Toshiba 57H81 57" Rear Projection...
Theatre View Toshiba Rear Projection TV 50 Inch with no sound or picture and a red light keeps blinking
I have the sames t.v you have to go in the back flip the power cord switch...then reboot the t.v.
Jun 27, 2008 | Televison & Video
Toshibe CF32G50 - Red Flashing Light
YOUR SET IS TRIPING MAYBE POWER SUPPLY IN TV SET
Jul 11, 2007 | Toshiba CF32G50 32" TV
Toshiba MD20FP3 Combo does not turn on. Help!
Not unless you have taken the time to learn all the safety issues concerning the HI voltage safety facts, in the repair of electronics? It sounds like your tv has a problem in the sweep/power supply circuits, and since these sets have NO user serviceable parts< its best too leave these types of repairs to a certified electronic technician. Good Luck
Jun 25, 2006 | Toshiba MD20FP3 Combo
Toshiba TheaterWide 62HM94 62" Rear Projection HDTV Logo
117 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
