Question about Dometic Refrigerators
Rm 6401l start flshing light and starter keeps working after gas is lit
    Top Expert:
  • Dometic Master
  • 8,686 Answers
Check flame sensor if ok replace board
Posted on Jun 18, 2016
2 Suggested Answers
  • 93 Answers
SOURCE: Dometic rm 2652 fridge works on a/c. i get a check
you may need to change the thermocople this cost about 12 dollars this is what make electricity to epen the gas valve thanks from gilles
Posted on Mar 15, 2009
I have no electric power (i.e., clock, oven don't work) but the gas works fine.
Older stoves didn't have electric start so pilot stays lit on burners when power goes therefore burner will still light. Oven won't work since it probably needs electric power or has electric starter.
Feb 15, 2016 | Kitchen Ranges
I have a pro com 30000 btu vent free heater.it keeps shutting off.how do I fix it.
If the thermocouple is bad, the pilot light will not stay lit. Sometimes the pilot will stay lit but when the unit turns on the gas for heat, things change a bit and the nearly bad thermocouple doesn't see the flame it should and causes the gas to shut off.
You can google the make / model of your unit with the word 'thermocouple' and see replacements for sale. Usually not much more than $25. Thermocouple Wikipedia the free encyclopedia
Feb 08, 2015 | Heating & Cooling
Won't start but lights and radio work. It did this 3 times before ( in about a 2 week span) but eventually started after sitting a few minutes. The lights don't seem to dim when I try to start it. I came...
try to put the transmission in neutral and start it, this will eliminate the problem from the neutral safety switch.
if the car still won't start then go to the starter with a test light
connect the test light to a good ground or negative post on battery
touch the light on the small wire on the starter and have some one try to start the engine
if the light lits then the starter is bad
if the light is not lit then the ignition switch
Mar 09, 2010 | 1996 Mercury Sable
Light pilot on Royal deep fryer. Pilot will not stay lit. Second fryer has larger pilot have no trouble keeping it lit. How can I adjust the pilot so that it will stay lit?
there is a small adjustment screw on the gas valve,turn it clockwise to increase pilot,if that does not work the vent cap on the gas regulator on the back of the unit could be stopped up,remove that cap ,clean out or replace unit can operate without it just fine.If you increase the pilot and it still wont stay lit replace the thermocouple
Feb 06, 2010 | Vulcan GR45 Deep Fryer
Gas burners lit, but electronic ignition still clicks
Here is a tip that I wrote that will help figure out why the burner spark keepson clicking...
Gas Range RepairBurners Keep on Clicking
heatman101
fsggfs
Mar 13, 2009 | GE 36 in. Monogram ZEU769 Electric Cooktop
Dometic rm 2652 fridge works on a/c. i get a check light on lp gas, i can light burner with flame, it stays lit
Feb 25, 2009 | Dometic RM2652 Refrigerator
The car died and won't start.
check the fuel pump relay first for a diagram of this you can get one from the dealership or autozone and if you can spray some starter fluid in the throttle body and the car starts and runs till it runs out it is more then likely your fuel pump
Sep 22, 2008 | 2000 Ford Contour
Mitsubishi montero sport 3.5 4wd light keeps flshing and somtimes engages in the front when I put on the brakes as well as the anti lock light sometimes comes on.
I have the same problem, changing to 4 wheel drive works ok but 4WD light keep flashing. I was told that it needed a solenoid switch.
Sep 18, 2008 | Mitsubishi Montero Sport Cars & Trucks
Refrigerators Logo
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Colin Stickland
Colin Stickland
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
