Question about Samsung SYNC SGH-A707 Cellular Phone
Cell phone water logged
My cell phone got completely submerged in water. I got it out immediately. I dried it off, took off the back cover and removed the battery and sim. I shook it to where I didn't see anymore water coming out. Replace the battery and sim- phone turned on and acted like it was going to work. went to check my phone's address book and the phone froze, the screen messed up. I turned the phone off and let it sit for a while. I tried a little later- the screen would not come on. I tried a third time a few hours later-The phone would turn on the the screen looked fine but would not get pack the loading screen. It has been that way ever since. The initial submersion occurred a little over 24 hours ago. Is my phone a goner or is there still hope? If there's still hope, is there anything I can try or should I just keep letting it sit to dry out? Thanks
  • 3 Answers
Hi ive had alot of people ask me this question they tend to drop theres when there on hol and cum back crying to me wot u want to do is buy some distilled water take ur batt out and sim and memory card and take ur case off put it in distilled water for 5 mins take it out and dab it dry this sounds stupid but get sum WD-40 and spray inside ur fone this helps to dispell all the water thats trapped inside and leave it under a lamp with a 60watt bulb on it fo9r 3 to 4days sumtimes it could take a week try that
Posted on Aug 12, 2007
SOURCE:
How do I make my EnV3 stop vibrating?
Take out the battery and put the phone in some rice. It should help completely dry your phone out.
Dec 04, 2011 | LG enV3 VX9200 Cell Phone
I drop the movil in the water
Your best solution is to fill a small box or other container with rice, making sure that it is fully covered. Allow the phone to dry completely before turning it back on. You can also submerge it in silica packets. Be sure to act fast!
May 31, 2011 | Cell Phones
Mobile in water not working now
Remove The Phone From The Water
The first step is to remove the phone from the water as soon as possible. The less time the phone spends submerged, the greater chance it has of being saved. The plastic covers that come with cell phones do provide some protection, but it takes a mere twenty seconds or less for water to get through these barriers and start causing damage to your phone.
Once you pull the phone from the water, remove the battery immediately. Cutting power is a crucial step when attempting to save a wet cell phone. There are many circuits inside cell phones that can survive getting wet, but only if they are not attached to a power source.
If your cell phone comes with a SIM card, remove it promptly. Do not heat the card, simply pat it dry with a soft towel, and put it aside until the rest of your phone is dry and back to working order. The good news is that SIM cards recover well from water damage. If for some reason, your phone doesn't survive the accident but the SIM card does, there are plenty of places that sell unlocked cell phones. Simply place your SIM chip into the new phone and go.
Salt Water Accident
Please take note; if your phone was submerged in salt water, you must rinse it in fresh water before the drying process begins. Even after the phone is dry, crystals can form and continue to cause damage and erosion.
Let Your Phone Dry
The next step you must take to save a wet cell phone is to allow the phone to dry. A great method in providing an optimum drying environment is to set the phone on the vent found on the back of a television set or cable box. The low heat emitted will gently dry your cell phone. Another trick to help speed drying is to place the phone in a bowl of dry rice. This will help draw out the moisture. You can also try placing the phone in a plastic baggie with a few silica packs that come in purchases such as shoes and electronics. Silica, like rice, absorbs moisture.
The important part of the drying process is to place the phone uncovered, in a warm, dry place and allow the moisture to evaporate completely. Another alternative is to place the phone on an air conditioner. The cold air will not damage the phone and the air from an air conditioner is very dry allowing the water to evaporate quickly.
Drying should take approximately three days at which time you can check to make sure the phone is clean and dry. It is at this time that you can re attach the battery and check if the phone works. If it doesn't, wait a few more days and try again. If the phone still doesn't work, take it to your local dealer, they may be able to repair it. Be prepared; getting a cell phone wet will void your warranty and most cell phones are equipped with a water damage indicator so the dealer will know the phone has been H2O compromised.
Alternative Drying Methods
There is an alternative way to save a wet cell phone that includes an alcohol soak. Alcohol is hygroscopic which means that it attracts water. Soaking your phone in denatured alcohol, or a 95% alcohol solution (regular rubbing alcohol is about 75%), soaks up all the water in the phone. When the liquid is dumped out, only alcohol, which will evaporate, remains. Make sure that the alcohol you use is denatured with only methanol as the chemicals found in other types can be damaging. This kind of alcohol can be purchased at your local hardware store. The alcohol soak may work best for phones that have been damaged by salt water or other liquids such as coffee.
