SOURCE: Mitsubishi projection TV WS - 55413
any flashing LED's when running service mode or convergence signal?
SOURCE: Mitsubishi WS-55413 timer light flashing. tv will not power on
you have some caps that have failed in the dm module
that will have to be replaced to correct the problem
if your know how to change them and have the tools the caps can be obtained through most electroinc parts suppliers
there 1000mfd 16v we increase working voltage to 35WV
if you can change them let me know and i can give you locations on the board and the dm stands on the right side of chassis at rear
SOURCE: Mitsubishi WS 55413. Ongoing rolling screen.
First check for the coolant/fluid leakage from the picture tube on to the signal board. Wipe it with paper towel and dry it will the hair dryer. I hope there's no corrosion yet.
SOURCE: Mitsubishi WS-55513 wont go from 480i t0 1080
Tries CBS or NBC channels have HD if displayed 1080i than ur box is working.The shows must say HD or Display 1080i to work HD programming.
SOURCE: Mitsubishi Medallion 1080 WS-55413 - colors not aligned
There is no "reset" as the set has in the customer and tech menus ways to attempt to manually adjust this.
under convergence in the customer menu select advanced and follow the instructions on the screen.
If Red or Blue or Green are skewed and will not adjust it means one of the two STK-394-250 CONVERGENCE chips this set uses is bad.
Depending on where you buy them they will range in price from about 12 dollars each to nearly 35 dollars each.
Let me know what you find; this may or may not be a do it yourself repair as some real expertise is required to correctly get at and replace the chips.
SD TECH
