Question about Ricoh Aficio 2015 Copier
How to load new developer ? - Ricoh Aficio 2015 Copier
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 32 Answers
If u have service manual u can load new developer by ur sel but if u r not technician its hard to load develpoer. u can by to me a service manual. email me at xeroxtechnician@yahoo.com
Posted on Feb 12, 2014
We have paper jump problem.after reseting and changing powder developer.for konic Minolta .bizhub250 bw
So you recently replace the drum? and the developer if so did you clear the counters for the drum and developer, FIRST? IF not then the copier thinks the new drum and new developer are old. The copier works on the counters that is how it knows it got a new drum and developer. Get new developer and a new drum and have it installed correctly. Counters are clear before the unit is yanked out of the machine, then you remove the image unit/drum unit replace the developer/drum and cleaning blade. (DO NOT USE A VACUUM CLEANER WHEN REPLACING THE DEVELOPER static electricity can destroy the sensor located below the developer unit. Then reinstall and RUN F8/Developer Charge. Make sure the fax line and Ethernet cable is removed can't print anything until the F8 is run. Or you will start all over again with new developer and a new drum.
Apr 21, 2016 | Minolta Office Equipment & Supplies
Konica minolta develop error c2557 how to solve
Did you recently replace the drum and the developer if so did you clear the counters for the drum and developer, FIRST. IF not then the copier thinks the new drum and new developer are old. The copier works on the counters that is how it knows it got a new drum and developer. Get new developer and a new drum and have it installed correctly. Counters are clear before the unit is yanked out of the machine, then you remove the image unit/drum unit replace the developer/drum and cleaning blade. (DO NOT USE A VACUUM CLEANER WHEN REPLACING THE DEVELOPER static electricity can destroy the sensor located below the developer unit. Then reinstall and RUN F8. Make sure the fax line and Ethernet cable is removed can't print anything until the F8 is run. Or you will start all over again with new developer and a new drum.
Nov 01, 2015 | Konica Minolta Office Equipment & Supplies
KONICA MINOLTA 164 MAINTENANCE CALL (M2)
. Might want to have the developer replaced and drum/cleaning blade normally done all together, then run the F8 procedure/Developer Charge, and make sure the counters where cleared. Did you recently replace the drum and the developer if so did you clear the counters for the drum and developer, FIRST? IF not then the copier thinks the new drum and new developer are old. The copier works on the counters that is how it knows it got a new drum and developer. Get new developer and a new drum and have it installed correctly. Counters are clear before the unit is yanked out of the machine, then you remove the image unit/drum unit replace the developer/drum and cleaning blade. (DO NOT USE A VACUUM CLEANER WHEN REPLACING THE DEVELOPER static electricity can destroy the sensor located below the developer unit. Then reinstall and RUN F8/Developer Charge. Make sure the fax line and Ethernet cable is removed can't print anything until the F8 is run. Or you will start all over again with new developer and a new drum.
Feb 03, 2014 | Konica Minolta Office Equipment & Supplies
How can install hebrew in 8350i
Simple
1. Download and install the multilingual version of "BlackBerry Desktop Manager 4.7" (use a search engine to find it) [Don't navigate using the AT&T page or you will only get the 4.6 option which will not include what you need]
2. Connect your device
3. Click on "Application Loader"
4. Under "Update Software" click on the "Start" menu
5. In the "Device software options" section, click on the "Options" button
6. Scroll to the "Language and Input Support" section
7. Check Hebrew (you may also want to include other options, such as BlackBerry Maps)
8. Click on the "Next" button then "Finish"
Advanced
The AT&T firmware does not include the Hebrew language support. For those brave enough to follow the steps below, and who don't mind to spend the time downloading/installing all the necessary parts, here it is (its really for advanced users only):
1. Search for the Blackberry Bold 9000 download page from a European carrier (I've only tried Orange UK). E.g. search "Blackberry Orange UK downloads".
2. Select to download the BlackBerry Handheld Software v4.6.X.*** (Multilanguage); where *** is the latest version.
3. Install the software on your machine
4. Open C:\Program Files\Common Files\Research In Motion\Shared\Loader Files
5. Open the 9000-v4.6.0.162_P4.0.0.155 (or similarly named) directory
6. Open the Java directory
7. Copy all files ending with __he.cod as well as the net_rim_font_semitic.cod file,
e.g. c:\Hebrew9000
8. Search for "Blackberry Software for Developers" to get to the RIM page.
9. Download the latest Blackberry Development Environment package
10. Install the development environment package
11. Create a new file in the directory where you copied the .cod files (e.g. c:\Hebrew9000) called InstallHebrew.bat.txt and add the following line (make sure its all is on the same line):
"C:\Program Files\Research In Motion\BlackBerry JDE 4.5.0\bin\JavaLoader.exe" -u load *.cod
12. Rename the file from InstallHebrew.bat.txt to InstallHebrew.bat
13. Connect your Blackberry and open the Desktop Manager
14. Double click to run it or open a command line shell.
15. You should see something like:
RIM Wireless Handheld Java Loader
Copyright 2001-2007 Research In Motion Limited
Connecting to device...
