Lg wd 10480np
No turn
My LG washer door wont open. Model is wd-14316RD. has done wash already.
There will be a delay of about 1 minute before it will open, this is normal. However if it will not open at any time try turning off at the power point, other than that you may need to get someone to look at it.
Apr 19, 2010 | LG WD-1080FD Front Load Washer
Lg intellowasher wd-8013f is very noisy
You suspect right.
It is a complete strip down job. I have just finished mine.
taking apart and reassembling is not too dificult.but you need to make up a tool to remove and replace the bearings which are two different sizes. It consists of a lenghth of studding, bolts and washers.
Download the manual from LG.
Good Luck
Mar 17, 2010 | Washing Machines
The barrel in our LG front loading WD won't turn.
Carbon Brushes on the motor worn down
Pulley loose on the motor or Drum Pulley
Motor control pcb failing to supply enough power to activate the motor
Take your pick !!
Sep 28, 2009 | LG Washing Machines
Washing Machines Logo
20 people viewed this question
Top Washing Machines Experts
