Call service person code c0202
Powers well but after CALL SERVICE PERSON CODE C0202
    Top Expert:
  • Office Equip... Master
  • 34,170 Answers
Maybe calling a service person and reporting a displayed C0202 code will help solve this problem
Posted on May 11, 2013
How do I correct error code C0202?
Did you take the paper out of the left side of draw that area is not a storage area!!!!! DO NOT STORE extra paper on the left side of any draw, that space is use for 11x17 paper. Might have a bad lift motor, might also check the roller assy for the draw, since there are sensors that determine if the paper lifted
Jun 11, 2015 | Konica Minolta bizhub Office Equipment &...
C0202 bizhub c353
open the draw check for any paper behind it, THEN REMOVE ALL OF THE PAPER SITTING ON THE LEFT SiDE OF THE DRAW
NOT A STORAGE AREA. for 11 x 17 paper
Feb 05, 2014 | Konica Minolta Bizhub C353 Copier
Konica printer error code c0202
try to reinstall the printer driver
Nov 20, 2013 | Office Equipment & Supplies
C222 c0202
Remove the first draw check for paper behind it. Then remove the paper that is stored on the left hand side . That is not a storage area its for when you want 11x17 paper placed in the draw. If that does not clear the code the motor or the sensors that monitor the tray are bad or worse the control board is bad.
Oct 23, 2013 | Minolta bizhub 200 All-In-One Printer
Error code c0202
c0202 means that the top paper tray is not rising to bring the paper in contact with the feed rollers. Remove all of the paper from the tray and try turning the machine off and on with the paper tray not pushed in to the machine. Good luck.
May 20, 2011 | Konica Minolta bizhub 350 All-In-One Laser...
C-0202
C0202 on a Bizhub C350 means you have a Magenta PC Drum Charge Corona malfunction.
The charge corona is contained in the Magenta Imaging Unit. There are cleaning rods on each Imaging Unit. I would try pulling out the rods and cleaning the wires that way. Concentrate obviously on the Magenta unit. Run it in and out several times. Turn off the MAIN power switch (NOT the one up on the control panel) then back on to reset the code and see if it goes away. If not you may have to have your service company clean the Imaging Unit or it may have to be replaced depending on how bad it is.
Good Luck and Thank You for using Fixya.
Sep 19, 2010 | Minolta C350 Color Printer/Scanner/Copier
A paper jam was not cleared in a timely manner, now the machine will only display "Error Code C0202, Call Technician" It is Saturday and I can not get a hold of anyone at our support center. How can I...
C0202= tray 1 elevator failure.
Open tray 1, check and make sure paper is loaded correctly.
With tray open, open and close front door. This will reset error code. With tray 1 open look to see if paper is stuck behind tray in back of machine, if so remove it ( this will block the lift motor for the tray).
Close tray 1, if you hear a popping noise the lift motor is damaged and will have to be replaced. Until it is replaced operate machine with tray 1 out to prevent error code.
Sep 18, 2010 | Konica Minolta Bizhub 362 Copier
C0202
That is a Magenta image unit code. You can try and pull out the image unit, clean the contacts and reinsert it.
If that doesn't work you'll need a new image unit
http://www.gmsupplies.com/Konica_Minolta_Bizhub_C350/results_6920.aspx
Dec 06, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Error code C0202
this is a tray 1 lift up failure code pull the paper tray out and check to see if some torn paper is blocking the lift sensor look around where the paper is fed into the feed plates if not it could be a failed lift motor or sensor and they will need to be replaced
Nov 29, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Bizhub 200 Error Code C0202
I fix the error thanks to Patrillica on my BIZHUB 350!
The paper stock in tray 1 or to be exact above the tray 1, when you open it, you can hardly see it. After you remove the paper you should unplug your machine and then lug it back.
Thanks again to Patrillica.
Mar 29, 2008 | Minolta bizhub 200 All-In-One Printer
312 people viewed this question
k24674