Connected
Loading net_rim_bb_crypto_resource__heDone
Loading net_rim_bb_diagnostic_resource__heDone
Loading net_rim_bb_elt_resource_he Done
Loading net_rim_bb_help_umts_wlan__he Done
Loading net_rim_bb_lbs_resource_he Done
Loading net_rim_bb_ldap_resource__he Done
Loading net_rim_bb_passwordkeeper_resource__heDone
Loading net_rim_bb_qm_peer_resource_heDone
Loading net_rim_bb_resource__he Done
Loading net_rim_bbapi_pim_res__he Done
Loading net_rim_bis_client__he Done
Loading net_rim_crypto_resource__he Done
Loading net_rim_font_semitic Done
Loading net_rim_platform_im_resource__heDone
Loading net_rim_platform_resource__he Done
Loading net_rim_platformapps_resource__heDone
Loading net_rim_runtime_resource__he Done
Loading net_rim_secureemail_resource__heDone
Loading net_rim_vad_resource__he Done
Loading net_rim_wlan_bb_resource__he Done
Loading net_rim_wlan_runtime_resource__heDone
502958 bytes sent at ~670610 bps
Disconnected
Note:
- Your device will restart
- You can uninstall the device software and development environment from your computer since you only needed them to obtain the files.
Jan 09, 2013 | Blackberry Curve 8350i
Please I have canon copier IR3170C but it has been giving me this error code E000021 - 0001 any time i on the machine and it is being boot. Please help me out. thanks
getfile.asp?rid=1258 May 8, 2006 getfile.asp?rid=3215 Product : imageRUNNER C3100 / C3170 Title : E021-000x Error Code Error :
E021-000x Error Code: Developing rotary does not rotate and abnormal noise comes from motor.
E021 can be displayed when an error occurs in the developing rotary.
The detail codes are:
0001: The developing rotary home position cannot be detected.
0002: The intervals of flag detection during rotation is too short or long.
0003: The sensor does not detect the flag when the developing rotary stops at development point
As a result of inspection, it was found that the DC Controller PCB was unable to control the motor because it was faulty.
Workaround :
1. Check whether or not the developing rotary receives any physical load.
Rotate the developing rotary in a counterclockwise direction by hand to see whether it rotates smoothly. If any abnormality is found, eliminate the root cause. No problem is found, go to the Step 2.
2. Make sure that the connectors are securely fitted between J313 on the DC Controller PCB and the Rotary Motor (M8) or there is no pinched wire. No problem is found, go to the Step 3.
3. Replace the DC Controller PCB with a new one. If the symptom still recurs, go to the Step 4.
4. Replace the Rotary Motor with a new one.
DC Controller PCB: FG3-3846-030
Rotary Motor: FM2-0080-000 Canon USA, Inc. Systems & Technical Support Division
Jan 20, 2011 | Canon Office Equipment & Supplies
What is the difference between the toner and developer on this printer? The manuals we have don't give any info on installing developer, but you can purchase both toner and developer for this...
Toner provides the color, Developer consists of magnetic particles that carry the color on the outside of the developer drum, which is magnetic. Some developer is lost on each copy, although most stays in the developer unit. When you run low on developer, your image gets lighter and lighter, until the machine reports an error because it can no longer self calibrate. One change of developer suffices for many changes of toner. There is a procedure involving various actions and codes to flush the developer material out and load new developer in. This is not difficult, but there are a couple of reasons you might not want to do it if you are unsure why or if you should. First, developer for these estudio copiers, is very expensive. Second, unless you know how many copies have been made on the existing developer, you might change the developer, and fail to correct the problem. There are related service items, involving the cleaning blades, and seals, servicing charging grids, corona wire, and general cleaning of the 4 developer units and opc drums. Including dusting with zinc sterate, etc., etc. Its hard to know where to begin or where to stop. If you really want to know all about it, order a manual from any of a variety of on-line sources. Good luck
Aug 30, 2010 | Toshiba E-Studio 310c Laser Printer
Printer only prints in pink
toner to the developer does not pass from the toner bottle, and I cleaned the boat and I see that hand has good fall. But if I have this same developer unit to another machine if you load normally, then pull out my conclusion that the unit is not revealed what may be happening I would like to help me with this problem because I got tired of being disarmed and loading toner directly to the developer .
send me the answer to the following core: pozo23megadata@hotmail.com
Apr 11, 2010 | Dell 962 Photo All-In-One InkJet Printer
My top loading machine always stops on Rinse
Did you find a solution? Mine is doing the exact same thing : ( Thanks.
Mar 22, 2010 | Samsung SW62ASP Top Load Washer
Studio 230 added a new toner cartridge
When adding toner to the developer unit, it will load from the toner. So, if toner is empty, it will ask for replacement. Normally u can hear noise from the toner when loading.
Mar 19, 2009 | Office Equipment & Supplies
Problem with aficio 1035
The developer should probably be changed in it. the cartridge should be inspected as well. Was there any toner spills?
Jun 21, 2008 | Ricoh Aficio 1035 Copier
Ricoh Aficio 2015 Copier Logo
46 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