Battery Caution
When attempting to save a wet cell phone, make sure you do not heat the battery as it could leak or even explode. Lithium-ion batteries are especially sensitive. In addition, many cell phones have plastic parts that can melt. Above all, do not try to save a wet cell phone by placing it in a microwave. You will destroy the electronic components and possibly the microwave in the process.
The above steps will help to save a wet cell phone, but be prepared. Often the phone will survive but the battery will not and the purchase of a new one may be in order. Good Luck!
Dec 05, 2010 | Nokia 2690 Cell Phone
I went in the sea with my phone in my pocket yesterday this was yesterday is there any hope 4 my g1?
Follow these procedure to save or revive your phone, remove Cell Phone from Water: Time is of the essence when it comes to saving a fixing a submerged cell phone, as soon as you see your phone in water, remove it quickly! Every second matters do this step quick.
Saving the Battery: In order to save the battery on your cell phone after it's been wet, quickly take the battery out of the phone as soon as you take it out of the water. Buy doing this you will ensure that minimal damage is done to your battery.
Drying the Phone Out: Quickly shake your cell phone to get all of the water out and reach for the paper towels. Press down on your cell phone to make sure all of the excess water has come out. If you have accessories such as cell phone covers, take them off promptly otherwise water will still be stuck in your phone.
Saving your Info: If your cell phone takes a SIM card, quickly remove it before the phone dries. While you may still loose some of your information, you won't lose it all if you take the SIM card out of your cell phone in time
.Removing Excess Moisture: To remove the unseen moisture in your cell phone you will need to cover it with either Desiccant gel packs or rice. Desiccant gel packs can sometimes be found when purchasing brand new shoes or clothes. Make sure your cell phone is completely covered with either one of these for up to 3 hours.
Vacuuming: Take your vacuum hose and place it up to 4 inches away from your cell phone with it on. While this won't remove all of the water, it will certainly eliminate the big spots of water damage.
Turing the Phone On: After allowing your cell phone to sit a day or two with the power off, turn it on to see if it works. More than likely if you followed these steps as soon as your phone was submerged, it will cut on. If not, you will have to purchase a new cell phone because the one you have can't be saved.
Take care.
Aug 08, 2010 | HTC G1
I call have water damaged what should i do ?
Take care.
Jul 21, 2010 | RIM BlackBerry Storm 9530 Smartphone
Water damage how can i try an fix it? on a samsung gravity 2
Take care.
Jul 18, 2010 | Samsung Gravity SGH-T459 Cell Phone
I had got out the shower an water got in the screen its a black berry storm from verizon an i dont know what to do
Remove the back cover and battery. Shake any excess water out of unit. If you can dis-assemble then do it and let it air dry for a day or two. If you cannot dis-assemble it then try and use a hair dryer on it to completely dry it out. I have had a couple of cell phones that got submerged in water and once they were COMPLETELY dried out they worked again.
Sep 23, 2009 | Cell Phones
I have a Nokia N90 and it fell in a bucket of water,it submerge for about 6 secs after grabbing it out.I dried it off and imediately run a blow dryer on it,but not getting any display on screen,but it...
The best way to treat a phone after water submersion is to remove the battery immediately and allow it to dry near a radiator or other gentle heat source. Sometimes burying the handset in dry rice will speed up the drying out process.
Be prepared to take it in for repair if the above doesn't work.
If it's insured you should be covered for water damage.
Jul 07, 2009 | Nokia Cell Phones
Maybe rzr v3m; black screen after dropping phonein water
you can take the battery and the back off the device and place in completely submerged in a bag of white rice and leave it in there for 1 to 2 days this will help absorb the moisture, this should fix it if the water did not damage the circut boards if the water damaged the circut boards then the device is fried
Apr 29, 2009 | Motorola Mobility RAZR V3x Cellular Phone
Dropped the i580 in a glass of water
Put the whole phone in a container of rice and let it dry out completely.
Jun 01, 2008 | Motorola Mobility i580 Cellular Phone
Samsung SYNC SGH-A707 Cellular Phone Logo
238 people viewed this question
Top Samsung Cell Phones Experts
Felizardo Erilla
Felizardo Erilla
Bill Long
Donni Steen
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
