Question about Car Audio & Video
CD CHANGER SHOWS ERROR 21
O own a Lexus LS 400, 1997, the cd player does not play. On the radio display shows Err 21 radio model P1712
    Top Expert:
  • Car Audio & ... Master
  • 38,111 Answers
This may be an indication that the CD player has worn out and needs replacement.
Posted on May 11, 2013
SOURCE: 6 cd changer
try to reset the cars computer. i had the same problem and it fixed it. all you need to do is unplug the battery for about 10 minutes and it may work. Good luck!
Posted on Jun 15, 2009
smarthome2
  • 1114 Answers
SOURCE: 6 CD Changer Stuck (Lexus LX 470)
Open the eject door and at the lower right side of the cartridge their should be a small indent that looks like you could poke it with a medium point pen. That's a reset for the changer. If that does not work, you will need to remove the changer from the car, pull off the top, plug the cable back in and hit eject. look for the arm on the backside of the cartridge and give it a nudge. It may just be stuck. Loading mechanisms usually do not fail before the optics or other!. If you need further help, post a comment with any model #'s on the changer and I'll look for info and help some more. Hope this helps.
Posted on Sep 30, 2009
SOURCE: i have the same problem error 4 in my lexus rx330 please help me
I just left the Lexus dealership w/ my ES 330 (my changer reads "Error 3" upon starting my car, it also makes a loud ticking noise); go figure, the mechanic/technician there informed me that I need another motor for my disk changer - Merry Christmas and hello $675!
After turning your car off for about an hour or so, the cd player is supposed to reset itself enabling you to retrieve your cd's. Attribute this to having utilized burned cd's.
Posted on Dec 16, 2009
SOURCE: CD Changer in RX330 Lexus 2004 shows error 4
I just fixed my 2005 RX330 CD changer jam, and saved $800-1000. It was easy, if you first spend $6 at:
http://www.carstereohelp.com
Here you will find pics and instructions on how to remove the stereo/changer. Mine was a Pioneer, and the stereo came out in 5 minutes. I could not find instructions how to take it apart, so I experimented a little. The secret was to take the top lid off the changer - 9 little screws, and a piece of black tape. Under the lid, I found my problem - a CD had been inserted too soon (the WAIT sign actually means what it says!), and I just lifted it off the top plate. Under the plate I could see 2 more CDs, in the 6 slot holder, but they seemed to be free and not jammed. So without reassembling the stereo, I plugged it back in. The changer cycled, I hit eject twice to get the other CDs out, and all is well.
Posted on Jul 05, 2010
SOURCE: Hyundai CD player displays ''error'' for all functions
my cd player in my sonata keep eject the cd can anybody help
SOS
Posted on Jan 12, 2011
Cd player shows toc err
google the name clarion error code toc
Feb 23, 2014 | Clarion Car Audio Player
What station does my radio need to be on in order for my 92 lexus ls400 need to be on so i can play my cd's????
if your car equiped with separate cd changer ,which usually in the trank , then in the head unit push CD button , then you'll be able to control and play CDs.
Jul 02, 2010 | 1992 Lexus Ls 400
I entered radio reset code for 2002 civic now the clock flashes and will not allow me to adjust it. How to solve this problem
Okay, I'm assuming that you were sucessful in resetting your radio code.
I'm also assuming that you have a CD player (which may not be the case).
The flashing clock also functions as an error code indicator. It should say something, indicating what the error is. You can't set the clock until the error is resolved (a disc stuck in the CD player, for example, on no disc in the CD when it's been told to play).
The procedure is as follows (which you probably know):
The audio system display usually shows the time when the ignition switch is in ACCESSORY (I) or ON (II). It shows the operation mode of the radio, cassette player, or optional CD player/changer when you operate them, then goes back to the time display after five seconds.
If an error occurs while operating the optional CD player or changer, the display will keep showing the error code and will not switch to the time display until the error is corrected. You can set the time only when the clock is displayed.
To set the hours, press the H (Preset 4) button while pressing the CLOCK (SCAN/RPT) button. Press and hold the H button until the hour advances to the desired time.
To set the minutes, press the M (Preset 5) button while pressing the CLOCK (SCAN/RPT) button. Press and hold the M button until the minutes numbers advance to the desired time.
If you don't have a CD player, or no error is showing in the clock read-out, leave a comment so I can investigate further.
Hope this helps you.
Nov 11, 2009 | 2002 Honda Civic
The CD Changer will not work and shows ERR 1 and I
The cd changer internal mechanism is faulty, replace the cd changer itself.
Jun 04, 2009 | 1999 Audi A6
CD Changer Not Working - Please Help
THE CD YOU ARE TRYING TO PUT IN THE PLAYER MAY NOT BE COMPATIBLE, IT MAY ONLY PLAY CD-R CD-RW
May 05, 2009 | Car Audio & Video
1994 lexus ls 400, cd player
Hello I just purchased a 1991 Lexus LS400
I have one of those 6 cd changers and got "err" when I started up the CD.
Here is what I tried and the result
1. I took out the CD,s replaced with new ones and it played but only for a bit, then even the new CD's got the err message
2. I then though maybe dust and/ or dirt so I took out the 6 pack of CD's and blasted compressed air into the unit from a can of computer cleaner compressed air. Lost the err message but then came back
3. Read a few other ideas on the problem and then tried the old hair dryer trick. (I am a long term live a board boater and have brought back may mis-behaving electronic devices that have moisture issues with the hair drier) However the hair drier did not do away with the err message.
4. two more boating tricks I thought of... I wiped down each leaf of the CD pack with rubbing alcohol
and actually got a good deal of dirt off the plastic, finally and probably the solution I sprayed some "wire dryer" a light spray then a mist.( Wire dryer made by Gunk is a spray can of a liguid we used all the time to get cars started in the cold weather, even got a better connection by spraying on battery wires to get the sailboat diesel started with an almost dead battery.)
I Waited a few minutes put back the cd holder and it worked.
It has been about 6 hours and it is still running like a champ.
could have been the combination or just the wire dryer...not very scientific maybe it will help
Jan 12, 2009 | 1993 Lexus Ls 400
1992 6 disc cd changer not working
Are you placeing cds face up or face down in the changer, some cd changers will only play with the cds face down.
Oct 26, 2008 | 1992 Lexus Es 300
6 DISK CD CHANGER ON A 2001 LEXUS RX 300 ERROR
As the consumer there is nothing U can do to fix this problem, the error code is for a radio technician with the right technical publications and tools to fix the problem, you will have to pull the radio/CD player and send it out for repair with an authorized Lexus sound system repair station.
Oct 14, 2008 | 2001 Lexus RX 300
1994 lexus ls 400 radio reads err when i try to play cd changer.
Hi
How can I find the code for my 1994 Lexus LS400 radio.
Please replyat : shahramanwari@cox.net
With regards.
Sep 16, 2008 | Car Audio & Video
Pioneer P626 car audio in 1991 Lexus LS400
With radio off I pressed the CD button and CD came on with no error code and works fine.
Feb 17, 2008 | Car Audio & Video
Car Audio & Video Logo
320 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
