Question about Bissell 7901-1 ProHeat Scotchgard Upright Wet/Dry Vacuum
Leaking soap dispenser
While using the proheat steam rug cleaner the soap is now pouring out. I fill the soap dispenser and it empties before I'm half done with a room. I used to be able to do 2 rooms before having to refill the dispenser. Not sure if you can get replacement dispenser bottle for the machine.
  • cleanser Aug 19, 2008
    I have the same or similar problem. As soon as I put the SmartMix bottle in place, it starts leaking solution onto the floor.Haven't figured out yet if leak if from the bottle valve lid or the compartment in which it is placed.
Same problem. Let me know if the new solution bottle helps.
Posted on Nov 19, 2016
This also happened to us. I just got a new one in the mail - did it over the internet on their website. Haven't tried it yet so hope it is the solution to our problem.
Posted on Aug 14, 2007
Leaks water or cleaner when setting upright
Turn the setting knob to the rinse cycle when not in use, and you have leftover cleaning solution. This is the standard setting when storing , it blocks the soap from dispensing.
Empty the water tank and rinse after each use, and store empty.
If still leaking check the lid on the soap dispenser, make sure the gasket is even before tightening down and or the gasket between the water tank and the body, make sure they seal , check if they are straight and flush where they connect..
Mar 17, 2014 | Bissell 8910 ProHeat Clear View Upright...
Bissell ProHeat Rug and Floor cleaner. Won't
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
sf
Oct 20, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
I have a bissell steam cleaner. the hand piece
heatman101
a
Sep 26, 2009 | Bissell 1699 ProHeat Clear View Upright...
Water won't come out
Hi there SmartAlec from nelsonvacuums.com.au here. I think that the likely solution for the problem is that the water tank is slightly warped and so will not seal properly. Normally this is caused by using hot water in the tank. It should still be covered under warranty though just take it back to the dealer and get them to check it.
Aug 14, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
Soap is not dispensing out of the soap dispenser on the bissell
Pour some hot water in the machine and see if the hose is clogged. Is the pump making any noise when you hit the switch like it is trying to pump?
Feb 11, 2009 | Bissell 1699 ProHeat Clear View Upright...
Bissell 7901-1 ProHeat Scotchgard Upright Wet/Dry Vacuum Logo
507 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
