Question about Alpine CDA-9885 CD Player
Alpiine CDA-9885 - No Audio from Ipod - Cd Playback not working
Deck installed fine and tuner audio is working My Ipod has the latest software version that Alpine says will work however the functions display but there is no audio. Cd playback does not work - unit vibrates Thanks for any help provided
Thanks so much - There was no indication of a screw on the unit from Alpine but I was looking for an insert in the cd slot for transport purposes. Thanks again I appreciate your help
Posted on Aug 13, 2007
    New Friend:
  • 83 Answers
Did u remove the transport screw?
Cda 9885, When in tuner mode sub does not play
Does you car volume get lower when you stop. If not sounds like an internal issue. No sound at all my brother hooked his up and when he switched to tuner everything would go through the subs but you would not know it sounded like his 6x9s no bass. was a wiring issue. I dont know if this helped or not.
Feb 28, 2014 | Alpine CDA-9885 CD Player
Setting up ipod to CDA-9885R
The ipod cable plugs into the rear of the stereo. Here is a link to the installation manual:
http://vault.alpine-usa.com/products/documents/CDA-9885%20OM.PDF
Aug 23, 2012 | Alpine CDA-9885 CD Player
No subwoofer with Ipod or CD but works with Radio - CDA-9885
You need to switch from the blue to the blue/white on harness...you are using the antenna turn on...which powers down when in aux mode or cd mode...
Jun 11, 2009 | Alpine CDA-9885 CD Player
How do you hook an ipod up to the CDA-9885 Alpine sterio?
Hello billybob3491,
The best way would be to add the Alpine optional proprietary iPod connection cable. This will give you full control of the iPod from the radio. Your CDA-9885 uses the KCE-422i optional cable.
The cheapest way (with lower quality audio) would be to use a generic FM modulator with a mini-jack input. The Scosche FMMOD01 shown here is sold in numerous stores from $17 - $50. Another downside with this method is that you have no control of the iPod from your head unit. But, hey! It works.
Hope this helps.
May 04, 2009 | Alpine CDA-9885 CD Player
Cda-9885 ipod not searching
I had the same problem. I got it resolved by making the MIX OFF. Just press the button number 5 to make the MIX (Random Play)ON/OFF. After the search you can set the MIX to ON. However set the MIX to off before you start any search every time.
Jan 18, 2009 | Alpine CDA-9885 CD Player
Stuck in IPOD mode
try pressing reset button ... located behind the face on the front of the radio ... after disconnecting from your ipod
May 25, 2008 | Alpine CDA-9885 CD Player
Alpine 9885 - no sound with cd's or ipod
have you fixed it yet? if not try this. your car probably has factory amplified speakers. hook up the remote wire AND the power antenna wire to the blue factory amp wire and it should work just fine
Mar 08, 2008 | Alpine CDA-9885 CD Player
CDA-9885 Alpine No audio from Ipod - CD Playback not working
Disconnect whatever is attached to the BLUE wire at the back of the Alpine deck. Re-connect it to the BLUE/WHITE wire instead. This should solve your problem.
Aug 12, 2007 | Alpine CDA-9885 CD Player
IPod will not work.
restoring factory settings won't revert the player back to previous ipod software. Check with the alpine website product support and see which ipod software versions are compatible with the car deck you installed. I would think the latest version would be supported. then go to the apple website and download the most recent version of itunes that alpine says is compatible. connect your pod and open itunes. upgrade the pod to that itunes version and try it again with the car deck.
Jul 30, 2007 | Alpine CDA-9883 CD Player
Alpine CDA-9885 CD Player Logo
194 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Jaime Hernandez
Jeffrey Turcotte
Jeffrey Turcotte
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
