pls try to update the software of ur pda and see if it helps , but i insist that ur digitizer is faulty u have to get it replaced no other solution , it is harware fault u cant correct it thru software
If you have already tried the re-aligning of the touch screen, and you have failed. It is better to bring your Imate to a service tech, to check the software details of your pda.
Or if you want, try to reset it or master clear so that it will go back to its factory default.
Thanks! please rate my solution positively!
Comments:
Mar 18, 2009
- Well, I suggest that you should bring your phone to a service center, hope you still have the warranty, if not, check with them how much will be cost, if its worth rapairing or you can buy a new one.
How do I replace/change the touch screen on my I-mate JAMin. It is not cracked but it will not...
(More)
How do I replace/change the touch screen on my I-mate JAMin. It is not cracked but it will not calibrate and when you tap the screen it activates a point some distance away.
Hi, I am getting 3 bands on the screen while switching on (red,green and blue). It also has some...
(More)
Hi, I am getting 3 bands on the screen while switching on (red,green and blue). It also has some text like IPL 2.13.001 and SPL.2.13.001. Please help
Have no sound , no ringing etc. Put the headphones on and can still listen to music etc but that's...
(More)
Have no sound , no ringing etc. Put the headphones on and can still listen to music etc but that's it.
