Question about Toshiba 51H84 51" Rear Projection HDTV-Ready Television
Toshiba 51WH46 - Bad picture on powering up
Over the the last few months the picture on the TV has been pixelled on starting it up. This used to go after a few minutes, but now its at a point where it takes about 15 minutes to get a decent picture and even then its pixelled round the edges. Picture tuning and Convergence make no difference. Can anyone help? If it needs a spare part where can you get it from and how much will it be?
  • Anonymous Aug 15, 2008
    TOSHIBA 50HDX82 CINEMA SERIES.SAME SYMPTOMS AS SWANLADY2000'S.ALSO MY FRIEND BOUGHT THE SAME TV AS I DID AND HE'S GOT THE SAME PROBLEM.
4 Suggested Answers
SOURCE:
  • 1030 Answers
SOURCE: bad picture until tv warms up
this is a very common occurance in these sets. toshiba has issued a servece bullteen with this set. Sorry to tell you this but this is a problem with some very small capacitors on what is known as the hypermodule. in my shop we fix 2 to 5 of these a month. you really have to know how to solder. Idealy replace the hypermodule is the best way. but......that board is hard to find. so we replace these 11 very very small componets with twezzers and a big magnifier. we charge about 250 to 350 for this repair.
Posted on Oct 08, 2008
SD Tech
  • 14553 Answers
SOURCE: TOSHIBA 57H82 TV Blurry for 15 minutes till warms up
This is a model first sold 2002.
They have a history of the Hyper board failing. Usually noise or lines in the picture and the warmup time gradually gets longer and longer.
This board processes all signal from all inputs inside the set and is no longer available from Toshiba.
The only way to get one is from a national company called PTS Electronics who rebuilds or repairs them--cost for rebuilt board is about 220 plus shipping and part number for this model is:
Part Number23148024
I have a service bulletin with photos of the board on my computer.
It is a financial decision, not a job for the average do it yourself person to attempt.
Let me know if you have questions or need help.
SD TECH
Posted on May 03, 2010
welcomejee
  • 10594 Answers
SOURCE: It take my Toshiba about 10 minutes after I turn
If you get shaky picture with lots of lines (as shown in below image) in your Toshiba 52H82 tv then it is problem of bad capacitors in Hyper Module, replace these capacitors in hyper module to solve this problem. Hyper Module is little circuit board mounted vertically on signal board and located behind inputs jacks.
Capacitors replacement needs good soldering skills with proper tools, if you do not have soldering parts in circuit board experience, local tv repairman will do this job in proper way.
Thanks.
Posted on Dec 31, 2010
Keeps taling longer for tv to start
Probable power supply decline to failure.
Dec 28, 2013 | Toshiba 46XV640U 46 in TV
My Polaroid TV is connected to Virgin yet most channels are pixelated and the tv looks like it needs fine tuning, but i can't. Any help?
on the tv screen menu go to display and reset the a settings the larger the numbers the better the picture --apply and ok
Oct 22, 2017 | Polaroid 4241-TLXB 42 in. LCD Television
Toshiba 40" turns on for a few seconds, then turns off. No picture!
Consider having it repaired as it should be in warranty.
Apr 30, 2012 | Toshiba 40E210U 40 in. LCD TV
Three-year old 47" Samsung LCD. At first, some pixelation, usually correctable by turning TV off then on again. This situation lasted months, getting slightly more frequent each week. More recently, the TV...
1. the motherboard might be bad and you will need to replace it. 2. or The power supply is bad
Chances are if its making clicks the power supply is bad and you will need to replace it. Which makes sense because constantly powering the tv on and off will damage the power supply or possibly short out your motherboard. These things usually cost about 200 bucks to fix at a local tv repair store.
Sep 02, 2010 | Samsung LN-T4671F 46 in. LCD Television
ZV55 toshiba TV
Bad capacitors on power supply board.
Apr 12, 2010 | Toshiba Regza 47ZV650 47 in. LCD TV
Toshiba lcd series 6, 18 month old tv will not
consult manual for troubleshooting it could be that lamp in tv takes long time to cool down or that it is bad they usually last about 2-3 years depends on how you use your tv
Dec 31, 2009 | Toshiba Toahiba Satellite A70 A75 M35...
Display not proper
hi sir
plz use the bloor in satalite component plz close all network then you u use it
Jun 06, 2009 | Computers & Internet
Green spots/pixels at top of TV screen
I have a 50" Pioneer PDP-503MXE with the same problem - the fans don't run. It appears to be a problem with the temperature sensor that controls the fan speed. However, the fans can manually be switched to MAX.
To do this, put the display in standby. Press the 'Menu' button and within 3 seconds press the 'Power/Standby' button. The 'Integration Menu' will appear. Select the 'Option' tab on the right. Scroll down (next page) to the 'Fan Control' option. It will most likely be set to 'Auto'. Press 'Set' to change it to 'Max'. Within a few seconds the fans will run.
At Max the fans are a bit noisey but it will cool the unit down.
May 05, 2009 | Pioneer PureVision PDP-503CMX 50 in....
Bad picturre on toshiba tv
Good Day, pieps57;
Corrective Action: Remove the MVUP13 Hyper Module from the TV chassis, remove the top shield and replace the 10uf, 16v capacitors using Part Number 24619040. It’s recommended that all of the capacitors identified be replaced (Note: These capacitors are low impedance surface mounted aluminum electrolytic capacitors. Care should be taken to avoid damaging the PCB while replacing these capacitors.) CAPS: cx178, cx221, cx230, cx241, cx250, cx261, cx270, cx541, cx670 & c514, c5030.
Good Luck, Big Irish.
Jul 07, 2008 | Toshiba 42H81 42" Rear Projection...
Tv picture
Solder any / all bad connects in power supply,vertical,horiz &
video circuitry,esp. regulator IC's..................T.
Jan 09, 2008 | Toshiba 32AF43 32" TV
Toshiba 51H84 51" Rear Projection HDTV-Ready Television Logo
99 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
