Question about KitchenAid KESS908SPB / KESS908SPW Electric Kitchen Range
KITCHENAID KESS908SPW ELECTRIC RANGE
I just installed a new Kitchenaid KESS908SPW slide in electric range. I have verified the voltage on both legs (118vac), and the only thing that works is the oven control. None of the cooktop controls function ( the lockout is not lit either), and if you turn on the oven it doesn't warm up( I've tried bake, broil...etc...). The fan starts and the control shows that it is working, but it never warms up. I've checked the sabbath mode, the locks, the timed start, and so on, but to no avail. HELP
  • ALLDUN5 Aug 13, 2007
    According to the installation manual there is only one. It recommends the 40 amp 4 wire (used) over the 40 amp 3 wire. I will call the appliance store in the morning, and let you know what I find out.
  • ovenisbroken Jan 16, 2009
    I have the same problem! Does anyone know how to fix it?
  • 640 Answers
Are you sure the oven doesnt need 2 voltage supplies?control voltage and load voltage.
Posted on Aug 13, 2007
SOURCE:
How to level my kitchenaid stove
sounds like back legs are up too high, or front is dipping. If back legs are at the appropriate level, then you should be able to adjust the front legs. If no adjustments can be made that way, then you might have to shim under front legs. If this is a drop in stove top, then you need to pull it out of the hole, and loosen corner screws, and push top into the correct position. Don't forget to re-tighten the corner screws. Also, if this is a range and the top is not level, then you need to shift the top forward and you should feel it drop into place. There is a slot on either side of the frame that the top should slide onto.
Jan 27, 2013 | KitchenAid KDRP467KSS Dual Fuel (Electric...
My kitchenaid range KESC307HBS door will not unlock code F5 E3
Hi ad welcome to FixYa, I am Kelly
Here is the service manual:
http://appliancedigest.com/index.php?/files/file/242-whirlpool-kac-34-kitchenaid-self-cleaning-slide-in-electric-range-service-manual You have to join the site to get the manual but of all sites this one is a gold mine of information. I am sending this link now and will respond again after my almost 3 hour manual download of the manual. I have to read the manaul myself before responding. My intial thoughts are the following: Possible door lock failure, an oven sensor has failed or a high limit thermostat has failed. I will resond with the code F5 E3 data after the manual completes. Thanks for choosing FixYa,
Kelly
Jun 20, 2011 | KitchenAid KESC307 Electric Kitchen Range
Looking for temp /resistance chart for whirlpool/kitchenaid part #4455636 to verify that it is faulty
read 3 highs and 3 lows and average it out that will tell you how hot it is inside the oven
May 10, 2010 | KitchenAid KESC307 Electric Kitchen Range
Finding a replacement night light bulb for kitchenaid superba
KitchenAid KESC307
The bulb inside the oven is 40 watts appliance
You did not indicate which bulb you need but you can go to
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=251681
and click on the diagrams in the left-hand side to locate the bulb you need.
May 09, 2009 | KitchenAid KESC307 Electric Kitchen Range
Kitchenaid electric range yker1201 with f2e0 error
F2-EO indicatwes a shorted key pad. Electronic parts on ranges sometimes have warranty for five years (may only cover parts) so check your owners manual to see what your warranty is then call for service. It is a good idea to save reciepts of repair for future reference if neccessary.
Dec 28, 2008 | KitchenAid KESC307 Electric Kitchen Range
What electric voltage plug do I use for KitchenAid 32" cooktop
I would use the 220volt 60amp available at any hardware store. Just make sure you check the wall outlet you are going to use. The Dryer and Range are not the same.
Nov 03, 2008 | KitchenAid 32 in. KECC508 Electric Cooktop
KERS907 series electric ranges.
any high tech range or any appliance for that matter that is high tech has a greater risk of repairs, the smart solution is to purchase an extended warranty on the appliance so if it does need to be repaired it will not cost you any additional expense
btw kitchenaid makes a fine range
Apr 16, 2008 | KitchenAid KERA807P Electric Kitchen Range
Do they still have this stove in stock
THE MODEL SERIAL PLATE IS LOCATED BEHIND THE STORAGE DRAWER/BROILER ON EITHER THE LEFT OR RIGHT LEG OF THE RANGE.
Mar 31, 2008 | KitchenAid KESC307 Electric Kitchen Range
KitchenAid KESS908SPB / KESS908SPW Electric Kitchen Range Logo
205 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Carmen Mikulic
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
