Question about Dishwashers
Siemens sn26m290 pump not working
  • 636 Answers
Could be that the pump is plugged or the water level switch is stuck. Check to see if the leveling switch moves freely by lifting it up and down a few times, then try the wash cycle again. Did you happen to wash dishes without rising them first, rice is bad for dish washers. Rice gets plugged in the diaphragm which is located in the drain line. You may have to remove the drain line fitting and clear debris which is lodged in the fitting.
Posted on May 11, 2013
My siemens dish washer,s pump keeps running will not turn off automatically when the cycle is complete
this is usually a sign there is a leak either the drain pump or the main motor it has activated the flood switch
May 30, 2016 | Siemens Computers & Internet
Siemens se25m275gb
Dishwashers tend to get stuck on wash cycle if the water temperature is not reaching the level the wash program expects it to reach. This could be due to faulty heater or thermostat or both.
One test is to run the dishwasher on a rinse cycle (normal water temperature) and see if it completes it.
Refer this site for location and cost of heater and thermostat
https://www.buyspares.co.uk/siemens/se25m275gb80/catalogue.pl?path=463858:496324,183865:463966&model_ref=185092
Apr 12, 2014 | Siemens Dishwashers
Siemens avantgarde washing machin stopping at rinse stage
Does the washer pump out the water after the wash cycle? If not then check the drain lines coming from the pump to make sure that they are clear. Your pump not pumping will cause the machine to stop working as well
Mar 23, 2014 | Siemens Washing Machines
I need siemens dishwasher model SL34A016UC/29 manual We moved into a house with the dishwasher already in the house. I used it once and the water won't drain, and they never left the manual. If you...
It is a common fault that the drain fails to work in most machines in a period of time and is the most problematic fault in a dish-washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged. Now remove the drain hose clamps and remove the drain pump/valve, clean the drain pump/valve, use back flushing to clear off all dirt. Now test using power to see if this works and can be simulated. When refitting, the hose must be tightened properly. If the pump/valve does not work even with power then it must be replaced. If there is intermittent power to the drain valve/pump then the program controller unit is a suspect.
Cleaning a pump:
http://www.youtube.com/watch?v=zKjKi50YBpI&NR=1&feature=fvwp
Finally the washer must be placed with a tilt- use a spirit level- so that all water will drain to the outlet port and thereby there is no residual water remaining.
Please check this link for SIEMENS manuals:
http://www.siemens-home.com/
Thank You for using fixya
Sep 23, 2011 | Siemens Dishwashers
Dishwasher siemens is not draining water.
Hello & Welcome to FixYa
Dishwasher not draining completely problem usually occurs due to clogged/blocked drain hose or the drain pump not working. First try to clean the drain hose and drain pump filter for any clogs, then check drain pump operation. If the problem returns after cleaning then it is the drain pump that needs replacement. Please get back to me if you have any other questions.
Kevin
Jan 09, 2011 | Siemens WFXD8400UC Front Load Washer
Our dishwasher does not drain and the red tap icon is now illuminated. Other things worked ok i.e. it cleaned the dishes ok but not it will not operate at all. It's about a year old. It is a Siemens...
The age is not a factor for this fault but I think that your drain pump is not working.
You will need to remove the drain hose and pull the pump off .
Use a voltge to check / remove clean dirt if action is low. If coils arre ok a ccleaning should solve.
however if the pump works fine on test then the controller unit is not outputing and could be faulty
Sep 11, 2010 | Siemens Dishwashers
Where can you purchase Siemens parts in the USA? We've just begun our search for a drain pump for our WFXD5200UC UltraSense Washer. Thanks
www.apdepot.com
they are very reasonably priced. If you don't find the part on their website, call them.
I just purchased that same part (drain pump assembly) for about $ 63.
Now I have to find out how to access it to replace it!!
May 16, 2009 | Siemens WFXD5200UC Front Load Washer
My siemens washer will not pump the water out or spin
Sounds like your pump went out on the machine. They are not ease to replace though. You might want to kall some one out to fix.
Dec 16, 2008 | Frigidaire ATF6000ES Front Load Washer
SIWAMAT 6102 (GB) Code 3 Flashing. What does this error mean
The pump was working but not pumping. The rubber hose from the bottom of the drum to the pump was removed and found to be partially blocked. The debris inside the rubber hose was cleaned out and reassembled with no further problems.
Sep 07, 2008 | Siemens Washing Machines
Siemens 1433 Washer - Aquastop
I had the "pump blocked" message, and we had the pump replaced after the technician took a look. He said the washer had been overused (we had run it 4 times a day for 8 months).
Jan 13, 2008 | Siemens WIQ1433 Front Load Washer
Dishwashers Logo
53 people viewed this question
Top Dishwashers Experts
