Question about Technics Audio Players & Recorders
Technics sagx170 how do i turn off loudness function
No sound from the left channel of my technics sl-b35 turntable
First of all remove the wires to the cartridge. With the amp on, touch each of the wires to the cartridge with your finger. one at a time. On one you should hear a loud buzz on the left and on another a loud buzz on the right.
If you get no loud buzz on the left. There is something wrong with either the connections between the deck, or the pre-amp of the amplifier. This will not effect any other function on the amp such as tape or cd.
If you do get a loud buzz on the left, check the cartridge connection or replace the cartridge.
Apr 07, 2017 | Technics Audio Players & Recorders
Technics 1080 pre amp volume control is not functioning correctly
Technics SE CA1080 Service Manual
there is a chip called an operational amplifier under a heat sink on the pcb,that fails when it get top volumed for two long theres regulators with heatsinks.
it is listed as,
Technics SE -CA1080 amplifier F61 fault,
May 13, 2015 | Technics Audio Players & Recorders
Problem with rx yaesu ft 767G emits a loud whistle
It sounds like you have the microphone gain turned up to far or you are getting feedback into the speaker on the radio. If you are using an external speaker move it as far away from the radio as possible or add some ferrite clamp-ons to help with the issue. RadioShack Snap Together Ferrite Choke Core Radioshack just run the wire through them a couple of times and it should help.
Sep 28, 2014 | Yaesu FT-767GX Technical Manual
Technics su-g75 amp goes to loud static after a few minutes
Hi Aawpharmd,
system control error.
please go for repair shop.
regards,
nuwan
Jan 13, 2014 | Technics SU-G75 Amplifier
Technics SL1210 mk2 loud hum, it's not the rca or grounding cable...
This normally happens when the carts are removed and the amp is up. Its called microphonic-ing. Cheers john. Styluscity.
Apr 15, 2012 | Technics Audio Players & Recorders
Both Technics SL1210 mkII's loud hum and almost no sound...
You seem to have some feedback hum from somewhere. I would think it might be caused by a faulty connection somewhere.
Mar 12, 2017 | Technics Audio Players & Recorders
I have a Technics SL-BD20D turntable and want to connect it to a Technics SA-EH50 amp. Can this be done. Please tell how
Hi, you need a preamp to boost the line level if no dedicated phono input is on amp. Cheers John. Styluscity
Dec 28, 2011 | Technics Audio Players & Recorders
My su g90 shuts off when i turn it up loud what do
Amplifiers get hot. The more you crank the volume up (or use extended for extended periods), the more current is required. When it gets hot, there is a fan motor (on the back), that should turn on. I believe your fan motor (brush) is worn out and therefore non-functional. Under this condition when the system overheats, it automatically changes mode to protect circuits.
Also note: if it works when you initially turn it on (cold) for a few minutes it should work fine...until it starts getting hot inside the case.
Oct 20, 2009 | Technics Audio Players & Recorders
I have a Technics SA-AX610 receiver that says overload .
From the manual pg 27....... "The protection circuitry has functioned because the positive and negative speaker connection wires are "shorted," speaker systems with an impedance less than the indicated rated impedance of this unit are used or under severe use, such as loud volume, excessive power and in an excessively hot environment."
Nov 16, 2008 | Technics SA-EX110 Receiver
69 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
T-Comtech Repairs
T-Comtech Repairs
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
