FixYa.com
Tags:
Compaq Case Cooling Fan
My Presario 700 stopped working after overheating...
posted by mrbiglove on Aug 12, 2007
My Presario 700 stopped working after overheating it now has a smel coming from it as if it has bruntout can I fix it myself and if so how ?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Aug 13, 2007
Helpful (85)
mistyman
Rank:Wiz Wiz
Rating: 81%, 272 votes
Hi, as this is a laptop computer it is not as easy to service as a desktop.
However if you remove the keyboard you will find your cpu and fan accessable from there. I think you probably have a burnt out cooling fan and possibly some damage to the cpu. The service manual is available from the HP web site and this will guide you how to remove the keyboard to get access to the faulty parts.
The question you have to ask is; is the cost of parts and down time woth the gamble for a laptop of thia age?
one idea is to check Ebay and see if you can get another one for parts.
Rating Locked! (?) mrbiglove has rated this solution as Helpful
Solution #2
Helpful (85)
fnshman
Rank:Master Master
Rating: 88%, 38 votes
It depends on what burned out. If its the power supply, then no problem, you can get an after market replacement reasonably priced. A plug-in video card is easily replaced as well. If its on the motherboard, it would depend on the part. Unfortunately when something on the motherboard overheats, there's no guaranty that you won't have problems with the operating system freezing-up on you a lot. Usable, but very annoying.
Of course you'll have to look things over closely to find what part. If the fan on the power supply doesn't come on at all, it's a good possibility its bad.
Was this solution helpful? Show your Appreciation by rating it:
Solution #3
posted on Jun 23, 2008
Not Rated (0)
altec1105
Rank:Wiz Wiz
Rating: 81%, 20 votes
I think you probaly should by a new fan they cost around $50 to $200 if you have a quad prossesor you should by a fan more expensive maby like $100 instead of $50 but if you have a dual core or single porossesor you should probaly buy a $50 doller fan and if you have a new computer it is more easy to intall internal hard if you thing your up to the task to install it your self then unplug the power and open the case up and if you thing you cant do it then bring it in to a computer repair store near you.
Can you Help with these System Cooling problems?
System Cooling
Trying to replace both the...
The easiet solution to changing... Answer This...
System Cooling
renault clio
does my clio 1.8i have a brake... Answer This...
System Cooling
relay unit
car fires up but then dies need... Answer This...
System Cooling
Warning light.
Electronic fault indicator... Answer This...
System Cooling
Peoplesoft
There are how many ways for... Answer This...
Repair Service
Find System Cooling Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
