Question about Sharp 27DV-S100 27 in. TV/VCR/DVD Combo
Picture break up
When I turn the volume up the picture starts to break up like some sort of interference, when I lower the sound it goes away
    Problem Solver:
  • 7 Answers
My first gut tells me that this is a power supply problem. The power supply runs out of capacity due to the increased load of the audio amp. Possible problems might be power supply capacitors have changed their value (lowered), if it has a linear power supply, the full wave bridge (that converts AC to DC)might have a bad diode, if it is a switching power supply one or more of the output capacitors may actually be open. Another possible problem is a cold solder joint. Does the picture breakup occur when the case is slapped? This could indicate a mechanical failure (like a solder joint). Is this the only symptom that this set has?
Posted on Aug 13, 2007
6ya staff
SOURCE:
My samsung tv model number is sp50L7hx it's 5 years old, when I turn it on it's a brill picture and sound, after ten minutes the picture goes off , the sound is still on and a very dim lit black screen, if...
This problems is the causes by the board call the T-Con decoders board is dying.This board sit right in the middle bottom of the LCD picture screen panel.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-Con decoders board for the replacement.
Nov 23, 2010 | Samsung Televison & Video
Hissing sound coming from speakers
I found out that if I manually turn the speakers down on the tv and then turn it up with the remote control the hissing sound goes away
Mar 18, 2009 | Toshiba 65HDX82 65" Rear Projection...
JVC AV-32D305(?) turns off sound but not picture
if you know how to solder ,resolder the amplifier your tv .or check speaker
Sep 03, 2008 | JVC AV-32D305 32" TV
Large black box keeps covering 80% of the screen
i have the same problem, when i turn the volume knob on hitachi remote it goes away. Anyone heard of thi s???
Aug 30, 2008 | Hitachi 42HDS69 42 in. Plasma Television
PANASONIC 42 PLASMA WHEN YOU TURN IT ON THE TOP ONE THIRD HAS A DOUBLE PICTURE AND GOES AWAY AFTER A SHORT TIME. PANASONIC SAID TO LOWER THE VOLUME CONTROL ON THE TV AND HIT THE CENTER BUTTON ON THE REMOTE...
well did you do that and did it work ? i guess that panasonic doesn't say that for nothing so try that first , and unlike lcd tft tv's plasma need to be warm to get the best picture
Jun 01, 2008 | Computers & Internet
Sound
WOW never heard this one . You might check the volume down button on the tv to see if it is depressed in . What is the model # and do you clean the picture tube with windex ? Maybe some of it has seeped down onto the control board and has gummed up the volume down button. Good luck
Mar 03, 2008 | Sony KV-27V42 27" TV
MPVR+ CB Picture Sound
I have this camera and unfortunately there doesn't seem to be a way to turn that sound off. It's odd because I have an IS-DV2+ also and if I turn the volume all the way down, that sound is muted as welll. I don't know what goes on at Aiptek...
Dec 14, 2007 | Aiptek MPVR Digital Camera
Unknown model of panasonic tv problem with picture
Depending on age, it sounds as if picture tube has an intermintent short in the red gun. tap on the center of the screen to see if it goes away, if it does,I would strongly say that the tube is gone; but you could try openning it and check if the crt board is mounted on the tube's neck properly. do this at your own risk since you might get a shock if not familiar on how to handle tv's.
Nov 20, 2007 | Televison & Video
Zenith IQB60M92W 60in Rear Projection
Sounds like some kind of local interference. The first thing I'd try is disconnect the antenna input. If the wavy line goes away, it's probably something coming in through the antenna. Then I would start shutting off the circuit breakers until I was down to just the one the set is plugged into. If it goes away I would start flipping the breakers on, one by one until the noise returned. If you can isolate it to one circuit, start looking at everything that is on that circuit. If all else fails, call a TV tech.
Oct 01, 2005 | Zenith IQB60M92W 60" Rear Projection...
Sharp 27DV-S100 27 in. TV/VCR/DVD Combo Logo
148 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
