It has started having a dark stripe all the way across the paper. The green roller in copier in the printing area gets a build up of toner on it in the same area as the stripe. I clean of the build up off and in comes right back
Yep... it's the drum. this model is notorious for drum failure! Good news is you can replace thedrum yourself. DQ-UH32A I think is the Panasonic part number.
The drum (green roller) is causing your problem. If it has toner on it, cleaning it will not help...it may make it worse. The unit has a cleaning station built into it, and when it fails the drum unit needs to be replaced.
how much would it be to check the light path on an Infocus Lp640 projector? It lights up but there...
(More)
how much would it be to check the light path on an Infocus Lp640 projector? It lights up but there is minor discoloration on half of the projected image.
how do i remove the Panasonic 1810 printer / fax from the attached stand for transport & is...
(More)
how do i remove the Panasonic 1810 printer / fax from the attached stand for transport & is there anything special i need to do to move the unit to another location?
Help me with Search Tip: type in either product names or questions Search the entire site... or...
(More)
Help me with Search Tip: type in either product names or questions Search the entire site... or choose an option below Search the Web 1 Solution for ''WHAT IS ERROR CODE E07 12 ON PANASONIC COPY MACHINE WORKIO DP 3000E''
