Question about Toshiba 42HP84 42 in. Plasma HDTV
WHEN I TURN TV ON IT TAKES ABOUT 5-10 MINUTES FOR CLEAR PICTURE TO COME ON, MEANWHILE AN ARRAY OF COLORED LINES ACROSS TV SCREEN.
SOURCE:
chrispurs1
  • 372 Answers
SOURCE: Color line across the center of a black screen
Hi. this is caused by dry solder joints on the frame o/p IC. Resolder all legs of frame chip. Should sort that out.
Posted on Sep 12, 2007
djnick989
  • 1067 Answers
SOURCE: Vertical lines
hair line cracks in motherbord on soldering jobs look all over re soilde rthem back togther nicely
Posted on Jan 29, 2008
  • 1694 Answers
SOURCE: 57h82 toshiba projection tv
Hyper board bad = No longer available part # 23148024 PTS
rebuild only...send core in........57H82..............................T.
Part # is specific to model !....
Posted on Apr 25, 2008
SOURCE: Toshiba 27D46 Black Screen - White Horizontal Line
I fixed the problem by taking it to a repair shop
Posted on Apr 26, 2008
SOURCE: Toshiba 46In HD Rear projection TV Vertical lines on screen
We also have vertical lines with our JVC 62"... turning it off and letting it cool down is the only solution. For us, we know it's a problem with heat. We simply are wits end on fixing it. added two additional fans, a exterior fan to blow heat away from the back of the tv, pulled everything else away, etc.... Anyway, goodluck.
Posted on Apr 30, 2008
How may I fix colorful vertical lines on screen but clear voice on Sharp Aquos TV when I first turn it on?
T'Con board fault. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Aug 13, 2015 | Sharp Aquos Televison & Video
I have a 37" JVC LCD TV Model # T370HW02 and the left half of the picture if filled with vertical colored lines for approximately 30 minutes after the set is turned on then the picture clears up and s
The problem with your TV is the screen tabs this is where the electronics bond to the screen a technician may be able to fix it with compression pads otherwise it a new screen
Apr 11, 2017 | JVC Jlc37bc3000 37 Lcd Tv 1080p
Tv takes up to four minutes to turn on and when it does it has distorted red lines running verticaly across the screen
is there retrace line with red colour then off agian.if yes there is red gun problem which is shorted with ground.you have to do give another way heater ac voltages or replace picture tube.
Oct 16, 2010 | Samsung Televison & Video
Plasma "warm up" is now up to 30 minutes and climbing
put a towel across the top of the tv so it can heat up faster and you will get your picture. be carefull!!
Jan 26, 2009 | Televison & Video
Vertical color lines
I had the same thing happen to me this morning. I turned on the TV and it had colored vertical lines through the whole screen. I called Sony and they had me unplug the TV for about 15 minutes. This solved the problem. They said the boards just needed to be reset. It fixed the problem and I am happy with my Sony once again.
May 22, 2008 | Sony KDF-E50A10 50 in. LCD HDTV
Sep 06, 2007 | Toshiba 32A60 32" TV
Toshiba 42HP84 42 in. Plasma HDTV Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
