Question about Philips 55PP9401 55" Rear Projection Television
Phillips 55PP9401 Convergence Problem
I've had a convergence problem for a few weeks and I'm trying to decide whether it's worth repairing or not. When I use the Intellisense function to align the tubes, it appears to come back with an "error code" 4. Does anyone know what this indicates, and, is it worth repairing a 6 year old set like this or is time to buy new?
  • wallacernrt Nov 12, 2007
    when in the service mode with only green shoing the bow or bend will not straighten, horizontal.
    what should i do?
    Genius:
  • 1,694 Answers
STK392-110 convergence IC's upgrade to STK394-160.....
I use Hitachi brand part # CZ 01341 ... change both.......
Check for dis-colored resistor (s) = replace with exact value...
Please respond............T.
Posted on Nov 26, 2007
    Genius:
  • 1,153 Answers
Yes change both convergence amps and resistors nearby and it should be ok.
Posted on Aug 25, 2007
Intellisense adjustment not working
It will not work if the convergence circuit is not functional--it is indicated here it is phillips 55pp9401?
Mar 24, 2012 | Philips 55PP9401 55" Rear Projection...
Don't have remote is there another way to line up colors I've already changed the convergence chips but not the resistors
Chances are the new ICs have failed since the 6.8 ohm resistors werent changed a phillips will almost always blow one or two of the 6.8 ohm resistors and if new ICs are installed without replaceing the resistors the new ICs are usually destroyed by the blown resistors. You will need the original remote or authorized replacement to adjust the convergence properly.
May 06, 2011 | Philips 55PP9401 55" Rear Projection...
My phillips 55pp9401 looks orange and purple , heres a picture of what it looks like, i tried the intellisense and it does nothing. http://palmsprings.craigslist.org/ele/1679632114.html
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV2_bing.gif may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 07, 2010 | Philips 55PP9401 55" Rear Projection...
I have a Phillips model 55PP9401 TV and there is no red color, but the picture is still good. What do I replace? The corners are also losing clarity? Please Help! Thanks
Ur convergence it dead.Must know how to solders?Buy a convergence kit,replaced what in that kit.Tries Tv repair World.com,Tvrepairkits.com
Dec 23, 2009 | Televison & Video
Double lettering on red when in 1080i good picture in 480p
This is a common problem. Your convergence has gone out.
Common symptoms are...
1) 3D Video
2) Warped Video
3) Convergence menu does not adjust the red or blue correctly.
Go here for a solution...
http://www.fixya.com/support/r2861627-updated_convergence_problems_amp
Sep 06, 2009 | Philips 55PP9401 55" Rear Projection...
Blue shadows
installing a convergence repair kit will usually repair that issue. You can get the phillips DPTV305-DPTV345 convergence kit at the following link. It contains the parts and a cd with instructions.
http://www.tvrepairkits.net/
Jul 10, 2009 | Philips 55PP9401 55" Rear Projection...
Where can i buy remote control for phillips 55pp9401?
get a full universal at your local walmart for less then 20 with full menu and program functions, get a phillips brand and no programming required.
Mar 16, 2008 | Philips 55PP9401 55" Rear Projection...
55pp9401 convergence problem
try aligning them using the yoke control rings.
sometimes the alignment is so far out that you have to adjust the magnet rings instead.
Feb 25, 2008 | Philips 55PP9401 55" Rear Projection...
How doi adjust convegence manually on phillips 55pp9401
Order service manual from partstore.com ..........
procedure is complicated..............T.
Dec 08, 2007 | Philips 55PP9401 55" Rear Projection...
Phillips 55pp9401 red and green not converging even after using itellesense
Replace convergence IC's STK392-110 mounted on large heatsinks....I use upgrade STK394-160E = CZ 01341 Hitachi #.
Let me know if you have ??'s.......................T.
Oct 27, 2007 | Philips 55PP9401 55" Rear Projection...
Philips 55PP9401 55" Rear Projection Television Logo
774 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
