Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet HT Front Load Washer
I am getting a F 02 error and do not know what that error code means. Washer has water in it, but will not drain. When activated, I can hear a faint humming sound. Drain hose is clear, electrical connection at the outlet is good. How do I take the back off? Any suggestions?
  • 16 more comments
  • Anonymous Nov 13, 2007
    i cannot find my book ,so i am trying to find out what error code f 02 means
  • Anonymous Nov 14, 2007
    I'm getting 11-F code problem. I do't know what the code means
  • Anonymous Jan 26, 2008
    mhagle17@aol.com My duet washer stops at the rinse/spin cycle and flashes a F02 error code. If I turn over to Rinse/Spin cycle only it will function, This does not happen on very small loads (yet?). Have no manual; washer came with house.
  • Anonymous Feb 08, 2008
    I am getting a F02 error code and do not know what this means. Also the washer will not go into the spin cycle and does not appear to be draining all the way. Makes a clicking noise when this happens.
  • Anonymous Mar 02, 2008
    Me too!  The F 02 thing first happened today and I managed to finish the partly-done load by dividing it in half and running each half on "rinse and spin".  But that didn't work for the second load, which I had deliberately made smaller, and there was a lot of water left in the barrel.  I took everything out and tried "drain and spin", but it just added water and wouldn't drain or spin.  So I unplugged it and will try some of these solutions tomorrow when I'm not tired and ticked off.
    The manual says to check if the drain hose is clogged.  How are we supposed to do that if we can't detach it from the back of the machine?
  • Anonymous Apr 02, 2008
    will not drain or spin
  • Anonymous Jun 04, 2008
    Same problem F02 error with clicking noise and draining / spinning issues...
  • dmsk Jul 22, 2008
    Same basic problem but get error code F only. Also here a clicking sound instead of hum & sometimes works fine. Checked hoses & filters to no avail & belt is fine.
  • cipriany33 Aug 27, 2008
    i just connect it yesterday, but from the firs time show the F AND H code. and every two minutes the washer stop and show that code and it is impossible to use
  • NIKAANIKA Oct 22, 2008
    I have the same problem with my washer the code f 2 , water inside won't drain . I washed a rug is this why?
  • jkcomer Dec 30, 2008
    I have a very similar problem. The F and H code flash 2 minutes into the wash cycle (basically any cycle on the left side of the dial). There is also a humm that is occuring. It sounds exactly like something jammed as you describe. However, the drain/spin, and rinse/spin modes work with no problem. (No humm in these modes) The water pumps out of the washer in these two modes fine.
  • oconnellcrew Jan 07, 2009
    same problem with the clicking
  • Anonymous Mar 05, 2009
    I had this same problem. I fixed it following your directions. I had 4 baby socks stuck in the trap! It smelled like sewage. No wonder I was having a smell coming from my machine. Thankyou Thankyou.
  • Anonymous Mar 07, 2009
    I had the same problem. Great advise from fixer444. It WAS the drain trap. Fixer444 told us exactly how to take the panel below the door off and get into the drain trap and clean it out. There was a sock in the drain trap. It was very easy.
    I have the same problem... wont drain or spin at the end... Un plugged, re set . still the same
  • Petesjunk Apr 14, 2009
    Had the same problem, cycled stopped, wouldn't spin and drain, plus there was a rotten egg odor. Fixed as described below. Found 2 kid socks, a pen and unidentifiable gunk! Super easy (20 minutes) but VERY stinky, and I just finished my first load--no problems at all!!
  • Anonymous Apr 14, 2009
    My washer started out flashing F21 and we cleaned out the clean out valve, then started flashing 5d now it is flashing f33. It sounds like the pump is working and the washer is spinning but it will not drain.
    also for those of you doing the clean out valve, I have found if you take a contractors garbage bag and wrap it around the outlet then unscrew the cap the water will go into the garbage bag and since it is a heavy duty one, it can be taken and dumped out the back door.
