Question about Alpine CDA-9826 CD Player
No sound (Alpine CDA-9826)
When I put a cd in my radio, the amp stops playing. When the cd is removed I get full sound again. Is the radio shot?
  • Qdawg 4 Aug 12, 2007
    I don't recall a big bump. Nothing has been unplugged. Is the problem worth fixing?
    You are the bomb!!!! That was it. Thanks
    Problem Solver:
  • 10 Answers
Is this a new installation or did it just start happening without anyone changing any wiring? If it is a new installiation make sure you have the remote turn on connected to the remote turn on wire from the radio(blue and white) and not the power antenna wire (blue). The blue wire will turn off when you switch to cd while the blue and white will not.
Posted on Aug 12, 2007
    Genius:
  • 1,153 Answers
No it sounds like a problem with the cd mech. was there a large bump to the player are maybe the mech cable been unplugged. Or the laser has a problem with the sound portion.
SOURCE:
Mp3 and radio search problems
OK you have mistaken this player for a player you can plug in an MP3 Player into .....This is an MP3 player that plays MP3 CDs you burn off your PC ... so it will only play MP3 CDs!!!
about search problem I don't have a fix but just manually adjust stations then program them to your buttons.
Oct 01, 2009 | Alpine CDA-9826 CD Player
Alpine cda 9884 has no sound in cd or ipod mode
actually, chrysler/dodge has factory Infinity sound systems installed. The nice part about these systems is that you dont have to bypass the amplifiers in order to put a new radio in, but simply power up the amp by hooking up the amp turn on wire at the harness. The alpine should have 2 blue wires coming off of the back, one that is solid, the other with a white stripe. The one that is solid only has 12v when the fm/am radio is on (used for power antenna) but cuts off when other sources are used (cd,aux,ipod). My guesses are, you have the amp wire on the vehicle harness (blue) tied into this wire, instead of the BLUE/WHITE wire on the alpine which has 12v as long as the radio is on. i hope this solves your problem, 9 times out of 10 on a chrysler this is it.
Auto Tech
DA2 (Supa)
Jun 07, 2009 | Alpine CDA-9884 Car CD/ MP3 Player
Alpine cda-9853 no CD audio
do you have an amplifier powering your speakers? if so make sure you have the correct remote wire and not the auto antenna wire
Sep 15, 2008 | Alpine CDA-9853 CD Player
CDA 9885 No idea why it suddenly stopped working
It sounds like you have a bad ground connection. You need to take the radio out and check all the connections. I bet you have a loose one somewhere. That is what the problem was with my bronco
Sep 08, 2008 | Alpine CDA-9885 CD Player
CDs and Ipod wont play with Alpine CDA-9885
The Alpine has two tigger wires when it turns on. One is an AMP TURN ON wire (blue/white) and a PWR ANT wire (blue) and that wire only comes on when using the radio or an optional HD radio unit ... When it was installed/connected . someone hooked your amp turn on wires for your "full range amps" to the PWR ANT wire. And the sub amp trigger is either hooked correctly to the AMP TURN ON WIRE or somewhere else, it probably shouldn't be... Check it. Amp triggers should all be to the blue/white wire from your alpine. Warning: Alpine trigger wires, are very easy to mess up they supply a very limited amount of power.
Apr 28, 2008 | Alpine CDA-9885 CD Player
Radio has sound but not the CD player or iPod
Your amp is not turning on - what you should do is connect the "blue/white - remote turn-on lead" to whatever wire you have the "blue - power antenna" output from the Alpine connected to now. That should solve your problem.
Mar 07, 2008 | Alpine CDA-9883 CD Player
Radio sound but NO cd or ipod sound
Radio is screwed.
But try these these steps:
Clean the eye of the head for reading CD. Must open up the radio.
IPod: check for good connections from Ipod to PCB.
Feb 23, 2008 | Alpine CDA-9856 CD Player
Cd plays, but no sound
Disconnect the blue wire from the back of the radio and connect the blue/white wire in its place. This should fix your problem.
Apr 29, 2007 | Alpine CDA-9833 CD Player
Alpine CDA-9826 CD Player Logo
180 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Robert Salgado
Robert Salgado
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
