Gestetner 3255 3265 3270 3355 3370 5502 Lower Fuser Logo
Anonymous Posted on May 11, 2013
CODE SC542 WHEN START THE GESTETNER 3355, SHOW ON DISPLAY SC542 CODE, PLEASE I AM TOTALLY LOST. HOW MAY I FIX IT?
Peter Fiadz
Level 1:
New Friend:
Problem Solver:
  • Contributor 10 Answers
  • Posted on May 11, 2013
Peter Fiadz
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
10
Questions
Helped
2637
Points
33
Press clear mode key follow by 107 and hold the stop/clear key to enter sp mode power the copier off and on if the problem reoccur replace fuser unit and enter mode and off and on the copier
4 Related Answers
Anonymous
  • 409 Answers
  • Posted on Feb 08, 2011
SOURCE: i have my gestetner 1312 code appear sc542..i
try installing a new driver for you model. you can download it here->>http://www.liutilities.com/device-driver/gestetner-dsc424-ps/
check this link too, it will be useful.-->http://www.qualpro.com/Products/Copiers/Color_Copiers/DSc424/DSc424.htm
Thanks for rating good luck
Anonymous
  • 263 Answers
  • Posted on Feb 09, 2011
SOURCE: We have a Gestetner 3355 in our office, there is
Maybe it's a power problem.
Do you have equipment plugged into a UPS? If so I would advise you to directly connect to power without the UPS.
If it still does not work try this procedure:
1. Set the machine to turn off with the weekly timer.
2. After the machine has turned off, turn the switch on and off operation at least ten times.
Anonymous
  • 263 Answers
  • Posted on Mar 01, 2011
SOURCE: Gestetner 2212 copier Service Code SC542 I"ve
In your machine (model) you have to enter in SP mode to reset your error code.
Try this:
Yellow key.
1-0-7 on the key pad
Red key at least 3 sec.
Press "copy sp"
On the key pad press 5 810 and #.
Press execute
Exit all the way out.
Turn the machine off and on.
Anonymous
  • 263 Answers
  • Posted on Mar 17, 2011
SOURCE: erorr cod sc542 for
already give the answer
3answers
What is error code SC542 for ricoh aficio 9005?
Ricoh Aficio MP2510, 3010 Error code sc542 on Lanier ...
? 6:08
https://www.youtube.com/watch?v=58MQVyjfDyg
Sep 3, 2013 - Uploaded by Used .Copier
Are you getting Error Code sc542 on your Ricoh, Lanier,Savin or Gestetner copiers? ... Ricoh Aficio 1022 ...
How to reset Ricoh Error Code sc542 sc546 sc548 problem ...
? 2:41
https://www.youtube.com/watch?v=3CnGl1Ytp34
Sep 21, 2015 - Uploaded by Copier Liquidation Center
How to reset Ricoh Error Code sc542 sc546 sc548 problem ...Ricoh Aficio copiers : AFICIO 1013 F
Gestetner DSM730
thermostatic from the fuse unit
Gestetner Dsc445 service code error
have you checked/replaced the thermostats?
this may also be a problem with your hvt board or power supply.
1helpful
Try this:
Yellow key.
Press "copy sp"
Press execute
1helpful
SC542 error code
Without a model, I can't give you a lot of information, but I am assuming it is a Ricoh machine (Possibly Lanier/Gestetner, same difference), as that's the format of their error codes. An SC542 error code is a Fuser Temperature Error, meaning that the fuser didn't warm up fast enough. It is extremely likely that you will have to replace the fuser unit before the error code will go away. Please give me a model number if you need more information and I will try to be a bit more precise with the information. Thanks.
We have a Gestetner 3355 in our office, there is an error code that says SC 124. What is this? And how can I fix it?
3helpful
Transformer blew at our office yesterday, now calling for a service call, error code SC542???
sc542 is a fuser temperature error code, which could either be something simple (a bad sensor reading) or something serious (a blown thermostat). Either way you'll need to have your service technician come take a look at it and reset the code. (Unfortunately, turning the printer off and back on won't help.)
Jai un probleme avec un copieur Gesttner 3220 . A l ecran il me marque le code sc542 je demande de l aide SVP
Gestetner 3220 is similar to ricoh brand
sc542 means your termistor had to be replaced with new one.
if you know the technique, switch off th copier,the open the lateral door,take out the fuser unit.
under or below it you will find 2 unit termistor with red
contact . Properly replaced both with new unit then reinsert the fuser unit in.
Switch on th copier,reset the machine to sp mode
to get into sp mode ,you have to push yellow[C] button follow by button 1,0,7 then push red button[cancel] for several sconds until the screen show sp mode.
When you in sp mode, switch off the machine,then wait for 1-2 min then switch on the copier, wa la it's working. You should try it and it save your cost.
3helpful
2answers
Error code SC 542 on my Gestetner Dsm622sp
Fusing unit problem.Verify the heater lamps,thermistor and thermofuse continuity.Enter in the SP mode turn OFF the main switch,unplugged the machine wait 10 sec.,plugged and turn ON the copier.
I am totally lost on how to add more toner to the
You can go here and download the manual. Even though it's a Gestetner...it cross references to a Ricoh Aficio CL2000. Ricoh builds all of their machines. Look for it under "printers"..."color":
http://www.ricoh-usa.com/downloads/manuals.asp?tsn=Ricoh-USA
I don't know if this will solve the "blue ink everywhere" problem
*Please rate me :)
Top Gestetner Office Equipment & Supplies Experts
Daniel Blask
Daniel Blask
ZJ Limited
ZJ Limited
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
