Question about Panasonic PT-AE900U Multimedia Projector
Panasonic AE900U Projector
The projector is 1 year old. Shuts itself off while running. First time I thought it was the bulb, but following replacement the same problem occurred. Now, on startup, it will shut down three or four times before finally starting up. Once running, it stays on for between 15 minutes and three hours. Projected image is perfect when running. The projector has not been moved, or damaged. The dust filter is cleaned regularly. Mounted upright, fan is on high setting as I live in a warm climate (Brasil), though I am not always certain the fan is actually running. Since qualified repair shop is likely out of the question here, I am hopeful I can fix this myself.
  • MollyWage Dec 06, 2007
    I have experienced similar problem where the projector will not power on and the lamp light blinks, but I only have about 300 hours on the lamp. Turning the power on and off a few times may fix the problem sometimes. I called Panasonic a couple of times and they suggested sending the unit back for repair. I read on Amazon reviews and someone reported this problem is experienced by a lot of people and it has something to do with a defective iris, but Panasonic will not recall the unit.
  • PeterV2 Dec 19, 2007
    I have just had the same fault repaired under my extended 4 year warranty.
    The standby lamp was flickering on and off, as was the light, and when it was on the picture was OK. I suspect it was the iris as the lamp was not turning off, just the light. The project is just over 2 years old and only has 450 hours on the lamp. The service repairer (not Panasonic) told me they replaced a defective P module, what ever that is. Could be the power module, I really don't know. Anyway, it has fixed the problem.
If you cant hear the fan running it isnt. While this unit has a quiet fan believe me you will know if its running during normal operation if you listen for it. This would explain your constant shutdownds.
Posted on Nov 01, 2007
I tried removing the lamp as soon as the unit shut down. this seems to work. i have had this problem occur a few times
Posted on Oct 07, 2007
Check the manual if you have it or on line. The symptom you are describing may be a built in warning that your bulb has reache 2700 hours. I think there is a reset process and then at 3000 it goes out. Spent today reading the manual because I have one and the red lamp light is blinking. I called Panasonic and found out the only place that services these units is in Leawood Kansas USA> The place is called Heartland Services.
Posted on Aug 27, 2007
Why does the lamp shut off on the Panasonic PT-AE1000E Projector within 1 minute of starting?
1,Check the fans ,whether the fan is running,when you turn on the projector
2,if the fans run, then ,check the lamp or lamp ballast
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
any questions, feel free to contact me
have a nice day!
Jerry Lampdeng Limited
May 26, 2014 | Panasonic PT-AE1000E Projector Lamp...
I've just replaced the lamp on my Panasonic PT-LM2E projector and it will switch on but no light comes out. The previous lamp blew in the projector after around 2000 hrs. The indicators are as...
I'd recommend checking the fans of the projector, and make sure that they're spinning. Since you've mentioned that the lamp blew inside the unit, bits and pieces of the lamp might have lodged itself within the fans. It might also have to do w/ the after-market replacement bulb, which I normally wouldn't recommend.
Aug 08, 2011 | Panasonic PT-AE900U Multimedia Projector
My pt-ae900u wont turn on. the lamp light is flashing red..and the motor or fan is making a soft scratching noise. I never got any warning on the screen saying the bulb was in need of replacing..but its...
First of all check the remove the lamp and check the same. if it found burned you have to replace it. Remember one thing you have to reset the lamp hour After replacing the lamp. You can see the option in the menu.
resetting procedure.
1. inset the new lamp.
2. power on the projector.
3. Press menu and select OPTION.
4. Press enter button and the select LAMP RUN TIME.
5. Press and hold MENU button for 3 seconds.
6. Lamp reset , power off message will display.
7. power off the projector. this will reset the lamp hour.
Also Check the lamp cooling fan of your projector. may be its has some problem. its not running at the correct RPM. Do one thing, Remove the fan from the projector. In the fan there will be a specification sticker. Remove the sicker. now u can see a hole in the center. its the bearing part of the fan. put one drop of oil in it. u can use any type of lubricating oil. rotate the fan leafs with finger for some time. after that re-stick the spec sticker. insert the fan in the projector. power ON the projector and watch.
ok
Mar 10, 2011 | Panasonic PT-AE900U Multimedia Projector
Our projector (Panasonic PT AE900U) is still working but the picture seems very dark all of a sudden. we are wondering if this means we need to replace the bulb and if so, what do we replace it with.
You need a new lamp. Cost is around $350. The following site shows replacement:
http://www.shopvsc.com/Replacement-Lamps-for-Panasonic-Projectors-s/284.htm?searching=Y&sort=7&cat=284&show=50&page=1&f-PT-AE900=109462
Oct 16, 2010 | Panasonic (ETLAE900) Projector Lamp for...
I have a Panasonic pt-ae900u projector that doesn't project an image. The lamp fires up but no light makes it past the LCD panels, no video or menu graphics, nothing...help would be appreciated
I have the exact same issue with my projector and was wondering if anybody has an idea what the problem/solution could be? Have checked all internal connections, wiring, etc. but nothing is physically wrong with it. Powers on and off with no issues; bulb is working but no light out of the lens. Please help!
Oct 14, 2010 | Panasonic PT-AE900U Multimedia Projector
Works good for 2 minutes, Then shuts down & light goes red. Remote wont restart , so turn power off then on, Works again for 1 minute then shuts down. Panasonic PT-AE900U... projector
change the Bulb if that does not work it could be a power supply or power supply regulator this should be done by a professional except the Bulb
how many hours of operation does the unit have ??
Sep 21, 2009 | Office Equipment & Supplies
Bulb not coming on?
Hi - You can download the manual by clicking the link underlined in blue below:
PT-AE900U
Most likely the air filter needs cleaning. See page 55
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Sep 13, 2008 | Panasonic PT-AE900U Multimedia Projector
No image, lamp light blincking red
I have a 3 yr old AE900U dont know exact hours but prob at least 2000 hrs. about every other start up, the projector would flash little box; (replace lamp now). now a month later lamp wont come on. So this is prob the normal way a lamp will die. anything else might be another problem.
Jul 23, 2008 | Panasonic PT-AE900U Multimedia Projector
Projector restarts after 30 minutes or so
Hi jamble77
This sounds like a faulty Ballast ( lamp's powersupply ) if it made a grinding noise and now the Projector shuts on and off intermittently.
I would advise you to rather have the part replaced than repaired , as in most cases the Ballast almost always returns with the same problem if repaired a couple of months down the line.
May 20, 2008 | Panasonic PT-AE900U Multimedia Projector
Panasonic PT-AE900U displays black and white only
sounds like bad cables, or wrong setting on projector you may have it set to compoent instead of composite,, you don't tell how you are hooking it up. (what type of cables you are using)
Oct 25, 2007 | Panasonic PT-AE900U Multimedia Projector
Panasonic PT-AE900U Multimedia Projector Logo
627 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
HEMANT GROVER
mahesh y.h
mahesh y.h
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
