? 4:18 https://www.youtube.com/watch?v=ZFl5o6OyUTw
Aug 11, 2013 - Uploaded by bicycledesigner
Convert your mountain bike rear disc brake wheel into a motorzied disc brake ... How To Install a 48cc 4 ...
Custom Motored Bicycles - DISC BRAKES, ROTORS, 26 ...custommotoredbicycles.com/disc_brakes_rotors_26_inch_wheels_conve...More Disc Brake Parts for Motorized Bicycles coming soon! ... This lazer cut, offset bracket fitting allows you to install disc brakes on virtually any Bicycle [without ...[Brakes] - engine kit on a bike with disk brakes ' Motored Bikesmotoredbikes.com > ... > General Bicycle QuestionsJan 30, 2013 - Hello, I'm not sure if there is a post about this or if I'm posting in the right section, but I am wondering if it is possable to mount an engine kit on a ...Install engine on a bicycle with rear disc brake. - M
There are some schemes for adding disc to non-disc-compatible frames but they're Rube Goldberg solutions. And you still need to get new wheels and new brake levers if you're going with hydraulics.
You do not say what kind of bike, speed bike?Coaster brake? hand brakes, pedal brake? If, it is a hand brake, it usually means that your wheel is bent and needs to be trued. You cannot adjust brakes with a bent wheel and you need a truing stand.. If it is a coaster brake you need you hub rebuilt as there is an part broken inside the hub.
The teloscopic forks have mounts for disc brakes so you would need forks from a bike with disc brakes and the front tire with the rotor and caliper all off the same bike so it would all bolt up. Most forks are the same diameter but measure to make sure.
I'd clean them, most disc brakes are sprayed with oil before they're shipped on the bike. So if it isn't all wiped off then the disc/pads start to collect dirt and dust which can cause a squeel. Clean your pads and your discs and see if that helps.
