I need manual worbook for my ketron solton MS5 keyboard . Can you help
Cerco manuale di istruzione solton MS5 keyboard anche per e-mail
pippokid
  • 14 Answers
SOURCE: Problemi con explorist 500
Ciao, mandami una email a casa1111@libero.it altrimenti tramite questa via ci mettiamo fino all'anno prossimo. hai messo una basemap europea sulla SD card? nella directory "Backgroud maps"? se hai fatto così avrebbe dovuto sentirtela. Se in ogni caso metti la basemap europea nella directory USBTRANS della SD card dovrebbe caricartela nella memoria interna del GPS (dopo il caricamento non è più presente nella SD card, per cui se devi ripetere l'operazione devi rimettercela).
Ciao
Alberto
Posted on Oct 04, 2008
namzyanzy
  • 435 Answers
SOURCE: manuale italiano videocamera canon pal mv630i
You can download the Italian manual here:
Canon MV630i manual - Italian
Thank you
Posted on Feb 07, 2009
SOURCE: My router DI-624 does not get an IP address
Is the M2 LED light on? That's a light that tells you if a problem exists with the hardware itself.
If you connect the laptop directly to the modem does it connect okay? That will tell you whether it's your laptop and cable that might be the problem.
If it does connect okay with just the laptop and modem in the mix try these steps:
-disconnect the modem from your laptop
-double check that your laptop has no static IP info on the network card including a gateway or DNS settings
-power off your laptop and the router
-connect the laptop to the router (port 1 on the back)
-disconnect the router from the modem so only the laptop is connected to it
-power on the router
-power on the laptop
-make sure a green light appears on the front for port 1
-type in ipconfig /flushdns at a command prompt
-see if you can ping the default IP address 192.168.0.1
-if you can, see if you can connect to the router console
-if not, hold the reset button in for 10 seconds and release
-wait for the router to come back to green lights
-reboot your laptop
-try to access console menu again
If your laptop doesn't work when connecting directly to the modem, we can take other troubleshooting steps together.
Let me know how it goes and if it works don't forget to rate this solution! :)
Posted on Mar 31, 2009
SOURCE: Cerco le istruzioni per l'uso
Hola Sergio.
Estoy
usando Google Translate.
http://translate.google.com/#auto'es'
Manuales de Gardena son el link.
http://waterheatertimer.org/How-to-program-Gardena-C1060.html#manuals
Utilice Google traducir. Copiar el p?rrafo del manual. Pegar en el apartado traductor Google.
Posted on May 25, 2011
SOURCE: solton ms60 keyboard... volume stuck , can't adjust sound once set
There are a number of ways to adjust the volume. 1) Normally a button or keys on the keyboard will adjust the sound volume. You might have to press and hold the FN key or the Alt key then hit the key that adjusts the volume up or down. 2) If you right click on the megaphone at the bottom right near the time you can adjust the volume. If you click Start/Control Panel and look for Sound and Audio Devices you can adjust it there. 4) If you click Start/Programs/Accessories/Entertainment you will see a way to adjust the volume.
Posted on Apr 02, 2012
My Ketron Sd5 seems to play a different key on the right than on the left. For example if I play a beat in the key of G (left) the right hand side plays in A. Can you help?
You need to check your manual for instructions on key transpose. The right side has been transposed one key higher. If you don't have the manual, try resetting the instrument by removing the internal battery and reinstalling it. Good luck!
Aug 01, 2016 | Ketron SD5-61-Key Arranger Workstation...
Funziona 10 minuti poi si accendono e lampeggiano insieme la spia verde timer e la spia rossa turbo, se spengo e accendo di nuovo riparte e si ripete il guasto sempre dopo 10 minuti
Ciao.
Il frigo ti sta dicendo che non riesce a rafreddare come dovrebbe. Il caso piu comune e' dovuto a sistema di defrost che non funziona.