  • beyako May 16, 2009
    My Whirlpool Duet HT have a code --- on screen and does do anything. What I can do to start working properly
    President:
  • 331 Answers
The hum you hear is the drain pump trying to get the water out of there, but it can't for one of two reasons. 1.) It's jammed by debris (pillow stuffing material, underwire from a bra, etc...) 2.) The pump itself has failed. UNPLUG THE WASHER! You'll need to remove the three screws that are located below the bottom front panel. (Do this easily by leaning the machine backwards toward the wall and propping the 2 front feet up with a brick or the 4" side of a 2x4) These screws are star shaped, called "Torx" screws, size #20. After you have those removed, pull the panel downward and pull out from the bottom at the same time, then set the panel aside. Mounted to the floor of the machine near the center is the drain pump, see the hose coming out of the bottom of the tub and into the pump? That one will HAVE to be clamped off before you continue. Use 2 open end wrenches and a pair of vice grips... use the wrenches to pinch off the hose and the vice grips to clamp the TIGHTLY into place. Now remove the drain trap cover. Rotate the hand grip counter-clockwise several turns and pull it toward you. (*THERE WILL BE SOME WATER COME OUT EVEN THOUGH YOU HAVE THE HOSE CLAMPED OFF. HAVE TOWELS READY) Use a flashlight and your fingers to inspect the pump area, remove any debris you find. Make sure it's COMPLETELY cleared out. Then re-install the drain trap cover next remove your hose clamps. Plug your machine back in and set it to "spin only" and engage. You should hear the pump fire up and water being evacuated. Is so? You did it! Rebuild everything. Job time= ~45 minutes. If not, you have a bad pump and it should be replaced. The part # is 280187 and list for ~$115.00 at your local appliance parts retailer. Good luck! Please post back.
Posted on Aug 13, 2007
Please unplug the washer before you attempt the following ! ! !
(1) Find the three torx screws on the bottom front panel under the door (at the bottom of the washer).
(2) Remove them, the panel will drop down, you will see something that looks like a big plug or drain stopper.
(3) Unscrew it (counterclockwise) if there is water in the tub you will have a mess, so put down towels or try a small bucket. It should slide out very easily.
(4) Claim your treasure, I had a drill bit, guitar pick, $2.47 in change, several nails, a breadbag clasp, and several other items that cannot be identified.
Posted on Dec 06, 2008
Spinning like a Top again, and all thx to you, you saved me two weeks without my washer and probably over 200.00 in repair fees.  Your step by step instructions worked perfectly.  Thx. so much.  P.S.  I am single and do have a few other odd jobs around the house which I could use some extra hands.  Think about it.  ha ha
Posted on Jul 22, 2008
SolutionGuy's instructions were great and helped to solve the problem (F-02 error message). A piece of fabric and scraps of paper were caught in the pump.
Tip 1: If you don't own box wrenches, a couple of wood paint stir sticks work just as well.
Tip 2: You don't need a lot of towels if you're clever and patient when you remove the drain trap cover. Place two large sponges (like what you use to clean your car with) on either side of the drain trap cover and only unscrew the cover enough to let water out until the sponges are full, then screw the cover back on, wringe out the sponges into a bucket next to you and repeat until all the water has been drained out. This takes time, but saves the trouble of cleaning up half a gallon of water that would otherwise be flooding the floor of your laundry room.
I had to go one step further because of where the fabric was jammed in the impellor (water pump). If you can't remove the material that's jamming the impellor by reaching in with your fingers, you may need to remove the pump/impellor for easier access to the material. To do this, unscrew the three phillips head screws that secure the gray, plastic flange to the white drain trap. One is on the hidden "back" of the gray flange, but you can easily find it by feeling around with your fingers. When you remove the impellor/pump, keep track of the black, rubber "washer" that may fall off the impellor. You can now get at any foreign material stuck in the impellor. Once the area is cleared, put the rubber washer back on the pump, and put the screws into the holes of the gray flange before positioning the pump on the drain trap. Tighten the screws until they stop, but don't overtighten because you're only screwing into plastic. Now you can finish putting the drain trap cover back on, remove the clamp and restore the bottom front panel.
Posted on Dec 28, 2007
DO NOT ....I repeat DO NOT use the Purex 3 in 1 laundry sheets in these front loading machines !!!!!!!
Posted on Jul 19, 2009
I am having the same issue. Geting the F2 error and washer won't spin and drain. Works sometimes and not others. What's the issue?
