Question about Sony KV-32S26 32" TV
Standby / Timer light with no picture
Have had no problems with the TV then the Standby / Timer light came on and there is no picture on the TV. The sound works but there is no picture.
  • 2 more comments
  • Anonymous Sep 08, 2008
    tried to turn tv on but no picture and red timer standby light is blinking,
    have not tried to do anyting yet, dont' know what the problem is and
    what to do.
  • Anonymous Oct 13, 2008
    Same problem - came out of nowhere. TV was fine, I glanced away, and when I looked back, the picture was gone. Sound is still fine. I turned tv off and back on again, and picture came up for about 2 seconds, then went black again. Now, no picture at all when turning it on, but standby/timer LED blinks when I turn the set on.
  • poohrules Oct 28, 2008
    My 32" Sony is only two years old and it has the same problem. The timer led blinks 4 times then goes off and repeats the same pattern over and over and the tv never turns on, no video no sound. Please tell me what components i need to change because I am an electronic technician. There is a small board with a power transistor with heat sink and two electrolytic capacitors on it, is this part of the power board. There is also a small metal case that looks llike a power supply with a large heat sink on the top of it, could this be the bad part? Any help would be greatly appreciated.
  • orteez2000 Dec 07, 2008
    I have a sony trinitron MDL.kv35s66 . After pushing power button i get a click (like tv turning on) but only get flashing red standby/timer light.
    New Friend:
    Problem Solver:
Hi I have the same problem tv sound comes on but I have no picture :( I have tryed resetting using the up arrow and power button but when I do this the Sony symbol apears then goes back off :(
Posted on Dec 07, 2014
    Genius:
  • 1,153 Answers
There are a series of cap and transistors that need to be changed, so if you are not familiar with soldering and component replacement then you may have to have someone do this for you.
Posted on Aug 12, 2007
  • mukta c
    mukta c Apr 09, 2015
    In which section you are talking about? where are these series cap. and tr.?
2 Suggested Answers
SOURCE:
SOURCE: sony tv model # kv36fs320 no picture sound is
check power supply. measure crt voltage on crt pcb at the tube nack.
Posted on May 15, 2009
Standby/timer light stays on red. no picture or sound on tv.
this is a simple capacitor fix at your local tv guy..should be 100 to $150 max
Apr 09, 2014 | Sony KP-48S75 48" Rear Projection...
No picture just sound
GO SETTING TAB AND FIND OPTION SET DEFAULT MANUFACTURING SETTING AND TRY
May 18, 2012 | Sony KV-35S42 35" TV
Hello I have a Samsung TV Model# HL50A650C1FXZA I have 3 lights blinking 2 green and 1 red light what is the problem
Hello, I try to help. But your questions not spesific.
Below are conditions lamp indicators that appear blinking and solutions:
1. If Timer and Lamp blinking --> Auto timer on/off was been set, picture will appear ~ 25 second.
2. If Timer and Standby/Temp blinking --> A cooling fan inside the set is not operating properly.
3. If Lamp and Standby/Temp blinking --> The lamp cover on the rear of the set is not installed properly.
I hope that solve your problem.
Thanks.
Feb 22, 2011 | Samsung DLP HL-P5663W 56" TV
Sony Trinitron TV. No picture; red standby/timer light flashes.
My Sony trinitron has the stero lite on steady and standby lite flashes four times then pauses and repeats. Can you tell me the circuit/condition causing the set to not turn on.
Jul 15, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Blinking/standby timer
Sony Trinitron TV. Worked well last evening. Now picture won't go on. When power is turned on, standby/timer red light flashes, but picture or sound does not work.
Jul 01, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
my sony red light flash.but it will not turn on just clicks
Nov 26, 2008 | Sony KP-48S75 48" Rear Projection...
Timer Standby light flashing No pitcher
Sony
Model # KP-53HS10
Serial # 9718217
MFG 2000
Plugged in TV. Timer Standby Light just flashes continusly. No Picture and No Sound.
Apr 02, 2008 | Sony KP-51WS500 51" Rear Projection...
Timer/Standby light blinks but no picture or sound when power button is pressed.
I'm having the same problem. My stand-by light blinks 3 times though. The tv clicks as if it is going to turn on, but it never does. Is there a simple solution to this problem?
Dec 22, 2007 | Sony FD Trinitron KD-34XBR960 34" TV
Sony KV-32S26 32" TV Logo
192 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