Prova a eseguire un defrost completo, staccando la spina (o l'interruttore) e lasciando il frigo staccato con porte aperte tutta la notte. Se questo risolve il problema allora era il sistema defrost. Se il problema ritorna in un paio di giorni o settimane devi riparare il sistema defrost. Il sistema defrost e' situato dietro la parete in fondo, di solito nel compartimento freezer. Il sistema comprende un evaporatore, che e' una resistenza che riscalda le spire del condensatore per prevenire congelamento. Il sistema comprende anche un termostato e una ventola (non quella di refrigerazione, un altra). Se il problema sparisce con defrost e ritorna in un paio di giorni queste parti vanno controllate. I test si fanno leggendo le resistenze delle singole parti.
Se il defrost non risolve il problema, cause comuni per il guasto sono:
Condensatore sul compressore da cambiare.
Sistema ventilazione (se presente in questo modello) non funzionante.
Controllo elettronico della temperatura diffettoso.
Perdita di gas refrigerante.
Le parti relative ai guasti elencati devono essere controllate.
Inizia controllando se il defrost ha a che fare con il problema. Quella e' la causa piu comune per it tuo problema ed e' facile da diagnosticare, anche a livello utente. Usa il numero che trovi nel manuale per ottenere parti, per verificare stato di garanzia, o per ottenere un appuntamento con un tecnico.
In bocca al lupo.
Ginko
Aug 10, 2011 | Refrigerators
Cerco le istruzioni per l'uso del T 1030 D: potete aiutarmi? e-mail: clanpro@libero.it Sergio Proietti
Hola Sergio.
Estoy
May 25, 2011 | GARDENA Water Timer
HO ACQUISTATO IL 20 APRILE 2011 NORTON INTERNET SECURITY 2011 CHE HA FUNZIONATO FINO AD OGGI E ORA RISULTA DISATTIVATO COSA DEVO FARE?
Ciao.
Symantech vende licenze annuali. Quando aquisti un prodotto in realta' ottieni un abbonamento per l'uso annuale della licenza. Dopo un anno la compagnia chiede di rinnovare il prodotto pagando per un altro anno di licenza d'uso.
Quando la licenza scade il prodotto inizia a funzionare in modalita' limitata. Questo e' abbastanza grave se la tua licenza e' scaduta anche per l'antivirus. Un antivirus scaduto non protegge efficacemente il tuo sistema.
Per rinnovare Norton devi contattare Symatech Italia. Il rinnovo puo essere fatto per telefono, via email, oppure online.
Vedi: Supporto dei prodotti Norton.
Se avessi bisogno di un antivirus gratuito finche non decidi di rinnovare Norton puoi provare Avira. Disinstalla il vecchio antivirus prima di installare un antivirus differente. Due antivirus che funzionano allo stesso tempo rallentano il computer.
Ciao e in bocca al lupo.
Ginko
May 12, 2011 | Computers & Internet
Errore f2 whirlpool sesto senso lavastoviglie
Ciao. La machhina risponde con F2 quando c'e aqua alla base della vasca ed il ciclo di scarico non e' completato in tempo limite (long drain) o quando il meccanismo che determina il livello dell'acqua segnala che l'acqua e' oltre il limite. In entrambi i casi ci sara acqua alla base della lavastoviglie.
Il codice d'errore si resetta tenendo premuto il tasto ON per 5 secondi, e poi riavviando un ciclo.
Se questo non funziona stacca la spina dalla corrente, rimuovi tutta l'aqua dal pannello base della vasca, e controlla lo scarico. Controlla anche l'altezza e il gomito del tubo di scarico dietro la lavastoviglia. Assicurati che rispetti le specifiche che trovi nel manuale, altrimenti rischi un effetto sifone causato dal riflusso d'acqua di scarico dentro la vasca della lavastoviglie. Questo puo provocare lo stesso errore.
In bocca al lupo.
Ginko.
Feb 02, 2011 | Dishwashers
Cerco le istruzioni dvd recorder rh7500
Le istruzioni per questo modello sono disponibili solo in Inglese.
Per favore usa il link qui sotto per scaricare il manuale in formato PDF.
[PDF] HDD/DVD RECORDER.
Ciao.
Ginko.
Nov 21, 2010 | Computers & Internet
Il mio Acer T180 non da più segni di vita nel senso che, collegando il cavo di alimentazione, non si gira nessuna ventola e non si accende nessuna spia L'unica prova che ho fatto è...
