My electri dryer 14 years old model keye670bwh2 serial no me0604386 was overheating and triped the breaker. brunt out heating element thermostat. brought new kit replaced.clean vent,then the motor . kept on tripping the breaker.runs 5min cuts out.put thermometer heat discharge was 125-145 that was in the vent discharge. took back off, check oms all stats look good
Breaker is tripping from faulty insulation allowing current to ground
breakers work on milliamp current so it requires a mega meter to check the insulation
call a qualified electrician to check the unit
Check to make sure the breaker is rated for the current draw of the dryer. If it is, you MAY have a bad breaker. Replace your breaker and If the dryer is still tripping the breaker, your dryer needs to be repaired by a qualified technician.... the heating element is probably burned up and shorting out.
Your heater elements may be bad and need replacement. Is it an electric dryer? If so electric dryers run a dual breaker, this means 120 volts on one side of the breaker runs the motor, the other side of the breakers runs the heater coils. Its possible the heater side of the breaker has tripped. Try turning off the breaker for 20 seconds or so then reset. 220 volt breakers can trip on one side and not the other.
Your heating element needs to be replaced, or the 240 breaker in your breaker box has tripped. I was a maytag technician for several years...So, check your breaker box for any tripped breakers or the heating element in the dryer needs to be replaced, or the t.stat for the element has blown.
Heating element or motor. Usually heating element. Replace limit switch (inside dryer) during repair. Limit switch should shut off before breaker if working correctly.
After repair clean or replace plug/wire. Inspect or replace receptacle in wall.
It is possible that you could have a bad breaker in the panel. They will start to trip randomly when they are going bad. If not the dryer is drawing too many amps and the breaker is doing it's job. If the heating element is defective and drawing extra juice that could trip the breaker. Usually replacement breakers are not too expensive if you electrical panel is less then 20 years old and can be purchased at most home improvement stores. I would try replacing the breaker before you try repairing the dryer. If you install a new breaker and the problem continues to happen then you should check the dryer heating element. That component is what draws the most amps and would be the most common one for tripping the breaker.
sounds like your heating element has opened up it was probably partially shorted to the case and this was causing your breaker arcing condition previously
how much are you putting in ? Is it a 220 volt dryer? May have a dead line (electris) to heating coils, or thermaostat is not functioning and letting the dryer coils get to operating temperature. Your heat setting control may be faulty. I wouls look at heat control first.
Check the circuit breaker or fuse box it takes two one to run one to heat. Then check thermostats Hi limit may be burnt if it overheated If the venting had been blocked. Hope that helps
