Question about HP ScanJet 5100C Flatbed Scanner
Scanner HP 6200
Scanning large volume of documents. Scanner works really well, but now scanning a black line down the left margin of pages. Tried feeding in a couple of blank pages to clean heads, and wiped down glass bed, but problem persists. Please help.
  • Anonymous Mar 20, 2014
    ive tried cleaning the cartridge holder, ive tried cleaning the screen filters, ive cleaned the printer head with alcohol and swabs. ive tried the alignment button , nothing works
  • 2,985 Answers
Not the scanner -unless you have allowed the page framing to slip- check that out More likely the printer- and an indicator that the waste ink tank is over full and needs servicing. Goto www.fixyourownprinter- and log into your model to see how to do it.
Posted on Aug 12, 2007
When scanning, why does the entire left side of page have a line down it one inch in from txt?
If you are scanning from the ADF - open the scanner cover and clean the narrow glass plate at the left end. It is usually caused by a speck of dirt or white out on the glass.
If you are scanning from the platen (large plate) you may have a faulty point on the scanner bar or a dead light diode. Alternatively you may have the source document in the wrong place and you are getting a page edge mark.
Apr 14, 2016 | Brother MFC-8370DN Laser Multifunction...
I am getting a black line on scanned documents of my HP Officejet 6310 All-in-One Thanks
It would require you to open scanner and clean scanning head unfortunately.
Aug 02, 2015 | HP Office Equipment & Supplies
Hp laserjet 2010 prints black line down side when printing scans from paperport 11
I have no idea what "paperport 11" is.
That being said, normally a line down the page when copying or scanning is caused by dirt on the Automatic Document Feeder glass, Not the flatbed glass. It is a thin strip of glass to the left of the flatbed scanner glass. Clean it.
Jan 11, 2011 | HP Office Equipment & Supplies
Orange line running down page
lift lid on scanner and clean the thin glass on left hand side
you usually find when you scan alot of docs dust builds up and leaves lines down page
Mar 08, 2010 | HP Scanjet 5590 Flatbed Scanner
Black line at left margin when scanning any document CX3900
Check to see if the glass part of your scanner is clean. Usually its dirty when you have that problem
Mar 12, 2009 | Epson STYLUS CX3900 All-In-One InkJet...
Black line down the middle of scanned documents.
Try leaving the cover open and run a test scan, once with a fresh sheet as the item to be scanned and then a second time without anything on the table.  You may see what is blocking the light source or possibly a defect in it.
Scanning is done left-right, left-right across the width of the page and the vertical stripe indicates that the blockage is present during each scanned line.
In servicing copiers and multifunction machines, I have found a number of curious contaminents, one of the most annoying was a moth, still alive, that would randomly sit on the lamp, causing some pages to come out OK, others not.
If your copies and printouts are coming out fine, then only the scanner can be at fault.
Jan 13, 2009 | HP Photosmart 2575 All-In-One InkJet...
Solid Line on left Margin after Copy/Scan
When I Copy or Scan with my HP LaserJet 3050, a solid black line appears on the left margin of the page. . Can you suggest any solution to the problem. .
Oct 29, 2008 | HP LaserJet 3050 All-In-One Printer
Scanning document leaves streak down right hand side
hmm this has happened before
make sure it is sitting straight and cleaning it might help
Jan 07, 2008 | HP PSC 1315xi All-in-One Printer
Black lines
Not sure what you have tried but if there are no lines when printing but there when scanning there is something on the scanner. Could be something as small a single dot of dirt and it will put a line down the whole page. Try cleaning the glass.
Dec 13, 2007 | Office Equipment & Supplies
Even a single grain of dust or a single strand of hair on the scanning glass will cause the scan head to perceive ink/image where there is none. Deffinetly try cleaning the glass using a good window cleaner, and a cloth that is completely clean, or even a peice of newspaper. If the black line remains, I would suggest taking it into a service center to have the scan head itself cleaned.
Dec 05, 2007 | HP OfficeJet 7310 All-In-One InkJet...
HP ScanJet 5100C Flatbed Scanner Logo
239 people viewed this question
Ben Johnson
