Question about Panasonic PT-47WX49 47" Rear Projection Television
47 inch Pabasonic Project T.V.
After a few seconds after I turn the tv on a black square appears on the screen. The black square disappears when i make an type of adjutment ie raise or lower the volume. What could be wrong with this TV
  • turiluna Aug 12, 2007
    WoW! That was too easy. Only if everything else could be this easy. Fixya worked for me!
    Genius:
  • 1,153 Answers
This could be part of the text mode, which has to do with the caption. Check and see if it's turned on.
Posted on Aug 12, 2007
SOURCE:
A black square appears on the screen several seconds after turning on. It disappears after changing channels but reappears soon after.
Check your TV settings under Caption, odds are someone adjusted the captions to text1 or 2.. the box should go away after you change that to off or std cap.
Aug 07, 2010 | JVC TM-2703SU 27" TV
How to fix TV
I have a large black square obscuring the picture. You can see the picture in 1 inch border around the black square. If I reset the input switch, the black square disappears for about one second (the picture is momentarily perfect) and the black square appears again. It is not the cable box because I wired the cable directly into the tv. The same thing happens when I try to play a DVD. Any insights????
Mar 08, 2009 | Mitsubishi CS-35305 TV
Picture trouble
Good Day, britt93;
It sounds like you have the TV's CLOSE CAPTION on; in the text mode, turn off and you and the TV will be fine.
Good Luck, big IRISH.
Aug 21, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Black square on one channel
that's a picture inside a picture option, and it sounds like the inside picture is set for a blank channel...just go to the menu, and shut off the picture in a picture option..should do the trick..
and keep the kids away from the machine
May 24, 2008 | Insignia IS-LCDTV32 32 in. Television
Black square covers the center of the screen-
the closed caption is probably on. look on your remote or in the tv menu for cctv and change the setting. there are at least four different types of cctv and you may have to cycle around some to find "off.
Apr 29, 2008 | Toshiba MV19N2 19 in. TV/VCR Combo
Black square covering up most of the screen
Try goeing into your Menu and see if you have the closed Caption on that will produce a black box on the screen if you have the owners manual look in there,if you don't have it you can go on line and download it from the manufactures website under Downloads Good luck Walter Grzybowski
Sep 17, 2006 | Philips 60PP9202 60" Rear Projection...
Panasonic PT-47WX49 47" Rear Projection Television Logo
43 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