Posted on Oct 23, 2008
It could be the drain hose... but more likely is the drain valve. My wife and daughter have fairly long hair... and that caused all of the problems. Fix is about 30 minutes and a little messy... Three screws on the very bottom of the front need to come off... then lift, pull and pry (grunt if it helps) from the bottom to pull the bottom cover off. Right in front is a large object filter with a removable lid. With a trash bag or cookie sheet under it, remove that lid (unscrews just like a pickle jar... tight and then bam! Your knuckles are now scuffed... or you were smart enough to wear gloves). Once that is done, you can remove the one screw holding it down and walk the back feet forward and it will come loose. Then, two hose clamps and an electrical connector need to be undone. Set all aside... Next is the drain valve... or eco valve... it's the big black elephant trunk that connects the basket to the filter. One large hose clamp needs to come off and then it comes right out. This piece will likely smell like the sewer... clean it to keep the washer from stinking up the house. Anyway, pop the teflon ball out.. there is a 1/2" by 1" opening where the hose interfaced with the basket. This opening is the "drain valve" that clogs with hair or string or whatever. Pull all of that stuff out, clean everything to your liking and put it all back together again. I prefer to use vice-grips to work with the hose clamps, but other things can do the job... The hoses are probably clogged a little... from soap scum. I took mine outside to the hose bib on the house and went wide open on the spigot and flushed them 95% clean. Works like a champ again. I would almost think all of this could be solved by running a load with drano in it instead of water... and that would save you a lot of time if you're not the "take it apart and put it back together" type. Best of luck!
Posted on Oct 22, 2008
SOLUTION GUY HAS THE BEST ANSWER! HE IS THE MAN1 FIXED THE PROBLEM IN 10 MIN. HOPE HE GETS LAID FOR HIS EFFORTS!
Posted on Feb 01, 2008
Solution Guy got it right!  And I used AKL17's sponge tip, only I used towels.  My culprits:  lint, pet hair, a paper clip, and a piece of cloth that I think was part of a dog bed.
If you have a pedestal, you don't need to tip the washer back to access the screws, but it helps to pull the drawer out.  I had a bunch of towels and packed them around the trap as I unscrewed the cap, and after I cleared the trap I used a fan to dry the inside of the washer completely before putting the panel back on (which was the hardest part, trying to hold it in place with one hand and put the screws in with the other).  I used a needle-nose vise grip to clamp the hose and it worked really well--just be sure, if your vise grip has a cutting portion, not to put that on the hose.  :)
Thanks for the tips!  Saved me a repair call and made me feel competent!
Posted on Mar 05, 2008
My whirlpool duet ht washer won't start....the power button comes on but at the settings it just flashes a green light and it won't start.
Posted on Jan 05, 2010
F-70???
Posted on Jan 01, 2010
Solution guys rocks!!!! Worked PERFECT!! Found 4 pieces of clothing and OMG did it smell like rotten eggs!!
I had a stink for 3 years in my drain tub and never knew why until NOW. The clothing peices were black as night and had mildew like a sewer. THANK YOU SO MUCH!!!!!!!!!!!
Posted on Jul 12, 2009
  • johhnyoak Jul 12, 2009
    I
I just went through the same process, but it looks like I need a new pump. HERE'S A GREAT TIP FOR GETTING THE WATER OUT FIRST: use a WET/DRY vac on the end of the drain hose to **** the water out before you begin! (Many thanks to jsrock516 for that one), Just be sure to put the drain hose back in the drain before you start the beast back up!
Posted on Jul 21, 2008
I did all of this and still had the problem. Bought a new pump. While installing it, just for the heck of it, I removed the hose connecting the pump to the washer part to see if maybe the ball was messed up. What I found was one of my wife bathing sponges stuck up there. It was blocking the water from exiting.
Posted on Jul 19, 2008
ATTENTION!!!
PLEASE UNPLUG YOUR EQUIPTMENT BEFORE MAKING ANY REPAIRS.
THANK YOU.... LEFTY
Posted on Jun 10, 2008
Right on the money i did things a little difrent i used a turkey baster to get out the water nothing on the floor tilted back as far as i could thank you for the help
Posted on Apr 27, 2008
Same problem...took the pump assembly apart and found the metal cylinder is starting to breaking apart(is this normal). Is there any way to just purchase this part instead of the whole assembly?
Posted on Apr 08, 2008
Rock and Roll Solution...literally, one of my wife's flat rocks (Azurite) was gettin' in the way of the impeller suction hole. This was just great. I buy the beer if you're in the neighbourhood.
Posted on Feb 29, 2008
Awesome step by step instructions! It worked perfectly and so does my washer now! Thank You.
Posted on Feb 05, 2008
Wow, great instructions! My husband and I were able to remove the sock causing the problem and the washer works great!! Thanks!
Posted on Nov 11, 2007
3 Suggested Answers
Astrobyte
  • 110 Answers
SOURCE: Whirlpool Duet HT Front Load Washer
F 02 does indicate a drain problem. You can see some troubleshooting steps here.
Good luck, and let us know how it turns out!
Posted on Feb 23, 2008
maklean
  • 1665 Answers
refer to user manual (page 5-11) at link below:
“E2” flashes if the thermistor has shorted.
