Question about Coffee Makers & Espresso Machines
WMF PRESTO STUCK
Hello i keep getting desc for my WMD coffe machine
    New Friend:
You do the Descaling and set the water hardness below 5
Posted on Jul 25, 2013
  • 3 Answers
SOURCE: hello my saeco vienna coffe machine leAKS ON THE
Take the brew group out from the machine and look inside the machine.espresso grinds will build up inside the area before it goes into drip tray (under distribution spout). Clean it out with a small pick and water. It is plugged up, causing water to bypass drip tray and run on counter top.
Posted on Jan 07, 2013
mikey270
  • 26 Answers
SOURCE: I have a WMF Presto coffee machine and when I
You have to have a lap top and software to repair! The only way to turn off the boot manager is to use the software that you can get from WMF! Try giving them a call if you don't have a tech in the area. 954-583-2269, good luck
mikey@espressomachineexperts.com
Posted on Feb 28, 2011
EsWorld
  • 1618 Answers
SOURCE: the coffe machine dosent rosast the benas
Try adjusting the grind coarser.
Posted on Apr 16, 2010
SOURCE: hello, the spent coffe holder fill up with water
water fills spent coffee holder during coffee making
Posted on May 16, 2010
katarzyna_ko
SOURCE: fault code 167 on my
Did You Solve problebm? What does it mean"luggers"?
Posted on May 23, 2012
Hello, i have a krups xp7220 and i have two problems with her.
A common place for a leak under the machine is the barista seal that goes in the bottom of the boiler around that eject rod. Barista seal part number is MS5002202, Seals on the tamping piston are MS5002040 (there can be 1 or 2 of these piston seals) If fixing the leaks does not fix error 6 then I expect it will end up being the distributor. Part number MS2A01500
Jun 17, 2017 | Krups Coffee Makers & Espresso Machines
I have a wmf presto coffee machine with an error code 186, how do I solve this
Download the Manual online. There is a Section that is for Diagnostics. I will tell you what the code is and how to replace it. Use the Model Number to get Manual.
Sep 15, 2014 | Coffee Makers & Espresso Machines
Can use 24vdc coil to 21 vdc oil
That should be fine - it's within 15%, on the "safe" side.
Aug 10, 2014 | WMF Coffee Makers & Espresso Machines
Wmf1400
http://www.manualslib.com/manual/879035/Wmf-Presto.html#manual
May 15, 2014 | WMF Coffee Makers & Espresso Machines
I Just bought a Saeco Intelia Focus espresso machine. I made coffe with 3 different coffe brands. Very good ones. And I became very disapointed when I try the results. Every time the espresso was way too...
Use less coffe , you are using too much , reduce the amout you are using . Presto . Also use homogenized milk , not skim , or fat free . Also use the water vapour to heat the cup before you make coffe , capuchino , caffe-latte, mocachino , espresso etc .
Oct 28, 2013 | Saeco Intelia Focus Automatic Espresso...
Fault code 167 on my wmf presto coffee machine
Aug 18, 2011 | Coffee Makers & Espresso Machines
I have a WMF Presto coffee machine and when I switch it on it comes up with WMF-AG Bootmanager P8.5 USB 1.1 on the screen and cannot do anything at all with the machine
Feb 28, 2011 | Coffee Makers & Espresso Machines
Wmf graphics filter missing! what is a wmf graphic filter?
 pc or laptop what ever you are using.in the operating system there is a file called -------- wmfimp32.fit file-------- this is missing.this hapopens due to viruses in the machine.some files get deleted.so its necessary to format your pc and reload the operating syste.as if you are not familiar with formatting and dont have software cd of your operating system then its very much advisable that you get it done by local computer hardware repair person.because if the virus gets in the some more files it will totally make your hard disk corrupt and all the data in the hard disk will get vanished.so its recomended to do this formatting as early as quickly as possible. thanks. keep updated.
Apr 13, 2009 | HP Pavilion a735w (PL308AAR) PC Desktop
Coffee Makers & Espresso Machines Logo
166 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
