Question about GE Profile Spectra JGBP90 Gas Kitchen Range
GE Profile Spectra JGBP85WEB5WW Range
Back on July 15 I wrote in with a problem with my GE Profile Spectra JGBP85WEB5WW range. I noticed that ever since I used the self cleaning oven feature, my oven didn't work right. It took forever to reach proper temperature. The broiler works fine. I was told that it was probably the oven igniter. So, two days ago, my husband put in a new oven igniter. Thought that my have solved the problem. It still takes about 30-40 minutes before the oven gets up to 350 degrees. My mom has the same stove, so I went over to her house and set the oven to 350 and within 9 minutes it had reached temperature. Any thoughts as to what might be the problem. Thanks for any help.
  • Michael McGloin Aug 12, 2007
    My husband is electrician by trade and he installed this range when we purchased it. He has also installed new gas water heaters in our house. Would this gas valve be located on the range?
  • Anonymous Jan 25, 2009
    my ge profile oven will not heat to proper temp and it will not reset
  • 76 Answers
It sounds as if you might have a problem with the gas valve for the oven. This is something that I would not reccomend that you try and fix yourself.
Posted on Aug 12, 2007
I have a GE Spectra Profile XL 44 and I get an code F0. What does that mean?
Here is a tip that I wrote that will help you with the Xl44 profile error codes.
Oven Fault Codes for GE XL44 Oven
heatman101
Oct 03, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
How do you lock the oven to clean? GE Spectra Profile Glass Top Stove
Before you try and use the self cleaninf feature... save your self some more problems by reading this tip that I wrote...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Apr 04, 2010 | GE Spectra JBP78 Electric Kitchen Range
Ge spectra oven xl44 model # JGBP85WEB5WW oven will not heat
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Nov 22, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
GE JGBP85WEB5WW - F7 / E9 Error codes
Well first of all you determine if problem is with the Key Panel or Control by-
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
This error code means Function pad button stuck or Bad clock: Unstick button or Replace Electronic Range Control (ERC).
Post comments for more help or information........
Good Luck!!
Aug 31, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Display shows error code "F1"
F1 Failed Thermistor Control Replace Electronic Range Control (ERC)
Good Luck and Please Rate Fixya!
Jan 06, 2009 | GE Profile Spectra JGBP79 Gas Kitchen...
im assuming you dont have to light the pilot.if thats the case and you replaced the ignitor assembly it could possibly be the ignition module/board.
Aug 13, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Yes, it could very well be an igniter. The igniter can still glow and not work. The reason being that the igniter (depending on type) needs to produce .25 to .37 amps in order for the gas valve to open. If this potential is never reached, the igniter will glow, but gas will never flow. Or, gas will eventually flow for a weak (slow) igniter and will take forever to ignite. Which could be the reason for your low bake temperature. The burner does not stay lit all the time during the bake cycle. It will cycle on and off as needed to maintain the oven temperature. If the igniter is taking a long time to relight the burner, it could take a long time to heat. The broiler has a separate igniter and probably doesn't get used as often as the bake igniter. You can test the theory by swapping the igniter between the bake and broil burners and see if the problem moves to the broiler. Make sure you secure power to the range BEFORE attempting to remove the igniter, however. You should not have to turn off the gas to do this. Everything should be accessible through the oven door and broiler. I tell you this, because a new igniter (depending on the type you have) can run as much as $100. It will probably be worth the effort just to be sure. I hope this helps you.
Jul 15, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
417 people viewed this question
Top Kitchen Ranges Experts
Steve Allison
Steve Allison
Craig Butler
Craig Butler
Sal De
Are you a Kitchen Range Expert? Answer questions, earn points and help others