See “Thermistor Test” on page 5-5.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/cdce3c10dcb5382285256aa20064beaa/$FILE/Duetdry.pdf
Fh error code wirpool duet washer
Display shows F20 or FH - Front-load washer ' Whirlpool ...
https://www.whirlpool.com/...fh-front-load-...
Whirlpool Home AppliancesQuestion: Display shows F20 or FH - Front-load washer. Answer. Image. or. Image. or. Image. This error code indicates a water supply problem. Are both the hot ...
whirlpool duet error code FH - Appliance Repair Forum
forum.appliancepartspros.com > Appliance Repair Help > Washer Repair
Jan 5, 2009 - 10 posts - ‎1 author
... Repair Help > Washer Repair » whirlpool duet error code FH .... FH No water detected entering machine or Pressure switch trip not detected. Whirlpool Duet diagnostic code C:03 error code FH
1 post
Dec 5, 2014
Whirlpool Duet Washer HF Error Code
Jun 10, 2013
FH Error Code on Whirlpool Duet Washer
Mar 11, 2013
FH error code
Sep 13, 2008
More results from forum.appliancepartspros.com
Stumped on error code FH for Whirlpool Duet front load washer .
Jan 08, 2016 | Washing Machines
Feb 23, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool front loader duet hd washer gets stuck in the wash cycle with the error code of F02. What is F02 mean?
Whirlpool Duet front-load washer F02 usually means it is taking over 8 minutes for the washer to sense that the rinse or wash water has drained, which either means that the drain/filter is clogged or the pressure switch/tube is clogged (causing both the washer to over-fill with water and not sensing that water has drained).
To clear out the drain/filter, tilt the washer backwards a little for easier to the kick-plate and support the front bottom with a wood block or similar, remove the front kick-plate's (3) retaining screws and swing the kick-plate up out of the way. The filter drain is behind the white knob in the center, be prepared with something to catch any remaining water and lots of towels to soak up any spills, and turn the knob counter-clockwise to remove the filter.
Jan 11, 2013 | Whirlpool Duet GHW9150P Front Load Washer
My washer is displaying an "F02" message. What does this mean?
If the drain time exceeds eight minutes, the water valves are turned off
and “F/02” is flashed. Press PAUSE/CANCEL two times to clear the
display.
NOTE: After four minutes the “Sud” error will be displayed, then four
minutes later the “F/02” error code will be displayedfc2323f.jpg3830f06.jpg 600f261.jpg
Your tech sheet? GHW9150PW0 Tech Sheet # 8182277 Rev #
Duet service manual and codes
Rate it or hate it:
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Sep 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Get code 02 F - what does that mean?
Hi
Thanks for using FixYa. F/02 error means Long Drain. If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed. Press PAUSE/CANCEL twice to clear the display.
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the electrical connections at the pump and make sure the pump is running.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 22, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My Whirlpool Duet front load washer is giving a F 11 error.
power failure--------unplug the unit for 5 minutes and see if it clears that code
Jul 26, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Getting a H then a F error when the washer is washing a load.... I ended up turning it off. I've also received a F 02 error and a SUD error.
Hello, the H and F error means no water is detected entering the machine or the pressure switch trip is not detected. If the control has turn the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valve will be turn off and the error code will be display.
So try the following steps
1. Check drain pump operation
2. Check the pressure switch hose to see if it's in good condition and properly connected to tub and pressure switch
3. Check is it is not a siphon problem
4. Check wire harness connections to: inlet valves, pressure switch, drain pump,flow meter, and central control unit(CCU)
5. Check all hoses for possible leaks
6. Check pressure switch operations
7. Check flow meter operation
8. Check CCU operation
F-02 ERROR: Means "Long Drain" that is if the drain time exceeds 8 minutes, the water valve are turn off and F-02 is flashed. Check the following
1. Check the drain hose and make sure it is not plugged kinked.
2. Check the drain pump filter for foreign objects
3. Check the electrical connections at the pump and make sure the pump is running.
And for the SUD error means after 4 minutes of the draining process the "sud"error will be display and 4 minutes later the F-02 will be displayed. So apply the solution for the F-02 to these.
Thanks
Jun 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Duet GHW9150P Front Load Washer: My whirlpool duet ht washer shows an L20 error mes...
L20 is not a valid error code.
Unplug for 40 minutes and re-try.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 17, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F-02 error code on whirlpool front loader duet
http://www.fixya.com/support/r3574284-checking_the_drain_pump_on_a_front_loader
May 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
5,787 people viewed this question
Sal De
Marvin
Marvin
jimorris77
