Question about SanDisk Sansa e260 MP3 Player
Ipod charger I accidentally plugged my Sansa e260 into ipod charger and now my player is dead. It was only plugged in for about 1 minute
    Problem Solver:
  • 18 Answers
1 question: how did you do that? i thought the Ipod and the sansa have different adapter types? anyway, i'd suggest getting a new battery. and it's probably because the sansa and ipod use don't use the same amount of energy (volts, etc.) that this happened.
Posted on Sep 03, 2007
SOURCE:
Can i use a ipod charger for a sansa mp3 4 gb
No. The pinouts are different. You can fry a Sansa by using an iPod cable or vice versa.
Jan 07, 2012 | SanDisk Sansa e260 MP3 Player
Type of charger of Sansa e260 (4 GB) MP3 Player
i have my SanDisk Sansa e260 MP3 Player and i lost my data cable, good thing is i have a spare of apple ipod charger, can i make use of it as data cable and how is it gonna be? thanks
Aug 15, 2011 | SanDisk Sansa e260 MP3 Player
I tried to charge my sansa clip with an ipod mains charger and now it is dead!
You can try and reset your sansa and see if this fixes the issue.
Connect the proper USB cable to yoru Sansa the Press and hold the Power On button and the Play button (>||) for 20 seconds
Jan 31, 2010 | SanDisk Sansa Clip MP3 Player
SanDisk Sansa e260 (4 GB) MP3 Player MP3 and Digital Media i have a e260 sansa mp3. when i plug it into my Answer i have a e260 sansa mp3. when i plug it into my computer it wont charge what should i do
There is a trick to charging the battery in these small mp3 players. It wont charge if it is turned on, and it won't charges if it's turned off. Here what to do...
1. plug the payer into your USB port. or wall charger
2. switch thje palyer on using the mechanical switch (on the side)
3. turn it off by either holding down the play button, or selecting "System" from the menu
4. The screen will go black and the battery will begin charging.
Jan 30, 2010 | SanDisk Sansa e260 MP3 Player
Sansa shorted out from an ipod dock
that wasnt the best idea to start out with,
but it was a good heads up for me.
uhm,,,, i'd check with sansa to see if you have a warranty available,
otherwise you may have to replace your mp3 player.
not the best news, but its the truth.
Nov 15, 2009 | SanDisk Sansa e260 MP3 Player
Charger
Your USB port must be repaired. In the meantime, hopefully, your computer has another USB port that you can use. Battery is a replaceable lithium ion rechargeable battery. There are battery chargers that you can connect to wall outlets - the type that plug into the computer would probably require that you plug it into the USB port, which you said is broken - so that's a no-go. There are multiple vendors for battery chargers - one possibility is http://www.greenbatteries.com/
-Tha Mp3 Doctor
Jun 02, 2008 | SanDisk Sansa e260 MP3 Player
Dead Player
Hmmm...the MP3 parts shouldn't have lined up with the iPod dock. Check that area for damage in case your son accidentally forced it. Otherwise, hold the power button for 15 seconds. That can occasionally jump-start my player, and it turns the player off even if it is frozen.
Jan 22, 2008 | SanDisk Sansa e260 MP3 Player
Sansa USB and Charger Problem
hi ya, ok one of the solution is checking out the trouble of litium battery, i guess has been out of base, i had the same siptom with sansa e250r 2-g, put in right the battery. In back of sansa there are 4 screws that u have to loose it
Aug 09, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
82 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