Sembra che il vostro alimentatore pu? essere morto, perdona il mio italiano, anche la if alimentazione non si accende non mean it effettivamente funziona, prima di cambiare la tensione, provare questo, scollegare il system, rimuovere la scheda madre battery, tenere premuto il potere pulsante per 30 secondi, rilasciare,, sostituire la batteria, plug-in e si accende,,, se quello non riesce, individuare i pin sulla scheda madre che il pulsante dell'alimentazione si collega anche, ci dovrebbe essere qualche altra cosa l? come bene, come reset, LED di alimentazione e HD LED, assicurarsi che il sistema ? collegato a sua volta e lo ob utilizzando un cacciavite tipo di lama e bridiging entrambi i perni di alimentazione con esso. I apoligise ma non sono molto bravo a itallian Quindi, se ho mescolato tutto mi perdoni ..
Sep 16, 2010 | Acer Aspireā„¢ T180 PC Desktop
Ho perso l'albero che va montato al centro del robot sul quale si appoggiano poi i dischi per tagliare...dove lo posso trovare? IL modello e MASTERCHEF 65 ELECTRONIC...
Ciao Matteo.
Le opzioni per aquistare un ricambio Moulinex sono contattare il piu vicino centro di assistenza Moulinex, o chiamare direttamente Moulinex, al numer che trovi sul manuale.
In questa pagina una lista dei centri di assistenza Moulinex divisi per regione. Clicca sul link al lato e scorri giu la pagina: Centri Assistenza Moulinex in Italia.
Il contatto e la lista dei centri di assistenza sono disponibili anche sulla pagina servizi del sito Moulinex. Clicca qui per aprire il sito Moulinex Italia.
Se non vivi in Italia usa come riferimento il sito Moulinex relativo alla tua nazione di residenza.
Per favore non dimenticarti di lasciarci il tuo voto.
Buona fortuna.
Ginko.
May 08, 2010 | Moulinex DG6 Food Processor
Ho perso manuale di uso e manutenzione posso averlo on line ?
Clicca il link qui sotto per scaricare il manuale in Italiano:
Download italiano Libretto d'uso
Qui c'e anche la pagina di supporto Miele.
Non dimenticarti di votare adeguatamante la mia risposta, se questo ha risolto il problema vota blu, se ha aiutato blu, se non e' di aiuto giallo, il rosso e' per chi ti insulta.
Io direi che se cercavi il manuale qui il blu ci sta'.
Ciao, e in bocca al lupo con l'asciugatrice.
Jan 05, 2009 | Miele Novotronic T230C Electric Dryer
JVC DR-MH30S DVD Recorder Image file
ciao! tutti vittime del dvd rec [jvc dr mh20-]..jvc dr mh 30...jvc dr mh 50..e un risolvere dell problema di LOADING...il mio jvc dr mh30..di 6 mese e roto ..ma trovo risolvere..difetto e nel hdd,160gb..e in corrozione..e roto hardisk,solo sistema operativo.......con softer COPY CLONE PRO..free da iternet.scarica nell cd room..nel avvio dell pc,che sono due hdd,uno rotto ,e uno buono..guarda instruzione dell cd..e tutto ok,per copy di hdd..e tutto ok per legare poi nell dvd rec jvc dr mh 30..ho provato io e tutto ok...ma io ho trovato hdd dell dvd rec jvc dr mh20..e io ho un dvd rec jvc dr30..ce un problema picollo dopo copy cloner,,mio dvd rec mi conosci solo 80gb..ma perche e in origine da dvd rec jvc dr mh20[80gb]..cercho un hdd di dvd rec drm h30..opure jvc dr mh50..per copy cloner,mio hdd,per conosciere 160gb..opure 250gb..atentti problema di LOADING..e nell due alimenti di hdd..e suporte di dvd..sono quattro line..12v..terra..terra..5v....sono simille anche perhdd..anche per suporte dvd..controla nel condizione di LOADING..se non sono precise..voltaggio..persempio..12v=10v..opure 5v....4.2v..e perdita..da un contesatore electrolitica.e asciugato da lavoro fastidiosa.......se aiuto da poco..non lo so aspettiamo nell mio e-mail....arivederci[ agimqosesda@yahoo.com ]
Apr 14, 2008 | JVC DR-MH30S DVD Recorder
214 people viewed this question
k24674
